Old Apr 01, 2012, 02:59 AM
CnadianFF is offline
Find More Posts by CnadianFF
Canada, BC, Kamloops
Joined Sep 2011
Wrong Prop or do I have to Reverse the Motor rotation?
This may be a dumb question but I went in to my lhs and asked for the 7x5 to upgrade my stock Stryker prop. They sounded very sure which one I needed and off I went. When I tried the prop it pulls not pushes. Do I have the wrong prop? They said it was for a pusher plane. Or is there a way to reverse the rotation of the motor and is that bad for it?
CnadianFF is offline Find More Posts by CnadianFF
Old Apr 01, 2012, 03:10 AM
Rich in ILM is offline
Find More Posts by Rich in ILM
Retired in NC
Rich in ILM's Avatar
USA, NC, Wilmington
Joined Sep 2010
Just reverse the motor. (Switch 2 of the 3 leads to reverse rotation.) Make sure the print on the prop is facing the direction of flight the same way it is when the motor is on front of the plane. Several pusher design planes don't use pusher props, from the factory, and run the motors clockwise. I do it all the time as the selection of pusher props is quite limited.
Rich in ILM is offline Find More Posts by Rich in ILM
Old Apr 01, 2012, 07:25 AM
M Ashmore is offline
Find More Posts by M Ashmore
Average User
M Ashmore's Avatar
Bakersfield, California
Joined Aug 2003
Your lhs guy was thinking in terms of ic engines and not electric motors. If your 7x5 prop is a pusher it will probably be designated as 7x5p.
Reverse rotation, or pusher props, are used on ic engines when configured as a pusher because the engine can only turn in one direction. Advantage goes to the electric motor as it can turn either direction with a simple swap of any two motor leads. You can use the 7x5 prop if it's turning the right direction and has the lettering facing forward.
M Ashmore is offline Find More Posts by M Ashmore
Discussion Twin Motors and Prop Rotation kingsflyer Scale Boats 30 Mar 10, 2012 01:38 AM
Discussion Do i need counter rotating props? npowell28 Beginner Training Area (Aircraft-Electric) 5 Jan 25, 2012 02:17 PM
Discussion Counter Rotating Props or Pusher Props bobmaxiao Power Systems 5 Oct 30, 2011 05:40 AM
Discussion Funjet - 3cells 3900KV Motor 5x4.5 Prop - Right or Wrong? Dorlingus Power Systems 13 Feb 16, 2008 03:36 PM
do i need normal rotation or revers rotation to use with gearbox? daltrey Electric Plane Talk 5 Dec 11, 2004 12:21 PM
