Old Mar 30, 2012, 05:54 PM
Paulbilbo91z9f is online now
Find More Posts by Paulbilbo91z9f
Fly It Like You Stole It !!
Paulbilbo91z9f's Avatar
United States, MA, Pittsfield
Joined Sep 2011
Bird of Time ARF Center Section
Hi Guys, I just bought a used Bird Of Time ARF that someone had tried to convert to electric. I finished the E-covert, installed spoilers and test flew it tonight for the first time.
My question is: On my third landing I dropped a wingtip and spun it in. Nothing bad. It was going very slow. It landed right side up on soft grass. Didn't even mark the wingtip. When I took the wing off the fuse there was a rip/crack in the white Mono-cote at the Center section of the wing. I know I've read here that some of the BOT's wing roots were weak. Is there any way I can tell if mine is an early version with a weak center section? As I said, I didn't buy it new and have no idea how long this guy had it before I came along.
If so, I'll cut away the covering and stiffen it up. What method have any of you guys used on the BOT's wings to do this little trick?
Thanks for any advice,
Paul M
Paulbilbo91z9f is online now Find More Posts by Paulbilbo91z9f
Old Mar 30, 2012, 10:24 PM
prodjx is online now
Find More Posts by prodjx
prodjx's Avatar
Joined Jan 2007
The BOT arf was known for poor center section strength. I just went and glassed mine.
prodjx is online now Find More Posts by prodjx
Old Mar 31, 2012, 12:20 PM
Joined Sep 2011
Thanks for the input. I think that I'll do the same. Glassing the top & bottom over should stiffen it up. I don't really want to take the chance of folding it up, not after I've done so much work to straighten it out and get it to fly right.
Sold Bird of Time ARF wing rmmoorejr Aircraft - Sailplanes (FS/W) 4 Mar 14, 2012 07:40 AM
Wanted Bird of time ARF center wing section. webdragon Aircraft - Sailplanes (FS/W) 1 Aug 04, 2011 02:51 PM
Wanted Center Section For Bird Of Time bipe22 Aircraft - Sailplanes (FS/W) 4 Sep 29, 2006 05:10 PM
WTB: Built Bird of Time or Bird of Time ARF Superman Aircraft - Sailplanes (FS/W) 1 Jul 14, 2003 04:06 PM
