Old May 11, 2012, 03:34 PM
Nodd is offline
Find More Posts by Nodd
Build something.
Nodd's Avatar
United States, CT, Fairfield
Joined Mar 2012
I Need Help with the CG
Okay I'm trying to figure out where my CG needs to be. I've visited half a dozen online CG calculators, plugged in my numbers & of course they don't seem to agree with each other...
Wing Only CG Calculator Results
Calc A: 1.71" back from LE
Calc B: 1.71" back from LE
Calc C: 1.71: back from LE
Wing & Tail CG Calculator Results
Calc D: 4.48" back from LE
Calc E: 3.22: back from LE
Here's the glider's data if you wanted to give this a try...
Wing Root Chord: 9"
Wing Tip Chord: 4"
Wing Sweep: 0
Wing Half Span: 55"
Tail Root Chord: 7.25"
Tail Tip Chord: 3.75"
Tail Sweep: 8"
Tail Half Span: 12"
Distance between Wing LE & Tail LE: 32.5"
Please enter what ever %MAC or Static Margin you feel would be good.
I'd appreciate help with this as I'd like to avoid having an iffy CG for the maiden flight. Thanks.
Nodd is offline Find More Posts by Nodd
Old May 11, 2012, 03:51 PM
plane_tech is online now
Find More Posts by plane_tech
Theoretical balsa dust maker
plane_tech's Avatar
United States, MI, Kalamazoo
Joined Oct 2007
A general rule of thumb that I use is 25%-30% of the wing chord at the root.
plane_tech is online now Find More Posts by plane_tech
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
Put at 3.2inches.. From the LE That's by my calcs seems right and by the chuck glider of my venom...
Keenan smith is offline Find More Posts by Keenan smith
Old May 11, 2012, 03:56 PM
RC Trainer plane is offline
Find More Posts by RC Trainer plane
Balsa builder and balsa basher
RC Trainer plane's Avatar
Joined Apr 2012
I would have thought the CG is about a cm behind the main spar
RC Trainer plane is offline Find More Posts by RC Trainer plane
Old May 11, 2012, 04:10 PM
boingk is offline
Find More Posts by boingk
boingk's Avatar
NSW, Australia
Joined Feb 2011
Originally Posted by Nodd View Post
Yes electronics can have all the programmable features in the world but without a programming manual what's the point? I love HobbyKing but sometimes, well umm, yeah. Anyway thanks once again for the advice. I spoke with our LHS RC guru about your 1 amp per servo rule & how you felt 3 amps wasn't going to cut it for a 100" full house e-glider. All I can say is he raised one eyebrow, Spock style & scoffed at the idea. Still I agree its better to air on the side of caution. More amps than I probably need = one less thing to worry about. Thanks again for the help.
My Blue Series actually came with a manual, go figure! Probably because they're a direct clone of Mysterys product.
No worries on the advice, I've been flying for a year and building for most of it - I know experience is usually earnt the hard way!
Anyway, my thoughts on servos/RX circuits is that all it takes is ONE servo out of the six to load up, jam or jitter and then you could push the circuit over the edge. I've seen this happen on the ground during testing due to a stiff pushrod/sleeve pair and its not fun! Overkill on the current allowance and you'll strip a servo long before you blow the BEC up.
As far as the linear/switch debate goes, switchmode BEC is far superior and yeah you'd most likely get away with 3A. Still, a switch-mode 5A is even better and the weight penalty is marginal.
Cheers mate - boingk
boingk is offline Find More Posts by boingk
Old May 11, 2012, 05:17 PM
Curtis Suter is online now
Find More Posts by Curtis Suter
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
I put your numbers into Sailplane Calc and got 3.68" aft of the root leading edge. This is assuming the model has no trailing edge or leading edge sweep, which I think it does but the numbers weren't given. Sailplane Calc only needs leading edge sweeps and chord changes along the wing and it'll automatically calculate trailing edge sweeps. This would make a big difference. I also didn't know the angle of the V's which of course affects the size of your horizontal stab if you will, so I chose 100 degree angle between the V's.
I've attached the Excel spreadsheet, it's in a .zip file so you'll need to download it then extract it. It works fine with Free Open Office but I used Excel to put it together. The formulas are from Dr. Simons book Model Aircraft Aerodynamics. I've used this spreadsheet for close to 18 years or so and it's proven quite accurate, assuming the proper numbers are input.
If will give you a good balance point to start a safe first test flight. Once you have your trims and flight controls sorted then you can perform the dive test to fine tune your balance point further aft.
Instructions are on the "Articles/Files" page at www.TailwindGliders.com
Curtis
PS Don't use the numbers given till the wing chords/sweeps and V-Tail angles are confirmed!
Curtis Suter is online now Find More Posts by Curtis Suter
Old May 11, 2012, 07:13 PM
Nodd is offline
Build something.
Nodd's Avatar
Joined Mar 2012
Thanks everyone for the CG help. Combined with advice from my mirror build threads it seems most folks are recommending a CG of around 3¼" back from the LE. That looks right to me & apparently the numbers back it up. I added a little over an ounce of lead to the tail & she's now sitting pretty on my CG stand.
The total flying weight came out to 54 oz. That gives me a wing loading somewhere in the middle for a thermal duration ship. I'm quite happy with that, was afraid I'd built a flying brick but I guess not. Here's the numbers...
Wing Loading
11.05 oz/sq.ft
4.96 oz/cubic.ft
I want to give out a HUGE THANKS to everyone who's contributed to this build. Couldn't have done it without you. Maiden flight this weekend!
Old May 11, 2012, 07:20 PM
Joined Dec 2010
When do you predict your maiden to be?
BTW what do ya think of my venom So Far...
Old May 11, 2012, 07:43 PM
Nodd is offline
Build something.
Nodd's Avatar
Joined Mar 2012
Like I said, maiden this weekend.
I'd be happy to discuss your build on your build's thread, not here.
Old May 11, 2012, 07:45 PM
Joined Dec 2010
Ok ... ill be Waiting to See the maiden..
Sorry Me being Random...
Keenan
Old May 12, 2012, 01:50 AM
Joined Apr 2012
Waiting for the maiden
Old May 12, 2012, 09:46 AM
scallopking is offline
Find More Posts by scallopking
Joined Nov 2011
Nodd Thanks everyone for the CG help. Combined with advice from my mirror build threads it seems most folks are recommending a CG of around 3¼" back from the LE. That looks right to me & apparently the numbers back it up. I added a little over an ounce of lead to the tail & she's now sitting pretty on my CG stand.
Wing Loading
11.05 oz/sq.ft
4.96 oz/cubic.ft
Nodd I have been watching your build. Very good Sir. Thank you for the all up weight, I have been wanting to run the numbers. I was a little worried that your construction was on the beefy side.
I ran you numbers and have calculated that, yours and mine are very close with one addition. You should have a stall speed of +/- 19mph. A nice slow floater.
I would say that you should have the CG spot on. In my experience CG ends up being between 3" and 3" 1/2 right handy of the main spar. Nose heavy = front of spar and tail heavy = backside of the spar.
Before the maiden I like to test the CG. If your an athlete try running and lobbing the plane in the air catching it to see which way it wants to pitch or you can give a toss from knee height.
I hope you take video of the maiden. Maiden videos are always the favorite out of any other flight video except for well, um, maybe, nah I'm not going to be the one to say it. Best of luck.
scallopking is offline Find More Posts by scallopking
Old May 12, 2012, 10:14 AM
MAT1978 is offline
Find More Posts by MAT1978
Portugal, Faro District, Almancil
Joined Feb 2008
Absolutely brilliant design there . PLEASE PLEASE PLEASE can you send me some kind of plan for this stunning plane? Been searching for a gull winged boom and pod vtail for ages and its impossible to find one. Already got all my materials just need a design lol. Keep up the good work
MAT1978 is offline Find More Posts by MAT1978
Old May 12, 2012, 10:42 PM
Nodd is offline
Build something.
Nodd's Avatar
Joined Mar 2012
Maiden Flight Video
Well you've all been requesting this so here it is. Enjoy...
Nodd RC - 009 - Sailplane Maiden Flight (6 min 55 sec)
Old May 12, 2012, 11:18 PM
plane_tech's Avatar
Joined Oct 2007
Nicely done!
Discussion Scratch-built 28" FFF Tiger Moth biplane (first scratch build) mclarkson Foamies (Scratchbuilt) 20 Apr 04, 2012 02:39 PM
Build Log Designing for scratch-built FPV wing... PiperCub49 Flying Wings 15 Mar 09, 2012 09:15 PM
Build Log Scratch built own design foamie... "Whiplash" glydr Australia 30 Jul 09, 2006 05:28 AM
Question Scratch built design? Perseus Large Scale Cars 2 Dec 11, 2005 05:02 PM
How do you design your scratch built jets? Florin777 Electric Ducted Fan Jet Talk 17 Mar 18, 2003 05:34 PM
