Old Apr 11, 2012, 10:17 AM
frankswd is offline
Find More Posts by frankswd
frankswd's Avatar
United States, OR, Eugene
Joined Sep 2002
.[/QUOTE]
Ideally I would have liked the hatches to sit flush with the bottom of the wing but again with the thin airfoil, the servo takes up too much room. Compounding the problem, I also had to reenforce the hatch around the control arm slot as it was kinda flimsy at first. Still, compared to this huge wing these tiny hatches should have negligible effect. I'm pretty pleased with the instillation, came out fairly tidy. The wing is a little thicker where I'm planning to install the flap servos so hopefully those will go in flush. Will have to see.[/QUOTE]
for future reference here's what i did with thin wings install.
http://www.rcgroups.com/forums/showt...1536798&page=4
frankswd is offline Find More Posts by frankswd
Old Apr 11, 2012, 04:38 PM
Nodd is offline
Find More Posts by Nodd
Build something.
Nodd's Avatar
United States, CT, Fairfield
Joined Mar 2012
Yeah that Elektra looks like a sweet plane. I like the blister bubble servo cover & really like the internal linkage arrangement. I might play around with some sort of aerodynamic cover for my linkage. I've seen them on lots of other planes. Might be a good idea to cover the linkage anyway to keep it from snagging on stuff during landing. Thanks for the link.
Nodd is offline Find More Posts by Nodd
Old Apr 12, 2012, 10:29 PM
Nodd is offline
Build something.
Nodd's Avatar
Joined Mar 2012
More servos to mount! Unlike the aileron servos which are mounted in a mirrored orientation so they move in opposite directions, thankfully I realized in time, the flap servos should be mounted using the same orientation. That way they move the flaps up/down together. Glad I caught that before installing them, although I guess there's a number of ways to reverse a servo if needed...
As I'd hoped, there was sufficient room to flush-mount the flap servo hatches...
I may go back & tweak the aileron servo hatches to see if I can clean them up aerodynamically but for now I need to concentrate on getting the rest of this plane built.
Old Apr 13, 2012, 03:31 PM
frankswd is offline
frankswd's Avatar
Joined Sep 2002
Here's how i would go about making my custom servo covers
1) get some modeling clay from hobby shop.
2) blue tape all around your servo wing area and servo arm.
3) shape up the clay as your aerodynamic insights guide you
4) take some cooking shrink wrap and lay it out smoothly over your clay mock up be sure to do at least one left and right side, they are different
5) wet-out some fiberglass and do a layup, i suggest at least 2 layers @ 45 degree angles to each other. Also you can use a slightly thicker plastic to smooth out over top of your layup to make it look molded, and not show the weave so much, kitchen garbage bags can work.
6) I suggest you might want to give them a short bake out curing in toaster oven or the big oven ( when mom's not looking) deny any accuzatoin of funny smells
Not hard at all, paint and fly!
Old Apr 13, 2012, 03:33 PM
frankswd is offline
frankswd's Avatar
Joined Sep 2002
and what??? my servo mounts didn't impress dang it
Old Apr 13, 2012, 03:41 PM
frankswd is offline
frankswd's Avatar
Joined Sep 2002
and you can buy them here, if you don't want to use your building skills!
http://www.espritmodel.com/sailplane-accessories.aspx
Old Apr 13, 2012, 03:42 PM
Mike Seale is offline
Find More Posts by Mike Seale
f5b-uk
Mike Seale's Avatar
United Kingdom, Dorset
Joined May 2002
I saw them and was impressed...but with no further information other than the pictures it was impossible to assess how they were made and what tools and materials would be needed to make similar. Also, it looks like they need gluing into the wing and if/when a servo needs to be replaced/repaired you would have to cut them out...yes? Because of this I dismissed them as being too complex compared to (a) gluing the servo in directly or (b) making a wooden frame and screwing them in.
Mike Seale is offline Find More Posts by Mike Seale
Old Apr 13, 2012, 03:53 PM
Woodstock 1 is offline
Find More Posts by Woodstock 1
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
This is the first time I've seen asymmetrical flap servos: most radios can reverse servos individually, so this is an unusual approach. You may find getting equal linkages and throws, etc. tough to achieve now.
Woodstock 1 is offline Find More Posts by Woodstock 1
Old Apr 13, 2012, 03:57 PM
TwoHeadsBrewing is offline
Find More Posts by TwoHeadsBrewing
Moderately Dangerous
TwoHeadsBrewing's Avatar
United States, CA, Chico
Joined Apr 2011
Wow, incredible build so far! Can't wait to see the rest of it, and of course, the maiden.
TwoHeadsBrewing is offline Find More Posts by TwoHeadsBrewing
frankswd is offline
frankswd's Avatar
Joined Sep 2002
Ok, so here's the deal. They were made Via 3-D printing by a friend of mine.
The mount is glued to the wing. The servo is held in by it's tabs retained in a slot. One scew to keep the servo from lateral movement. Remove the one screw, slide servo out at will.
The other version with the pin on the spring clip stops lateral movement, so no screws to unlock the servo. just lift and slide.
You could fabercate something like this out of wood, but you would most likely use 3 scews into wooden posts glued onto your wing . These wing servos are really nice and not too expensive however.
And i'm considering the idea of producing some more of these mounts that i designed.
Old Apr 13, 2012, 06:33 PM
Nodd is offline
Build something.
Nodd's Avatar
Joined Mar 2012
Setting up the two flap servos so they natively move in the same direction makes sense to me. I don't really see a need to use an extra channel on my receiver just so I can reverse one servo. Granted another option would be to pop open one of the servos & mess around with wire swapping but these servos are kinda small. I'm not sure my fat fingers, eyesight or soldering skills would be up to the task. Then there's plugin servo reversers but to be honest I don't foresee any issues with my current setup. The two control horns are positioned less than an inch different from each other along the wing's long axis. The distance from servo arm to control horn is identical for both. I don't expect any problems using this setup. We'll see though I guess.
The other reasoning for this setup is purely financial. Having limited funds I've already purchased a fairly economical 6 channel receiver that has just enough channels for everything I need:
1 channel for throttle
2 channels for the ailerons (needed for the crow mixing to work)
1 channel for rudder
1 channel for elevator
1 channel for flaps (using a Y-harness)
________________
6 channels total
Besides one of the fun things about scratch designing something is that you can experiment & do things differently. If it doesn't work then it can be fixed, if it does then we all learn something new.
Old Apr 13, 2012, 07:07 PM
Nodd is offline
Build something.
Nodd's Avatar
Joined Mar 2012
Yeah I totally like your setup. It differs from mine mainly in that my servo covers are structural, as in the servo is mounted to the hatch which is in turn then mounted to the wing. It looks like your setup has the servo mounted directly to the wing which is probably a better solution. The main reason I chose my method is that I couldn't see an easy way to get at the mounting screws if I installed them traditionally. You seem to have solved that issue with those nifty plastic doohickeys that somehow have the mounting screws facing vertically instead of horizontally. Cool stuff, would love to see more about their design.
Old Apr 15, 2012, 12:40 AM
Nodd is offline
Build something.
Nodd's Avatar
Joined Mar 2012
SHE'S OFFICIALLY AN RC AIRPLANE!
I spent a couple of hours today adding servo plugs to the spaghetti hanging out of my wing. I hooked up a receiver, ESC, LiPo & the wing & bound it all to my radio. Although far from complete, I think its safe to say this collection of parts can now officially be called an RC airplane. ITS ALIVE! muhahaha
I'm trying to decide what next to tackle. Although I've yet to start on the v-tail, I also need to devise a way to mount the wing to the fuselage. I'm thinking it makes sense to get the wing mounted first. That way I have something to align the v-tail too. I'll post more soon.
Old Apr 15, 2012, 04:33 AM
Sunfire is offline
Find More Posts by Sunfire
Sunfire's Avatar
Joined Jul 2007
nice! pictures please
Sunfire is offline Find More Posts by Sunfire
Old Apr 16, 2012, 01:14 PM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
subbed!
want plans
Keenan smith is offline Find More Posts by Keenan smith
Discussion Scratch-built 28" FFF Tiger Moth biplane (first scratch build) mclarkson Foamies (Scratchbuilt) 20 Apr 04, 2012 03:39 PM
Build Log Designing for scratch-built FPV wing... PiperCub49 Flying Wings 15 Mar 09, 2012 10:15 PM
Build Log Scratch built own design foamie... "Whiplash" glydr Australia 30 Jul 09, 2006 06:28 AM
Question Scratch built design? Perseus Large Scale Cars 2 Dec 11, 2005 06:02 PM
How do you design your scratch built jets? Florin777 Electric Ducted Fan Jet Talk 17 Mar 18, 2003 06:34 PM
