Old Mar 30, 2012, 04:01 PM
Hooks is offline
Find More Posts by Hooks
Hooks's Avatar
Joined Jun 2009
New Product
FPVlongrange UHF repeater system
I have the pleasure testing this nice "new" FPV product.
It's a RC repeatersystem so you can use your standard RC gear sending up to 12 CH to a repeaterbox - UHF RC SYSTEM.
I have made this illustration on how the system works in princip.
The repeatersytem is well tested with Dragonlink & TLRS & EzUHF system
Dragonlink: 12 CH
EzUHF: 8 CH
TLRS: 10 CH
The repeaterbox is milled out in a nice ALU case permanent closed.
Some would ask! But why? Well I like the possability to place the strong 433Mhz UHF signal away from my sensetive Video receiver. Ect. in top of a mast, hill or on the top of a high building without any long cables.
You can place the repeater 500-1000m away from where you fly.
Off cause when you repeat a signal you will have more delay on the signal receiving the plane, but this is not a problem for FPV & UAV flying. I have used the repeater system with multicopter and there is no problem at all.
** NOTE I'm not the seller or developer of this UHF repeater system.
I will try answer questions the best I can.
Hooks is offline Find More Posts by Hooks
Old Mar 30, 2012, 05:26 PM
FpvKiwi is offline
Find More Posts by FpvKiwi
Up up and away!
FpvKiwi's Avatar
Sweden
Joined Oct 2010
Very interesting! Is it any different from a PPM encoder, apart from the nice case?
Who's the developer?
What's the price? http://fpvlongrange.com doesn't mention this product.
FpvKiwi is offline Find More Posts by FpvKiwi
Old Mar 30, 2012, 05:41 PM
John Jensen is offline
Find More Posts by John Jensen
Joined May 2011
Well it no big diffrence, but with a standard encoder you will not be able to get this function. Why? Mostly because the PPM is not right.
John Jensen is offline Find More Posts by John Jensen
Old Mar 30, 2012, 05:51 PM
HighwayChild is offline
Find More Posts by HighwayChild
Joined Nov 2010
Great idea
The best part (to me) seems that you can use any control system you like, without hacking into your expensive Tx, and leaving your trainer port free for headtrackers/plugins.
I would be even more likely to buy this if the LRS manufacturers (TS, EZ, DL etc) just added a facility for plugging in a receiver to their boxes as standard, eliminating the need for a second box.
Eliminating all those fiddly failure-prone servo connectors somehow would be great too, maybe with a block-type connector if your receiver allows it.
HC
HighwayChild is offline Find More Posts by HighwayChild
Old Mar 30, 2012, 06:51 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Keep in mind, there already exists a few 2.4Ghz Rxs out there that can output a raw PPM
stream which you can connect to the PPM input of any UHF Tx module.
For example. Ch8 on this 7ch Rx outputs PPM.
http://www.rangevideo.com/index.php?...roducts_id=239
FrSky also makes a Futaba FASST compatible Rx with PPM output
http://www.frsky-rc.com/ShowProducts.asp?id=80
Can modify the Corona Synth FM Rx to output PPM
http://www.team-blacksheep.com/article/page:20
This approach obviously doesn't include the ability to multiplex multiple Rxs into one stream, but not everyone needs that.
ian
Daemon is online now Find More Posts by Daemon
Old Mar 31, 2012, 02:05 AM
Ian Davidson is offline
Find More Posts by Ian Davidson
Old Blighty
Joined Apr 2010
I like this!
Ian Davidson is offline Find More Posts by Ian Davidson
Old Mar 31, 2012, 03:56 AM
Hooks is offline
Hooks's Avatar
Joined Jun 2009
A video Will be made to show this in action.
This is nothing fancy or new hi tech "must have", but it's really makes things better/easyer to install and use the UHF rc long range systems. I was having big problems getting 10 useable ch from my futaba 10c to the UHF long range system. Using the FPVlongrange repeater system it's just pluging in the output ch from the receiver into the repeater Unit.
No hacking my fataba finding the PPM pin or installing a big uhf tx on my rc tx. Before i had one rc tx for my 2,4 GHz planes and one installed with uhf. Now i only use one rc tx for All my planes and All running on 2,4 GHz. When it's time for long range FPV i just bring the uhf repeater with mé.
Before I had noise in my video link because the uhf 433 mhz was too close to the video link receiver. Now the UHF tx is places in the other end of the flying field installed on a 3 meter tripod.
Old Mar 31, 2012, 04:32 AM
Old Blighty
Joined Apr 2010
Any idea when pricing and availability info will be released?
Old Mar 31, 2012, 07:40 AM
Hooks is offline
Hooks's Avatar
Joined Jun 2009
Simple guide in how to use. Att file
The FPV repeater system from FPVlongrange.com will soon be ready for preorder. First batch should be ready for shipment from Denmark EU within 14 days.
Old Apr 01, 2012, 11:03 AM
Hooks is offline
Hooks's Avatar
Joined Jun 2009
The FPV repeater system is now ready for order on FPVlongrange.com
Old Apr 01, 2012, 11:52 AM
Old Blighty
Joined Apr 2010
I'm rather tempted by this device. The ability to mix two RX's together and remotely position the UHF TX is rather appealing!
Old Apr 01, 2012, 01:16 PM
Hooks is offline
Hooks's Avatar
Joined Jun 2009
@ian I'm sure if your not happy with the result you can just return the repeater and get your money back. Just contact John via the website FPVlongrange.com.
Old Apr 01, 2012, 05:30 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Hrm interesting idea... I have been considering the concept of 2 RX's (use a cheap 4 ch radio for cam pan/tilt) but range was my concern, this would eliminate that!
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Apr 01, 2012, 07:51 PM
demondriver is online now
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
VERY cool technology Hooks!
demondriver is online now Find More Posts by demondriver
Latest blog entry: Foam Safe Spray paint!
Old Apr 01, 2012, 10:42 PM
Steph280 is offline
Find More Posts by Steph280
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
This is an awesome concept! I'd love to try this out.
Steph280 is offline Find More Posts by Steph280
Yippee! NEW DRAGON LINK ADVANCED: Full Telemetry, Bluetooth, Droid Planner, Data Modem JettPilot FPV Equipment 51846 Today 01:47 PM
Question UHF System Can connect to the 7 Channels Radio System ? RanD222 FPV Talk 7 Nov 15, 2011 10:04 AM
Suggestion Flyinjrc74 repeatedly abusing the feedback system. flyer368 Site Suggestions / Complaints 1 Nov 11, 2011 01:22 PM
Discussion Alternative to expensive UHF system fpvguy FPV Talk 1 Sep 19, 2011 11:32 PM
Discussion How do I switch off 2.4 Ghz system when I only want to use UHF system? Voguna FPV Talk 1 Oct 07, 2010 06:16 AM
