The evil epoxy-of-doom is dry. Woohoo!
Only took 48 hours for my 15 minute epoxy to cure. Nodd's new workshop rule...
- 5 minute epoxy - mix for one full minute
- 15 minute epoxy - mix for at least two minutes
I probably mixed it for all of 30 seconds as I was in a bit of a rush. BIG MISTAKE. Well back to the build...
Bolts or Bands
Some of you folks are probably going to give me all sorts of grief over this decision but it is, what it is. I've used both wing mounting systems, nylon bolts & good old rubber bands. Both have their pros & cons. Bolts make for a slicker install but on a high aspect wing can be somewhat unforgiving during a cartwheel landing. Rubber bands look dorky but are more forgiving during those inevitable D'OH moments. I chose to go with the latter...
At least I used spiffy carbon fiber instead of dowel...
In an effort to redeem my tarnished sense of style, I next went about carving probably the most complex shape imaginable...
I have no idea what this part is called, a fairing of some sort. Anyway it goes on top of the wing to help blend things in with the fuselage...
After much head scratching I figured out a neat way to carve the wing's shape into this fiddly little piece. I taped some sand paper to the wing & began rubbing. That's cheating I know...
A quick test fit (& no these wimpy little bands aren't for flying)...
That fit is close enough. Filled the gaps with a little putty & I'm done for the night...
