Old Apr 10, 2012, 05:21 AM
dutch jones is offline
Find More Posts by dutch jones
thats Mr dutch to you
Australia, NSW, Jeremadra
Joined Mar 2011
i put down a order for one today, i dont mind being a test subject.
dutch jones is offline Find More Posts by dutch jones
Old Apr 10, 2012, 06:40 AM
Wayno Complaino is online now
Find More Posts by Wayno Complaino
Fixed wings can be Drones too!
Wayno Complaino's Avatar
United Kingdom, England, Milton Keynes
Joined Aug 2011
is it one of these in a metal box? It does look slick though.
I really like the concept and have already planed to implement a control repeater along with a 5.8ghz video repeater from a 1.2ghz ground station to my goggles. This would give a truly wireless, lightweight solution for the pilot (me) but yet having some serious ground station equipment mounted elsewhere (like on top of my van).
Wayno Complaino is online now Find More Posts by Wayno Complaino
Old Apr 10, 2012, 12:56 PM
Hooks is offline
Find More Posts by Hooks
Hooks's Avatar
Joined Jun 2009
NO! but please let mé know if you Can Make this work the same way.
Hooks is offline Find More Posts by Hooks
Old Apr 10, 2012, 01:29 PM
Joined Aug 2011
Oh ok. How are the features different? Apart from the case and wiring? I was under the impression both products takes signal from a standard RX and makes it into a single PPM signal. One just has better casing and better marketing. I was already looking at a PPM converter to do this project based on a thread in FPVLAB before this thread was started.
I honestly mean no offence, i'm just wondering where to spend my money and I don't mind DIY soldering and heat shrinking. I want the best value for money, and if there is more to be had from your product then it's a contender.
Old Apr 10, 2012, 01:50 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
I wish my soldering skills where beyond doing XT60's and basic wiring!
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Apr 11, 2012, 06:16 AM
N485TG is offline
Find More Posts by N485TG
United States, OR, Medford
Joined Nov 2011
Originally Posted by billyd60 View Post
Yeah I was suprised by that statement. I stopped using my gopro for fpv because the lag was irritating and that was only about 1/4 second (estimate)
ok cool, I thought i noticed the lag in it. I was thinking it was from the Video TX/RX guess not thanks.
N485TG is offline Find More Posts by N485TG
Old Apr 11, 2012, 01:26 PM
Ian Davidson is offline
Find More Posts by Ian Davidson
Old Blighty
Joined Apr 2010
Just a quick video showing the unit connected to my DragonLink TX and controlling 2 servos attached to the same UHF RX, but one via a Spektrum DX7 the other a Futaba 8FG.
Spektrum and Futaba buddying up - who would have thought it, eh?
UHF Repeater Demo (0 min 40 sec)
(NB: That's a dummy-load on my DragonLink antenna connector)
Ian Davidson is offline Find More Posts by Ian Davidson
Old Apr 11, 2012, 02:16 PM
crazy1pilot is offline
Find More Posts by crazy1pilot
What goes up, must come down
crazy1pilot's Avatar
United States, MI, Midland
Joined Sep 2009
Running without an antenna on your UHF??? Don't want to burn it out also what was the lag like??
Crazy1
crazy1pilot is offline Find More Posts by crazy1pilot
Old Apr 11, 2012, 02:19 PM
Old Blighty
Joined Apr 2010
Crazy1
I guess you didn't see the bit in brackets underneath the video?
At this stage I would say any lag was barely perceivable, but I'll measure it at the weekend (when I have the equipment) and will report back
Old Apr 11, 2012, 05:26 PM
Joined Sep 2009
Hehe I see it now thanks for the video!
Crazy1
Old Apr 11, 2012, 06:55 PM
Farmer_Joe is offline
Find More Posts by Farmer_Joe
RC Farmer
Farmer_Joe's Avatar
Joined Aug 2011
I have tried this with frsky receiver and PPM out to TSLRS... But i failed, the range of frsky in my case was reduced to 0,5-2m it looked like it doesn't like to be connected directly to LRS.
If i put the same receiver on the LRS with servo connected it worked without problem.
Edit: You allso lose the ability to change the output power in case of emergency.
Farmer_Joe is offline Find More Posts by Farmer_Joe
Old Apr 12, 2012, 10:55 AM
Hooks is offline
Hooks's Avatar
Joined Jun 2009
Can you explane your setup a little better. I guess you are not using the FPVlongrange repeater system?
Old Apr 12, 2012, 01:36 PM
RC Farmer
Farmer_Joe's Avatar
Joined Aug 2011
No, but all frsky receivers have combine PPM out... i feed this in TSLRS transmitter. Everything works but range on frsky in drastically reduced.
Old Apr 17, 2012, 06:10 AM
Joined Mar 2011
when do you expect to send your first batch guys?
i cant wait to get into the air with my uhf gear
Old Apr 17, 2012, 08:27 AM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Seems a bit over-kill in extra bits increasing the chances of equipment failure.
I've used an extended PPM cable from the RangeLink to a mast, and an AV cable from GS to goggles. Easier and probably much cheaper!
Teamsherman is offline Find More Posts by Teamsherman
Yippee! NEW DRAGON LINK ADVANCED: Full Telemetry, Bluetooth, Droid Planner, Data Modem JettPilot FPV Equipment 46033 Today 09:47 AM
Question UHF System Can connect to the 7 Channels Radio System ? RanD222 FPV Talk 7 Nov 15, 2011 11:04 AM
Suggestion Flyinjrc74 repeatedly abusing the feedback system. flyer368 Site Suggestions / Complaints 1 Nov 11, 2011 02:22 PM
Discussion Alternative to expensive UHF system fpvguy FPV Talk 1 Sep 20, 2011 12:32 AM
Discussion How do I switch off 2.4 Ghz system when I only want to use UHF system? Voguna FPV Talk 1 Oct 07, 2010 07:16 AM
