Espritmodel.com Heli Air
Old Mar 30, 2012, 02:41 PM
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
Throttle End point adjustment?
I recently got a hitec aurora 9 and you can adjust all EPAs to 140% up and down including the throttle. Now on the servos i go until it binds then back off a bit, but i'm not sure what it would do for the throttle channel. Is it going to push the motor and esc more or just give more resolution to the throttle channel or nothing at all? Thanks for your help!
hone1er is offline Find More Posts by hone1er
Old Mar 30, 2012, 03:36 PM
58 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
For most purposes you should set endpoints to approximately 100%. Using more with servos gets you to angles on the output arms that cause control surface movement to be increasingly non-linear. There are exceptions for special purposes such as flaps, but for the principal control surfaces the throw should not be much over 100%. Control surface throw should then be set as necessary using mechanical adjustments.
As for the throttle channel with an ESC the throw should also be about 100%. It may in some cases be necessary to increase throw at the low end to get the ESC to arm, but normally it's not. There is absolutely no point in increasing the high end, as the ESC normally calibrates itself to suit the radio's signal range. Bottom line, unless you have a problem with arming, leave the endpoints at 100%.
Incidentally, endpoint adjustment of over 100% is a normal feature of virtually all programmable radios, with the maximum ranging from 125% to 150%.
Daedalus66 is offline Find More Posts by Daedalus66
Latest blog entry: Polaris Aileron Pushrods
Old Mar 30, 2012, 05:06 PM
Joined Aug 2002
Do not adjust EPA's unless required for 3D.
Throttle trim must be reduced to minimum or at least les than 50% on
any computerised transmitter for an ESC to arm correctly, please refer to:
. EPA, ATV, Dual & Triple Rates, Expo Differences & Caution + ESC / BEC Set Up
Hitec USA Support Forum Sticky:
. Aurora 9, AFHSS Spectra Modules, Optima Transceivers, Minima Receivers
& Telemetry
- FAQ & Undocumented Features
- Mixes, Setups, Tips. {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links (quick search = Ctrl+F)
A.T. is offline Find More Posts by A.T.
Discussion End point adjustment for throttle hone1er Beginner Training Area (Aircraft-Electric) 4 Mar 31, 2012 10:21 AM
Discussion How to add Throttle end points to U/Tronics Clancy Arnold Control Line 0 Nov 04, 2011 07:32 PM
Discussion dx8 end point adjust DenverJayhawk Radios 12 Oct 06, 2011 08:54 PM
Question End-Point-Adjust vs Dual-Rate LSF226 Radios 6 Nov 29, 2009 11:17 AM
Can one end-point adjust the throttle on a Futaba 8UAF? temacc Electric Plane Talk 6 Jun 13, 2001 09:21 AM
