Old Mar 31, 2012, 10:57 AM
captdave221 is offline
Find More Posts by captdave221
220 221 Whatever it takes
captdave221's Avatar
USA, IL, Belleville
Joined Dec 2009
Help!
E-Flite 10 AMP ESC Problems
I have 2 of the E-Flite 10 amp ESC's and neither will work properly with a Scorpion, E-Flite 300, E-Flite 280 motors. I don't have any other motors to try them on but I think it is not a motor issue. I called HH on this as I was trying to get a HH Grasshopper L4 flying and they sent me a new ESC 1st then a new E-Flite 280 motor next. The motors will work with other 10A ESC's from various MFG's. What is the deal? Guess I'll send them both back in and see what then say. Anyone else had this issue?
captdave221 is offline Find More Posts by captdave221
Old Feb 07, 2013, 10:14 PM
dabears720 is offline
Find More Posts by dabears720
dabears720's Avatar
United States, TX, Plano
Joined Jul 2011
I'm trying to get the Cessna 150 flying and am having the same problems with the E-Flite 280 motor and E-Flite 10amp Pro Esc. The motor oscillates violently at start up and vibrates the whole plane a lot past mid stick. To make matters worse the esc runs the motor quite fast when the TX is shut off. I sent the setup to Horizon and just got it back tonight saying there was no problems. I even said in the note that the esc runs with no signal and they still said it was okay. Arahgrah frustrating, I will call them tommorow and see what they say. I may switch to a castle 10amp esc.
dabears720 is offline Find More Posts by dabears720
Old Feb 08, 2013, 02:33 PM
cryhavoc38 is offline
Find More Posts by cryhavoc38
Why didn't they run? A pass???
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
Never shut off the tx before you unplug the battery to the plane/rx
The vibration issue is a bad prop or that its not mounted perfectly center.
cryhavoc38 is offline Find More Posts by cryhavoc38
Old Feb 08, 2013, 03:00 PM
dabears720's Avatar
Joined Jul 2011
I obviously know that, I was testing the ESC. Now I know that if my DX6i loses signal with the plane, the motor will keep running resulting in probable damage to aircraft and property. That is the exact OPPOSITE of the what the E-Flite ESC instructions say will happen. There is supposed to be automatic cutoff is signal is lost, and there is not.
Prop came balanced and there is no way to mount it other than perfectly center, unless you are talking about the spinner. I can assure you that it is seated properly.
Old Feb 08, 2013, 03:30 PM
dabears720's Avatar
Joined Jul 2011
Been playing with it and fixed the esc by rebinding the rx.
Old Feb 08, 2013, 04:41 PM
cryhavoc38's Avatar
Joined Mar 2007
ok, well a prop/motor will only vibrate alot if the shaft is bent, the prop is out of balance or the spinner is wonky.
You can check all three things by first, running the motor for a short burst without the prop installed. if its all smooth and the shaft is nice and straight, then mount the prop and test again.
If you get alot of vibration and your tracking is good (prop tips look even and are tracking along the same line when viewed edgewise), then one side of the prop is much heavier than the other. If all is smooth, then check again with the spinner mounted.
Just so you know, props rarely ever come balanced. Even the ones that state they were pre balanced
trust me.
Also, alot of nylon props are not perfectly drilled in the center. Most come with "precision rings" that you have to install to make the proper fit onto the shaft. Sometimes you will have to tap the pre drilled hole to make it bigger and then use one of the supplied "precision rings"
Old Feb 08, 2013, 07:51 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Maybe it is the photo, but I don't like the alignment of spinner hub and motor shaft.. is the spinner hub/adapter drilled true?
Dr Kiwi is offline Find More Posts by Dr Kiwi
Sold E-flite power 10, 40 amp switch esc copperbricks Aircraft - Electric - Power Systems (FS/W) 0 Dec 11, 2011 05:53 PM
Sold E-Flite Power 60 - Castle Creations Phoenix 80 ESC - Castle Creations 10 amp BEC moxjett Aircraft - Electric - Power Systems (FS/W) 6 Oct 18, 2011 08:49 PM
For Sale E-Flite 10-amp pro Brushles ESC & NEO 250 2200kv Outrunner motor w/prop PRICE REDUCED trobinson3003 Aircraft - Electric - Power Systems (FS/W) 7 Oct 04, 2011 09:56 AM
Sold E-flite 60amp esc and castle creations 10 amp bec SmokingFlite Aircraft - Electric - Power Systems (FS/W) 2 Sep 27, 2011 05:51 PM
Wanted WTT E-flite Power 10 and 40 amp E-flite ESC for Helicopter Sympster Aircraft - Electric - Helis (FS/W) 1 Feb 07, 2007 09:48 AM
