Old Mar 30, 2012, 11:28 PM
brightfan is offline
Find More Posts by brightfan
Joined Mar 2012
Cannot get 12v DC output from Delta DPS-700EB
Just got a retired Delta DPS-700EB.
After some search in the forum, I've gotten the full pinout from this post: http://www.rcgroups.com/forums/showp...&postcount=844
I connected (actually soldered) pson, pskill and ground, which brought up the power supply (apparently it made some noise). However, I measured the +12V pin with ground and got a 0 read. I am sure my digital multimeter works fine since I can get a 5v read between 5VSB and ground.
BTW, there is a led right aside the power cord socket and it's orange (should be green?).
Is there any modification I missed?
Thanks you very much
brightfan is offline Find More Posts by brightfan
Old Mar 30, 2012, 11:44 PM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
lots of info
http://www.rcgroups.com/forums/showthread.php?t=1292514
rick.benjamin is offline Find More Posts by rick.benjamin
Old Mar 31, 2012, 10:40 AM
Joined Mar 2012
Thanks Rick. I actually found the page in my post from the link you mentioned. It does have lots of info but it doesn't solve my problem. Thanks for replying.
My problem is: after I powered up the DPS-700EB (by connecting pson, pskill and ground), I don't get a voltage between +12V pin and ground. I don't think OVP or OCP has anything to do with this since there is no load in the circuit yet. And I need to mention the only led on the back of the power supply is orange.
Any comment will be helpful.
Thanks!!
Old Mar 31, 2012, 10:45 AM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
If you're absolutely certain that you've properly connected the appropriate pins, then you've likely received a bum supply. Buzz out all connections and make sure that there are no inadvertent solder splashes and such that may have pulled down a wrong pin.
Uncertain whether +5VSB is live when A/C is present regardless of PS enable but will do some checking. No doubt Xandrios knows this straightaway.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Mar 31, 2012, 11:08 PM
xandrios is offline
Find More Posts by xandrios
Steven
xandrios's Avatar
United States, CT, East Hartford
Joined May 2010
Hello brightfan.
In a few instances you may get an OVP fault .
If so, then also connect the 12VS (pin 63) to the +12V
and connect the 12VS return(pin 8) to Ground.
This may be needed if the internal voltage is set to high.
xandrios is offline Find More Posts by xandrios
Old Apr 01, 2012, 12:06 AM
Joined Mar 2012
Thanks for pointing me to xandrios, Mark. The problem is solved now.
As xandrios said, a potentiometer inside the power supply was setting a high voltage which caused an OVP fault. After I turned it clockwise a little bit, the led turned from orange to green and I finally got the output voltage.
Thanks a lot for the advice, xandrios
Originally Posted by xandrios
You could also turn the voltage down internally for your DPS-700EB .
Potentiometer #5 adjusts voltage. Clockwise to decrease output voltage.
Question how to step up 11.1V 3 cell lipo DC to 12V DC for my FPV monitor? TheSelf FPV Talk 17 Sep 09, 2015 10:28 AM
Discussion DIY RC LEDs Vector Kite lanternfly RC Paragliders and Kites 15 May 08, 2012 04:31 PM
Sold Great Planes PolyCharge4 DC 4 Output LiPo Charger 3D4ever Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 13, 2012 05:58 PM
Discussion Delta DPS-460CB C Power Supply db_sonic Batteries and Chargers 0 Oct 21, 2011 03:11 PM
Where to get a good 12V AC to DC Power Supply TopGun Power Systems 13 Apr 10, 2002 11:43 AM
