Old Apr 02, 2012, 02:17 PM
Ian Davidson is offline
Find More Posts by Ian Davidson
Old Blighty
Joined Apr 2010
Originally Posted by Hooks View Post
@Ian what UHF system dó you use? How about a Unit for test and review.
Oooh, that sounds nice! I have a Futaba 8FG and DragonLink
I'm the chap who wrote the article below when I had a DX7, but I'm liking this repeater concept very much!
http://www.fpvmanuals.com/2011/03/17...ezuhf-or-tlrs/
Ian Davidson is offline Find More Posts by Ian Davidson
Old Apr 02, 2012, 02:24 PM
Hooks is offline
Find More Posts by Hooks
Hooks's Avatar
Joined Jun 2009
Send mé a PM with your address a Unit Will be shipped tomorrow.
Hooks is offline Find More Posts by Hooks
Old Apr 02, 2012, 08:06 PM
catamar is offline
Find More Posts by catamar
Alicante, España
Joined Jun 2010
I want the 12 channels, but in 2.4 there are not 12 channels. What if I use my 2.4 transmitter Turnigy 9 channels, with the custom firmware that let me transmit 12 channels, so I buy a receptor with a sppm output that I can connect to this : http://www.foxtechfpv.com/rmilec-ppm...ter-p-403.html
And this, to the UHF repeater. So I have the 12 channels from only one transmiter. Am I right?
catamar is offline Find More Posts by catamar
Old Apr 02, 2012, 10:10 PM
TomM is online now
Find More Posts by TomM
Rust: The poor man's Loctite.
TomM's Avatar
State College PA
Joined Jul 2002
Curious how and why this thing is right in the middle of the UHF Ham band.
TomM is online now Find More Posts by TomM
Old Apr 02, 2012, 10:36 PM
John Jensen is offline
Find More Posts by John Jensen
Joined May 2011
Here are just a small video.
FPVlongrange Repeater system (3 min 38 sec)
John Jensen is offline Find More Posts by John Jensen
Old Apr 03, 2012, 01:40 AM
KiwiDavid is offline
Find More Posts by KiwiDavid
Joined Jun 2011
Hi,
433MHz is an ISM band for many countries (as is 868MHz) and is often under strict EIRP levels to comply so that a multitude of short range users can exist in a limited area. Garage door openers, and general keyless entry devices often use this band and with limited power and momentary operation there is little chance of mutual interference but this repeater is full time operation.
Is there a specification for the power output or EIRP with the supplied antenna?
If several users had such a device on the same frequency in the same area is there an increased chance of mutual interference over the original spread spectrum 2.4GHz signal?
Cheers,
David
KiwiDavid is offline Find More Posts by KiwiDavid
Old Apr 03, 2012, 02:21 AM
boopidoo is offline
Find More Posts by boopidoo
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
Is it just me or is it a quite noticeable lag between stick input and servo output? Which brings me to this question, exactly how much latency does this system really add? I noticed Hooks earlier reply that there is lag but it's not noticeable. Well, if it's noticeable or not is highly individual and latency builds up so even a small increase might feel to be much more in the end. There must be able to get a minimum and maximum latency number.
boopidoo is offline Find More Posts by boopidoo
Old Apr 03, 2012, 02:23 AM
FpvKiwi is offline
Find More Posts by FpvKiwi
Up up and away!
FpvKiwi's Avatar
Sweden
Joined Oct 2010
Originally Posted by KiwiDavid View Post
433MHz is an ISM band for many countries ...
The name withstanding, the FPVlongrange UHF repeater does not transmit a radio signal on any frequency so such discussions are off-topic in this thread.
FpvKiwi is offline Find More Posts by FpvKiwi
Old Apr 03, 2012, 02:36 AM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Hi,
Cheers,
David
In the US 70cm band can be used by HAMs (part 97) at higher power levels. (up to 50W PEP except in specific regions near the Canadian border)
Only license free operation (part 15) has extremely low power limits.
ian
Daemon is online now Find More Posts by Daemon
Old Apr 03, 2012, 02:45 AM
Old Blighty
Joined Apr 2010
Watching the unit by itself in that video, there does appear to be noticeable latency, but when viewing the comparison with a simple 2.4 GHz RX set-up (1:24 -> 1:50 in the video) the latency (for most FPV applications) would appear negligible.
Old Apr 03, 2012, 05:13 AM
Hooks is offline
Hooks's Avatar
Joined Jun 2009
Jep! you are right of cause there will be delay when you repeat a signal the way the FPV repeater system does, But as I mentioned before, this is absolutly not a problem when flying FPV. The system is not made for 3D Heli flying. But with Mulitcopter it's perfect.
The project started out as a experiment but after some test and test again, it really proved it worked just the way it was surpose to. (it worked so good John and Jesper (two nerds) desided to share with you all) Of cause if you only need 8 Ch for your setup, don't buy this device.
I just think if it works for me it might also work for you. So if you see you can use this FPV repeater system for your own project and setup I'm sure you won't regreat.
Like all other FPV stuff (It's better to have a need not, than to need a have not)
Old Apr 03, 2012, 06:47 AM
catamar is offline
Alicante, España
Joined Jun 2010
Hello, I think I am going to buy one, but I want to have the 12 channles in only one transmiter, Can I do what I mentoned before, 3 or 4 post back?
Old Apr 03, 2012, 06:54 AM
Hooks is offline
Hooks's Avatar
Joined Jun 2009
To have 12 ch you need to use dragonlink UHF.
Regards
Old Apr 03, 2012, 06:57 AM
boopidoo is offline
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
Why not TSLRS?
Old Apr 03, 2012, 07:09 AM
FpvKiwi is offline
Up up and away!
FpvKiwi's Avatar
Sweden
Joined Oct 2010
catamar, if you make your Tx output 12ch, you can connect the LRS module directly to the Tx and get 12ch, without extra devices (as long as the 12ch format is compatible). If you do want to control the LRS module wirelessly, your 2.4GHz system needs to be capable of accepting 12ch. I don't think many systems are capable of that so read up on your particular link brand before trying.
The purpose of the UHF repeater is to combine 12 servo signals into one PPM signal and to power a Rx with 5V. Once you have the PPM signal, just feed it to the LRS module. Some people use a long cable between the Tx and the module to place the module somewhere else.
Yippee! NEW DRAGON LINK ADVANCED: Full Telemetry, Bluetooth, Droid Planner, Data Modem JettPilot FPV Equipment 46075 Today 08:07 PM
Question UHF System Can connect to the 7 Channels Radio System ? RanD222 FPV Talk 7 Nov 15, 2011 11:04 AM
Suggestion Flyinjrc74 repeatedly abusing the feedback system. flyer368 Site Suggestions / Complaints 1 Nov 11, 2011 02:22 PM
Discussion Alternative to expensive UHF system fpvguy FPV Talk 1 Sep 20, 2011 12:32 AM
Discussion How do I switch off 2.4 Ghz system when I only want to use UHF system? Voguna FPV Talk 1 Oct 07, 2010 07:16 AM
