Old Apr 01, 2012, 09:16 AM
rc_newbie1991 is offline
Find More Posts by rc_newbie1991
United States, GA, Alpharetta
Joined Feb 2011
torque 2818T/900 question
Hey guys, i posted something similar to this in 3d flying but haven't really got any response.
So im running a 35 amp air boss on this motor with my 45 inch edge. I am a little underpowerd so I upped the prop size to a 13x6.5. I am now pushing 32 amps on ground (25 or so in sky) but my esc is running hot on landing. Its on a 3 cell by the way. Anyway I was going to upgrade to a 45 amp esc and stick with this set up but now im thinking of running 4 cells. The site says this motor has crazy power with 45 amp speed control, this motor and a 4 cell. Weird thing is im pushing 32 or so amps with a 3 cell and the motor says rated to 35 amps. Im afraid that a 4 cell will overload the motor.
Has anyone ran a 4 cell on this motor? if so what are the results? I would be going back down to 12x6 prob but still think i would be pushing the motor's limit
rc_newbie1991 is offline Find More Posts by rc_newbie1991
Old Apr 01, 2012, 10:50 AM
whitecrest is offline
Find More Posts by whitecrest
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
Here's a DriveCalc run for the Torque 2814T-820 that is close to your motor. On 4S, using a 10x7 APC E seems to provide good operating parameters with a lower draw and good efficiency. Always use a watt meter to verify your setup.
whitecrest is offline Find More Posts by whitecrest
Old Apr 01, 2012, 12:05 PM
Joined Feb 2011
Yeah, I was thinking of just getting that motor but since I already have this one and a 45 amp esc was just going to give this one a go if i could.
Old Apr 01, 2012, 05:28 PM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
13x6.5 would be WAY too much prop for the 900kv motor on 4s, you would be pushing about 80A An 11x5.5 would be more like it but probably still pushing a little over 35A.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Apr 02, 2012, 04:07 AM
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
+1. The 11x5.5 ought to be a good choice on 4S.
Here is a DriveCalc run using an 11x5.5 on the same stand-in motor as above. Thrust is a little better than the 10x7 with just a small drop in efficiency.
Old Apr 02, 2012, 06:31 AM
Aberdeen
Joined Mar 2006
Interesting Drive calc graph though I was actually talking about the 900kv 2818T/900 motor that the OP owns, not the 820kv 2814T/820. If you put the 900kv in DriveCalc then the amps would no doubt be a bit higher but probably still acceptable in bursts.
FWIW I actually own the 2814T/820 motor and on 4s it's far and away best on an APCe 12x6 prop. On a fresh battery It pulls 45-46A for around 680W with that prop which is fine providing you dont fly around at WOT all the time.
Old Apr 02, 2012, 07:27 AM
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
Here is the run for your motor on a 12x6 APC E. It appears to closely match your measurements. The OP's exact motor is not in the program yet.
Old Apr 02, 2012, 08:08 AM
Joined Feb 2011
Thanks a lot, I'm not sure if i'm reading the charts right but i see what you are saying. I would definitely go down on prop size with a 4 cell. I may just borrow a 4 cell this weekend and amp test it on meters.
Old Nov 11, 2012, 04:48 PM
jw357_23043 is offline
Find More Posts by jw357_23043
Shut up and Fly!!!
jw357_23043's Avatar
United States, VA, Hartfield
Joined Aug 2011
Where can i download the drive calculator?
jw357_23043 is offline Find More Posts by jw357_23043
Old Nov 11, 2012, 10:29 PM
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
Here you go.
Sold Extreme Flight Torque 2818T 900 kV Motor sdueck Aircraft - Electric - Power Systems (FS/W) 4 Apr 17, 2012 03:49 PM
Sold Torque 2818T/900 $55 Shipped Conus blakevan Aircraft - Electric - Power Systems (FS/W) 0 Mar 05, 2012 09:25 PM
Sold Selling a Torque 2818T/900 (PRICE DROP) justwanttofly Aircraft - Electric - Power Systems (FS/W) 3 Feb 25, 2012 03:47 AM
Sold Torque 2818T/900 motor jb_bak Aircraft - Electric - Power Systems (FS/W) 2 Feb 03, 2012 10:20 AM
Sold Torque 2818T/900 tonyrb Aircraft - Electric - Power Systems (FS/W) 1 Nov 02, 2011 03:16 PM
