Old Mar 31, 2012, 05:28 AM
georgy is offline
Find More Posts by georgy
Allways the hard way!
georgy's Avatar
South Africa, GP, Germiston
Joined Jan 2012
Idea
F104 Starfighter slot-jet
Lousy flying weather here... so i'm forced to think up more "impossible" problems for myself!
I have been looking for an idea for my next slot jet, & keep coming back to this bird... F104 Starfighter.
My idea so far is similar to the Mig15 i built: using hi Kv motor & small prop to allow running the prop inside the fuse hight & bracing top/bottom to restore fuse stiffness.
Dimentions so for looks like O/L=1260mm & +-590 W/S. Fuse hight at prop is 115mm which allow sqeezing in a 4.1" apc prop, with only millimeters to spare for the bamboo skewer braces.
Planned power is 3550Kv 450 heli motor & 40amp esc running of a 3c lipo. Basically double the power of the Mig. a F104 is never gonna be a floater, so might as well make it haul!! (H/King claim 500watt on this set-up... but we'll just have to see about that?? previous 200w motor boils at 170w!!)
Planning to split the horisontal fuse-&-wing bit to allow the characteristic F104 anhidaral. Not too sure about the inherent stability/in-stability of this type of wing?
Any comments on that??
Also planning a KFm4 or 2 wing. Missile-with-a-man-in-it was never famous for low speed stability so i recon the more efficient wing might be a good idea...
Any help or "what-were-you-thinking!" comments will be welcome before i cut...
George
georgy is offline Find More Posts by georgy
Old Mar 31, 2012, 09:25 AM
ksqm is online now
Find More Posts by ksqm
United States, VA, Hampton
Joined Mar 2009
Georgy,
A profile mid motor F-104 is possible. In fact, someone's beat you to it already. Can't remember who, but I have a set of plans on my computer. Unfortunately, I'm on my IPhone. I'll post plans later.
Ksqm
ksqm is online now Find More Posts by ksqm
Old Mar 31, 2012, 09:31 AM
ksqm is online now
Joined Mar 2009
Georgy,
Search on Eliworm in the ScratchBuilt forum. Eliworm posted plans.
Ksqm
Old Mar 31, 2012, 09:40 AM
georgy is offline
georgy's Avatar
Joined Jan 2012
Hi ksqm,
Thanx for the info. Will definately look it up. This bird is probably beyond my current piloting skills but will try anyway... The Starfighter is a very famous airy, so if some-one hadn't tried before i would have been gob-smacked. Been looking at an edf 104, but will try profile 1st...
George
Old Apr 02, 2012, 05:43 PM
rcflyer50 is offline
Find More Posts by rcflyer50
USA, Massachusetts
rcflyer50's Avatar
Joined Dec 2005
There a few, here are some, hope it helps:[url]http://www.rcgroups.com/forums/showthread.php?t=956580........
http://www.rcgroups.com/forums/showthread.php?t=703971
This is my F104
rcflyer50 is offline Find More Posts by rcflyer50
Old Apr 03, 2012, 11:31 AM
georgy is offline
georgy's Avatar
Joined Jan 2012
Hi Rcflyer50,
Thanx for the info... how does she fly? Handfull?
Had a look at the Eliworm thread, & if those experianced pilots prangs a plane cos' its a handfull, maybe i should give it a miss for now
(yellow belly chicken... LoL)
Old Feb 22, 2014, 08:52 PM
matrix48d is offline
Find More Posts by matrix48d
Joined Oct 2010
I have done it requires micro bearings K&S Al tubing some work and parts...Carbon 3mm shaft etc.
matrix48d is offline Find More Posts by matrix48d
Build Log MIG-15 Slot-jet georgy Pusher Prop Jet Models 9 Apr 01, 2012 11:28 AM
Question 1st Prop-in-Slot Jet georgy Pusher Prop Jet Models 13 Mar 13, 2012 08:38 PM
Discussion Good slot-jet candidate: Definition georgy Pusher Prop Jet Models 0 Mar 12, 2012 01:48 PM
Discussion Prop in a slot jet motor question Captain Bravo Power Systems 8 Jan 06, 2010 01:27 PM
Discussion Plan for "Prop in a slot" profile Epp jet model ? dekan Pusher Prop Jet Models 0 Jul 11, 2007 01:36 PM
