Canada, ON, Stouffville
Joined Nov 2011
No...it is a standard type connector...From your post, got the impression that you didn't want to use a different battery....here is a good match from HK.
http://www.hobbyking.com/hobbyking/s...mpatible_.html This is exactly the same at 1/7th the price...Downside, at this time of year batteries are hard to get, and they are BO. http://www.hobbyking.com/hobbyking/s...zone_Etc_.html This one is lower capacity...but they have...Just buy 10 At a $1.33 each...can't go wrong.sts41 |
Joined Apr 2012
Lol maybe if I pick up a second job I'll see the light. Have you any input on the 30c vs. The 15c batteries if I promise to join the dark side?
Edit: I was able to search and read to understand the difference in general but I'm not sure the difference in terms of this particular plane and battery size. Thanks again guys. |
at any rate (ha) when a battery says it has a 30C discharge rate, that means it can be discharged at 30x its capacity rating for some length of time. the length of time is usually stated somewhere either on the battery or in the literature. usually the battery will be printed with a sustained and peak discharge rating. for example: a 2000mAh (2Ah) battery that is rated for 10C continuous discharge and 15C peak can be discharged at 20A continuously or 30A for a short time, usually in a burst. |
| Thread Tools | |
| Help! Am all lost now with RC-Lander EDF | seedo | Micro EDF Jets and Power Systems | 4 | Mar 30, 2012 03:00 PM |
| Discussion Thunder AC6 charger and WoW adapter for 1s battery? | ZTECH | Batteries and Chargers | 4 | Feb 17, 2012 07:38 PM |
| Sold Champ w/Batteries/Charger/Extra Motor | Kevin Greene | Aircraft - Electric - Micro & Indoor Airplanes | 7 | Jan 23, 2012 11:44 AM |
| Discussion Hobbyzone Champ Lost Power!! Can anyone help? | aviator4934 | Micro RTF | 6 | Jun 19, 2011 09:25 PM |
| WOW I am completely STUMPED!!! need help...ep concept | thazy2 | Electric Heli Talk | 13 | Feb 04, 2003 11:14 PM |
