Old Nov 04, 2001, 07:26 PM
johnbob is offline
Find More Posts by johnbob
Joined Oct 2001
Herr Piper Cub Electric conversion help
This is my first electric, so have patience. I flew my Piper Cub for the first time today. Stats: 21 oz RTF, 48" span, 328 sq in area, 8.8 oz/sq ft load, I used the Geat Planes T-400 GD (1.7-1) with a 9X7 and later a 9X6 APC electric prop. I am using a GWS Naro reciever set up with the 2 amp speed control and a 7 cell 270 mah battery.
Performance is dissapointing as plane will not ROG and has a very poor rate of climb, it in fact will stall if rate of climb is not very conservative.
I am inexperienced with the electrics so my question is how to improve performance?
Seems to me that the mah and voltage of the battery might be the first place to start. Was going to try a 8 cell 600 mah pack was hoping that increased voltage/capacity would offset weight trade off.
Did I miss completely? Should this be a 600 setup? Or is there a more effiecient 400 GD than the Great Planes.
Not looking for a hot rod but would like more spirited performance, ROG at least.
johnbob is offline Find More Posts by johnbob
Old Nov 04, 2001, 07:57 PM
Rotten Robbie is offline
Find More Posts by Rotten Robbie
Rotten Robbie's Avatar
Kent, Wa.
Joined Feb 2001
I would change to a 5A ESC and an 8 cell pack. Get higher current battries also.
Rotten Robbie is offline Find More Posts by Rotten Robbie
Old Nov 04, 2001, 09:26 PM
KOMET 44 is online now
Find More Posts by KOMET 44
D.G.B.
KOMET 44's Avatar
Southington, Connecticut, United States
Joined Jun 2000
Johnbob,1) go to 8x800 ar batteries .2) i would also go to a bigger gear ratio.in my dallair sportster i use a 2.33to1 gear box .9x6 graupner slim prop.i know its not exactly the same plane but close.my esc is a jeti110.Also you will have to toe the wheels in./ \my plane is a hand full to r.o.g. but it will no problem.most of the time i just hand launch it, then do touch-n-go's with it.power is graupner sp400 .i had the same experiance as you.i read a artical review by bob aberly and i thought it was just what i needed to get into eletric flight.i also had the identical set up as him and the plane wouldn't fly. then i got some help from the ezone and never regret it yet!!!!! ITS JUST A ELECTRIFYING SPORT! stefanP
"Ghost rider requesting a fly by"
KOMET 44 is online now Find More Posts by KOMET 44
Old Nov 04, 2001, 09:50 PM
Jim Winget is offline
Find More Posts by Jim Winget
Mountain View, CA, USA
Joined Nov 2000
Upgrade your speed control immediately. There is no way a 2 amp controller will work for you. Buy something that will work for speed 400 motors geared or direct. The pixie 14 or pixie 20 are good bets, but if you go with another brand, get something that will at least take 10 amps. This is particularly important if you are ROGing off grass and end up with a nose over and engine stall.
Jim
Jim Winget is offline Find More Posts by Jim Winget
Old Nov 04, 2001, 09:54 PM
Mauilvr is offline
Find More Posts by Mauilvr
Almost a Pilot
Mauilvr's Avatar
NorCal
Joined Oct 2001
Your motor choice should be O.K. but I agree with the previous suggestions. You need larger capacity batteries - the 8X800 suggestion is a good one.
Your ESC is too small - your current draw is quite likely far >2 amps. Try to measure this with the larger batteries. You'll probably need a 5-10 amp ESC.
To get decent ROG you'll probably want to add a steerable tailwheel. Use the search function here on ezone and check out what has been done for the GWS Tiger Moth.
I think you're close - just a few changes necessary.
Good Luck!
Mauilvr is offline Find More Posts by Mauilvr
Old Nov 04, 2001, 09:55 PM
Joined Nov 2000
I was so stunned by the 2 amp speed control, that I failed to comment on the rest
You definitely need a better battey pack. Probably the only reason your speed control didn't already fry, is that your battery pack has so much resistance it can't produce the current your motor needs. As suggested above, a 7 or 8 cell 500-800 mah AR cell pack should work well. I'd go with 8, but it might be flyable on 7. As an alternate less costly solution, an 8 cell 600AE pack should work. After you get a better handle on the plane, you could try an 8 cell KR1400AE or move to Nimhs.
Jim
Old Nov 05, 2001, 07:20 AM
johnbob is offline
Joined Oct 2001
I appreciate all of your comments. i am going to try the 8 cell 800 mah battery pack and also upgrade the esc. Is there a "neat" way to add a fuse?
Comment; this is my first try at electrics, I have been flying with glow for two years and love it. I have been really excited about trying the electrics and flying in the back yard, and I am sure that once the bugs are worked out the electrics should be a blast. I would like to let you all know that I really appreciate your help, as you can tell I am a real newbie to electrics but I am here to stay.
Thanks for all your comments, on another scale (ha ha) I have investigated converting my 1/6 scale Pica Waco bipe to electric, but the $400 tag is hard to get past.
Old Nov 05, 2001, 11:21 AM
Kent, Wa.
Joined Feb 2001
<i><b>Is there a "neat" way to add a fuse?</i></b>
On the higher currrent ESCs tha have current limiting and thermal protection, is there really need for a fuse?
If so use a fuse at least double the ESC rating. It is not to protect the ESC. It is to prevent the plane from going up in flames. The fuse won't blow unless the ESC fails.
Robbie
Glow to Electric Conversion Help John Boren Sport Planes 0 Jul 14, 2003 12:35 PM
LMH electric conversion help. :) Tram Electric Heli Talk 12 Mar 25, 2003 07:37 AM
Looking for micro pushrod assy. for Herr piper cub slabs Beginner Training Area (Aircraft-Electric) 9 Nov 20, 2001 10:45 AM
Herr piper cub as speed 400 bztguy Sport Planes 2 Sep 18, 2001 05:19 PM
gas to electric conversion help needed. mflann Electric Plane Talk 8 Sep 10, 2001 07:03 PM
