This thread is privately moderated by SkyCadet, who may elect to delete unwanted replies.
Old Mar 31, 2012, 10:49 PM
SkyCadet is offline
Find More Posts by SkyCadet
Segelfliegen bedeutet Freiheit
SkyCadet's Avatar
Canada, MB, Winnipeg
Joined May 2010
Wing servo ball links installed...
I decided after inadvertently breaking off one of the flimsy aileron link horns, to follow another fellow who used the same thing: Dubro #189 ball links (aileron type). These normally get used inside a fuselage to link the servo horns to "L" wires, but these are a fantastic way to get a solid aileron linkage!
These use a 4-40 screw to normally lock a control rod/wire in place; in lieu, I used 3/4" cap screws with 4-40 threads into the ball link, and then used CA to fix them. I then cut off the head o fthe cap screw about 1/8" in from the head base, and smoothed off. The ball/screws then thread into 5/32 holes I drilled right next to the locations of the old horns. I trimmed the material carefully first, then used white glue and matching paint to hide the wood, where showing. I started with pilot holes of 1/16" and took my time with my Dremmel.
CA was dripped into the holes first, then a drop or two onto the screws. These then got fed into the holes, and bite WELL! Wicked the CA that may have squeezed out with a Qtip. Voila! Ball linkages on my Ailerons!
I plan to use the stock control rods, though ANY 2-56 threaded rod will also do. The links come with nylon sockets that have 2-56 threads in them, and brass couplers which can be soldered or adhered using CA after cleaning the surface of a straight rod.
See pix below for finished results!
Sky Cadet
SkyCadet is offline Find More Posts by SkyCadet
Latest blog entry: New plane - Evader!!!
Discussion What's a good ball link remover plier? tom_c5 Large Electric Helis 6 Mar 01, 2012 01:39 AM
Sold 6-(never flown) Hitec 645 MG servos with titanium ball links- $90.00 shipped! 540RCflyer Aircraft - General - Radio Equipment (FS/W) 2 Oct 31, 2011 06:17 PM
Found Ball link pliers and ball link sizing tool billyzelsnack Aircraft - General - Miscellaneous (FS/W) 0 Dec 01, 2006 01:49 AM
Rave I need a link to a site showing spoiler instal. sa-woody Sailplane Talk 2 Jun 03, 2005 03:23 PM
