Old Mar 31, 2012, 07:22 AM
SebastianJ is offline
Find More Posts by SebastianJ
Droner
SebastianJ's Avatar
Denmark, Capital Region of Denmark, CPH
Joined Mar 2006
Build Log
MiniWii NanoQuad V2
Some of you might have seen the NanoQuad v1 in the MiniWii thread.
Pre-assembly
I never did the build log I intended, I also never did more than one vid:
NanoQuad MiniWii (0 min 47 sec)
I got it flying a bit better since then, but not much, the MiniWii and the SuperMicro ESC's doesn't play well together in a single cell setup, even if they did I still want more power.
Enter 2 cell NanoQuad.
Specs:
Frame - G10 2mm
Small screws - HK-250GT screw pack
Nylon screws - M3 x 16mm
Rubber grommets - 3mm ID
Controller - MiniWii
Motors - AP03 4000kv
Props - GWS style 3x2
ESC's - Aeolian XP-7A
RX - Deltang RX32 or Spektrum satellite
Battery - 350mAh 2S 35C
Targeted AUW - around 65gr.
Targeted thrust - more than 200gr.
More to come.
Sebastian
SebastianJ is offline Find More Posts by SebastianJ
Old Mar 31, 2012, 07:24 AM
Droner
SebastianJ's Avatar
Joined Mar 2006
Assembly.
I'd like the Nano to look clean, so I'll be hiding as much stuff as I can under the FC.
I managed to mess up the RX part as I tried to get PPM stream from ch1 when in fact it's from ch3, easy fixed though.
Note to myself: Read the manual dumbass!
ESC's mounted and wired, I decided to use magnet wire instead of the stock bulky stuff, I initially planned to mount the ESC's under the arms to obscure the frame as little as possible, but since the ESC's are the same nice red color as the MiniWii I decided to try them on top, comments?
Now comes the part where I usually let the magic smoke out - The first power up!
A quick runthrough with the multimeter showed all in order.
Power - Check, success, no smoke!
RX - Check.
Bluetooth - Check.
Next up: Motors.
Stay tuned.....
Old Mar 31, 2012, 07:25 AM
Droner
SebastianJ's Avatar
Joined Mar 2006
Tuning.
Old Mar 31, 2012, 07:26 AM
Droner
SebastianJ's Avatar
Joined Mar 2006
First outside flight, other than that nothing new, not enough hours in a day so no time for play.
This is rate mode only, flies fantastic, rock solid and heaps of power, still flies like crap in level mode though, I need to mess with the low pass filter etc.
Here's my buddy giving it a careful spin in the open, it's a squirrely little bugger.
NanoQuad V2 outside flight (0 min 51 sec)
Droner
SebastianJ's Avatar
Joined Mar 2006
Whatever.
Old Mar 31, 2012, 07:34 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
Yanno, afro32 probably runs off 1S and at 72mhz just sayin'.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Mar 31, 2012, 07:38 AM
Droner
SebastianJ's Avatar
Joined Mar 2006
Does it now?
Your stuff has never let me down so far, I can see an afro32 in my stable in a not so distant future.
Old Mar 31, 2012, 07:43 AM
timecop is offline
Joined Dec 2010
Well, the processor runs at 3.3V and so do all the sensors, I just powered it off a 3.3V source and it still runs, even dropping below 3V seems to be OK, so yeah, I'd say it's safe for 1S. CopterControl is known to run off 1S, and this is same STM32 CPU.
Old Mar 31, 2012, 07:46 AM
Droner
SebastianJ's Avatar
Joined Mar 2006
Need a tester?
Old Mar 31, 2012, 07:49 AM
scousethief is offline
Find More Posts by scousethief
United Kingdom, England, Redcar
Joined Jan 2006
Very nice indeed
scousethief is offline Find More Posts by scousethief
Old Apr 01, 2012, 01:55 PM
ddoltar is offline
Find More Posts by ddoltar
ddoltar's Avatar
United States, CA, San Bernardino
Joined Feb 2012
very cool build. nice job
ddoltar is offline Find More Posts by ddoltar
Old Apr 01, 2012, 01:59 PM
Doblao is offline
Find More Posts by Doblao
Spain
Joined Jan 2010
hmmmm
Cool...just missing the foldable part like first version...too much weight?
Saludos,
Jose
Doblao is offline Find More Posts by Doblao
Old Apr 01, 2012, 02:38 PM
Droner
SebastianJ's Avatar
Joined Mar 2006
Saludos,
Jose
Thanks Jose,
Nah! - Same weight, foldable is a cool trick, but more or less useless in this size.
V2.1 perhaps?
Old Apr 06, 2012, 10:29 AM
Droner
SebastianJ's Avatar
Joined Mar 2006
Updated - Post #1 and #2
More soon
Sebastian
Discussion Benefits of buying FlySky TH9x (v2) over Turnigy 9x (v2) wwfisher Radios 110 Apr 19, 2015 04:13 PM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 09:54 AM
Sold MiniWii MWC Board FS Derek_S Aircraft - Electric - Multirotor (FS/W) 3 Jan 19, 2012 06:03 PM
For Sale 2 ArducCopterMega setups, kk boards(HK+ Red), miniwii's TGY 9X ezmobius Aircraft - Electric - Multirotor (FS/W) 24 Jan 14, 2012 01:25 AM
Build Log MultiWii NanoQuad and NanoHex ben123 Multirotor Talk 32 Nov 30, 2011 03:46 PM
