Old Jul 08, 2012, 04:03 PM
Kloner is offline
Find More Posts by Kloner
Aerial DP
United States, CA, Lakeside
Joined Apr 2010
it works great but adds to another piece to carry around. make sure to get the antenna straight up and down before ya send her off.......
Kloner is offline Find More Posts by Kloner
Old Jul 19, 2012, 12:51 AM
KKUSA is offline
Find More Posts by KKUSA
United States, IN, Indianapolis
Joined Oct 2010
One question I have yet to see is what does it do in a failsafe condition from the input receiver?
Also, shouldnt it be called a "RELAY" , not a repeater?
I have also yet to find any real benefit this has over any of the available PPM sum encoders, or receiver with PPM output.
The chap that had limited range on his FrSky receiver probably had it way too close to the UHF antenna. In that case it would swamp the Rx.
KKUSA is offline Find More Posts by KKUSA
Old Jul 19, 2012, 02:01 AM
Ian Davidson is offline
Find More Posts by Ian Davidson
Old Blighty
Joined Apr 2010
There are some advantages detailed here...
http://www.fpvmanuals.com/2012/05/29...e-com-preview/
Ian Davidson is offline Find More Posts by Ian Davidson
Old Oct 21, 2012, 08:00 AM
bjornthans is online now
Find More Posts by bjornthans
bjornthans's Avatar
Norway, Troms, Skjervoy
Joined Jul 2012
this works really great with my dmss system :-)
bjornthans is online now Find More Posts by bjornthans
Old Nov 09, 2012, 05:03 AM
dhano6 is offline
Find More Posts by dhano6
Slovakia, Bratislava Region, Bratislava
Joined Jul 2010
Has anyone tested it with graupner HOTT system?
dhano6 is offline Find More Posts by dhano6
Old Nov 09, 2012, 06:25 AM
Old Blighty
Joined Apr 2010
It simply accepts a standard PWM servo output, as an input, therefore it's receiver agnostic.
It doesn't matter what receiver(s) you're using - any vendor, any vintage, it will work.
Old Nov 09, 2012, 07:28 AM
dhano6 is offline
Joined Jul 2010
Thank you for your quick response
Old Nov 14, 2012, 06:34 PM
FabioBrazil is offline
Find More Posts by FabioBrazil
Joined Mar 2009
Does it support the 12ch mode on the futaba 8FG trainer port?
FabioBrazil is offline Find More Posts by FabioBrazil
Old Nov 14, 2012, 07:25 PM
Kloner is offline
Aerial DP
Joined Apr 2010
like the last answer, it is pwm, servo leads in. Seems like it did 10 channel if i remember right. if you have a receiver with 10 channels out, it can take that in and make a ppm sum of them to send to a long range transmitter
Old Nov 15, 2012, 06:51 AM
Joined Mar 2009
Hi Kloner, thanks for replying.
I thought one thing and asked other Sorry.
What I want to know is if the output is compatible with DragonLink. More than 8 channels.
Old Nov 15, 2012, 07:21 AM
LKJ is offline
LKJ
Find More Posts by LKJ
LKJ
Lars k Jensen
Denmark, Central Denmark Region, Tostrup
Joined Apr 2006
Yes it is.
Lars.
LKJ is offline Find More Posts by LKJ
Old Nov 15, 2012, 08:19 AM
Kloner is offline
Aerial DP
Joined Apr 2010
from the page you buy it at
The repeatersytem is well tested with Dragonlink & TLRS & EzUHF system
Dragonlink: 12 CH
EzUHF: 8 CH
TLRS: 10 CH
http://fpvlongrange.com/fpv-repeater-system/
Old Nov 16, 2012, 06:37 AM
bjornthans's Avatar
Joined Jul 2012
use it for my 11 ch. 11xzero. works very well with the ranglink system.
Old Dec 25, 2012, 02:02 PM
rclab1 is offline
Find More Posts by rclab1
USA: LakeGeorge, New York
USA
Joined May 2010
any updates on this? still forSale?
Thank You:-)
rclab1 is offline Find More Posts by rclab1
Old Jan 03, 2013, 02:26 PM
Hooks is offline
Find More Posts by Hooks
Hooks's Avatar
Joined Jun 2009
Yep! Still for sale here: FPV repeater
Hooks is offline Find More Posts by Hooks
Yippee! NEW DRAGON LINK ADVANCED: Full Telemetry, Bluetooth, Droid Planner, Data Modem JettPilot FPV Equipment 50072 Today 04:43 AM
Question UHF System Can connect to the 7 Channels Radio System ? RanD222 FPV Talk 7 Nov 15, 2011 10:04 AM
Suggestion Flyinjrc74 repeatedly abusing the feedback system. flyer368 Site Suggestions / Complaints 1 Nov 11, 2011 01:22 PM
Discussion Alternative to expensive UHF system fpvguy FPV Talk 1 Sep 19, 2011 11:32 PM
Discussion How do I switch off 2.4 Ghz system when I only want to use UHF system? Voguna FPV Talk 1 Oct 07, 2010 06:16 AM
