Old Mar 31, 2012, 02:01 PM
stratocu is offline
Find More Posts by stratocu
How much castor should I add??
I have 4 gal of Morgan Cool Power(green). It's totally synthetic so I'm wondering what amount of the Sig castor should I add per gallon??
stratocu is offline Find More Posts by stratocu
Old Mar 31, 2012, 02:15 PM
stratocu is offline
I should add that my engines are: Saito 82,115 OS 55,95AX GMS 76 Tower 75,46
Old Mar 31, 2012, 09:41 PM
706jim is offline
Find More Posts by 706jim
2-3oz/gallon
706jim is offline Find More Posts by 706jim
Old Apr 01, 2012, 07:48 AM
Chip01 is offline
Find More Posts by Chip01
United States, TX, Weatherford
Joined Dec 2006
Roger that. It does not take much. Saito used to recommend at least 20% total lubrication (or oil) in the fuel. GMS and Tower are essentially the same engine. All engines IMHO can use a little Castor in the mix. I even add it to my weed eater fuel and it runs like a champion.
Chip01 is offline Find More Posts by Chip01
Old Apr 01, 2012, 06:56 PM
H&H is offline
H&H
Find More Posts by H&H
H&H
H&H Hobbies
H&H's Avatar
Old mystic CT U.S.A.
Joined Nov 2003
A little castor goes a long way. Just enough to protect from a lean run is what I prefer. I have had fine luck with 100% synthetic in my four strokes but My teacher (my Dad) is old school and always taught me to have a little castor in the blend. That advice has always served me well.
H&H is offline Find More Posts by H&H
Old Apr 03, 2012, 01:14 AM
jeffie8696 is offline
Find More Posts by jeffie8696
TEAM BOCA
jeffie8696's Avatar
United States, IA, Muscatine
Joined Oct 2009
I think Cool Power is only about 16% oil so adding 4oz would bring it up around 18% last time I checked.
jeffie8696 is offline Find More Posts by jeffie8696
Old Apr 03, 2012, 03:32 PM
RCFVR is offline
Find More Posts by RCFVR
Keller, TX
Joined Aug 2005
Originally Posted by jeffie8696 View Post
I think Cool Power is only about 16% oil .
Why do you think that?
RCFVR is offline Find More Posts by RCFVR
Old Apr 03, 2012, 06:47 PM
buzzard bait is offline
Find More Posts by buzzard bait
United States, NY, Ithaca
Joined Sep 2007
I remember Cooper Fuels did some testing years ago and concluded that about 2 -3 % castor helped 4 strokes without causing carbon formation, so that agrees with the other advise you're getting, that 3 ounces per gallon or so would do it.
Jim
buzzard bait is offline Find More Posts by buzzard bait
Old Apr 03, 2012, 07:12 PM
NACA0012 is offline
Find More Posts by NACA0012
Joined Mar 2012
The oil content of Cool Power depends on the particular mix. There's one heli mix that's as much as 22%.
NACA0012 is offline Find More Posts by NACA0012
Old Apr 03, 2012, 07:16 PM
pathfinder is offline
Find More Posts by pathfinder
Mach 1
pathfinder's Avatar
walterboro s.c.u.s.a
Joined Jun 2004
Most hobby shops carry coolpower that has a 17% syn. oil content.Around here anyway.
pathfinder is offline Find More Posts by pathfinder
Old Apr 04, 2012, 10:25 AM
TEAM BOCA
jeffie8696's Avatar
Joined Oct 2009
From Morgans site , it states Cool Power 15% has 17% lube and since Morgans is blended by percentage of weight it comes out to about 16% versus SIG which is blended by percentage of volume at 18%.
Old Apr 07, 2012, 04:48 AM
gerryndennis is online now
Find More Posts by gerryndennis
gerryndennis's Avatar
New Zealand, Canterbury, Christchurch
Joined Jun 2008
G'day jeffie,
Assuming that Morgan's does mix by weight, how do you know that the weight of the oil is 17%? Is it possible that Morgan's measure by weight but use whatever percentage of weight is required to give the same amount of oil that 17% by volume would be.
I'll do this bit in metric to make it a bit easier to understand but the argument is the same in gallons.
If I was mixing a liter of 17% oil fuel I would take 170 mls of oil and add 830 mls of methanol. 170 out of 1000 equals 17% by volume.
Now if I weighed 170 mls of oil and weighed 830 mls of methanol and then put that weight of oil and that weight of methanol in a container I would still have exactly the same thing. 17% oil by volume. This may be a much easier way to make commercial quantities of fuel so even though I was mixing by weight my product would still have 17% of the volume of the fuel being oil.
There was another fuel manufacturer that was accused of ripping people off with nitro amounts because they measured by weight, but what if the weight they used was the correct one to give the equivalent volume of nitro. No one ever answered that question.
Dave H
gerryndennis is online now Find More Posts by gerryndennis
Old Apr 08, 2012, 06:38 AM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
Exactly, a lot of commercial mixing is done by weight, corrected for density, as it is easier to measure accurately.
Pinecone is offline Find More Posts by Pinecone
Old Apr 08, 2012, 02:06 PM
Jim Thomerson is offline
Find More Posts by Jim Thomerson
Are you sure they correct for density, given that the expensive parts, nitro and oil are both denser than methanol?
Jim Thomerson is offline Find More Posts by Jim Thomerson
Old Apr 08, 2012, 03:37 PM
mudcan is offline
Find More Posts by mudcan
Joined Apr 2011
oil
over at coxengines.ca is a downloadable spreadsheet for use in adding castor oil to any fuel. worth a look.
mudcan is offline Find More Posts by mudcan
Discussion How much should I charge my 11.1V battery? justin144 Batteries and Chargers 23 Feb 05, 2014 04:18 PM
Help! How much should I offset the engine mount mchandrayan The Builders Workshop 16 May 18, 2012 12:38 PM
Discussion how much should a properly trimmed/balanced GWS Corsair climb at full throttle? robster94gt Parkflyers 12 Sep 24, 2011 10:47 AM
Discussion How Much Should Government Do? How Much Is Too Much? How Much Debt? LcJ Life, The Universe, and Politics 80 Jul 28, 2011 07:43 PM
Question How Much Castor to Add WildWings Engines 4 Sep 21, 2009 08:27 PM
