Old Mar 31, 2012, 04:44 PM
Madison, MS
Joined Oct 2006
Hobby Lobby Lynx Speed Contest!!!! CONTINUED NEW Current top speed is 139.6 mph!
Previous thread,
http://www.rcgroups.com/forums/showthread.php?t=727016
Here's the current speed record pass. 139.6 mph by Tumbler.
http://www.rcgroups.com/forums/showt...09#post8482432
Power setup;
Don's Wicked 2700kv motor
APC 4.1x4.1 prop
Phoenix 35 controller
3 hs 55 servos
Thunderpower 4s 2200 extreme v2
And I think the wing was clipped to 23in.
dpowellmeii is offline Find More Posts by dpowellmeii
Old Mar 31, 2012, 04:45 PM
Madison, MS
Joined Oct 2006
I dug out an old Lynx jet the other day and slapped some stuff I had lying around in it and I'm getting a consistent 105mph level flight and unlimited vertical with an align 430L 3550kv with a 4.1x4.1 on 4s. Now I just need more speed.
Old Mar 31, 2012, 05:02 PM
Madison, MS
Joined Oct 2006
Just purchased Don's wicked 3000kv, we'll see how that works out.
Old May 15, 2012, 01:41 AM
Madison, MS
Joined Oct 2006
Finally getting around to posting some performance numbers.
Little Screamers Super Parkjet 1845kv APC 6 x 4 prop
- 18oz thrust 3s 17amps 205watts
- 27oz thrust 4s 24amps 350watts
Unlimited vertical with this setup, was lite and had long flight times but really couldn't get it to break 90mph level. It's a great park flyer on this setup as it would land really slow and I even flew it on some 2s packs.
Align 430L 3550kv APC 4.1 x 4.1 prop
- 19.8oz static thrust 3s 30amps 315 watts
- 28oz static thrust 4s 42amps 600watts
- 34oz static thrust 5s 52amps 890watts, never flew it on this setup cause I nearly smoked it on the bench.
Consistent 105mph passes on 4s with this motor with roughly 5min flight times managing the throttle on a 1300mah 4s nano-tech.
Don's Wicked 3000kv (actually 3200kv according to my meter) APC 4.1 x 4.1 prop
- 24oz static thrust 3s
- 31oz static thrust 4s 40amps 570watts 37,000rpms
Consistent 110mph passes with this motor on 4s with barely a 3min flight time managing the throttle on a 1300mah 4s nano-tech.
Old May 15, 2012, 04:30 PM
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia / UK visits
Joined Jan 2010
Isn't the Lynx the machine that Don's himself has exceeded way over the 139.6 quoted above ? He even has a video I believe on site ?
solentlife is offline Find More Posts by solentlife
Old May 15, 2012, 04:51 PM
Madison, MS
Joined Oct 2006
Na Don's was doing 120mph. The speed stated above is the current record.
Old May 19, 2012, 08:08 AM
solentlife's Avatar
Latvia / UK visits
Joined Jan 2010
Ok so only a whisker over my 138mph on my Parkjet .... .... which once I get home again in 2-3 weeks time will be smashed by my upgrade ............
Old May 21, 2012, 11:52 AM
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
A few years back I was on the speed craze with this bird. There is speed to be gained by thinning the wings and tails. That being said..... there is a fine line between thin and too thin. I was on a record setting pass and it blew apart in mid air. Evidence that on that one..... I went a bit too thin. It *should* have been over a 140mph pass. 3200 KV inrunner on 4s. 550 watts and I can tell you..... don't blink or breath as a wingspan this small becomes a blur.
Joe 1320 is offline Find More Posts by Joe 1320
For Sale Hobby Lobby Lynx-XF fly103-rcu Aircraft - Electric - Jets (FS/W) 9 Jun 23, 2012 03:44 PM
Contest *** Pizza Box Flyer - Speed Contest *top speed 75 mph* Contest ends Sept 30 2012 leadfeather Foamies (Scratchbuilt) 320 Jun 06, 2012 10:03 PM
For Sale Lynx by Hobby Lobby JoeR Aircraft - Electric - Airplanes (FS/W) 0 Mar 16, 2012 08:16 PM
Contest Hobby Lobby Lynx Speed Contest!!!! NEW Current top speed is 139.6 mph! The Don Pusher Prop Jet Models 1330 Mar 20, 2010 02:20 PM
