Old Mar 31, 2012, 10:36 AM
stormheli is offline
Find More Posts by stormheli
Closed Account
Joined Mar 2012
450 trex clone throttle/rudder question
i have a storm 430 which is a trex 450se v2 copy. on the left stick if i move it left or right it does not come back to center like it should.i hae to move the stick each time to get it to be center.i know this can't be right. anyone know how to fix this??????????
stormheli is offline Find More Posts by stormheli
Old Mar 31, 2012, 12:19 PM
Libtekguy is offline
Find More Posts by Libtekguy
Essayons
Libtekguy's Avatar
United States, CA, Sacramento
Joined May 2011
This is based on what mode your gyro is in. Sounds like it is in Heading Hold mode (which is should be). Heading hold means that the gyro will try to hold the heading it was last put at. On the ground, if you give it left rudder input, it will continue giving left rudder input even after you let off the sticks until it gets to the orientation that it was told to.
Having your gyro in Rate Mode would make the rudder go back to neutral after rudder inputs. You can fly a heli in this mode, but it will be a bit more difficult because your tail will drift a bit.
Libtekguy is offline Find More Posts by Libtekguy
Discussion 450 clone, more left rudder than right GuitsBoy Electric Heli Talk 32 Apr 11, 2012 10:23 PM
Help! Trex 450 pro 3gx rudder control problem. ian145 Mini Helis 2 Mar 18, 2012 12:28 PM
Discussion Trex 450 Pro clone parts question ScotY Mini Helis 15 Jul 11, 2011 05:50 PM
Question Newbie question on TREX 450 clone xahhax Mini Helis 3 Jan 09, 2008 04:39 PM
