Mar 30, 2012, 09:21 PM
United States, VA, Fluvanna
Joined Jan 2011
It won't produce any more from the motor than the motor can produce. Having said that, if the ESC isn't receiving the signal that it has decided is 100% then there is room to imake adjustmenst like this. However, if this is the case then you have the ESC setup wrong - most likely not calibrated it properly.
When the servos are installed, they don't normally use the full amount of travel simply to avoid problems with binding or internal damage. As you noted, you can increase the amount of travel on the transmitter and the servo will proportionally increase the amount it travels even to the point of damage.
When you calibrate an ESC you are basically telling the ESC "here is the highest point of my throttle range and it should result in 100% output. Here is the lowest point of my throttle range and it should result in no output." So if the ESC is calibrated when the throttle endpoint is 100% then changing it to later will have no effect. Sure, the signal to the receiver will be 140% when the stick is all the way up but the ESC was already at 100% output a little past midstick and for the ESC and motor because when it was calibrated, 100% throttle = 100% output.
Now, suppose you set the endpoint to 140% first. Then calibrate your ESC.
My Dx6i has 1024 steps (your Aurora may be different but for discussion's sake I'll use 1024 anyway).
100% / 1024 => 1 step is .098% of the travel
140% / 1024 => 1 step is 0.137% of the travel
For example, step 510 is about 49.98% of the normal throttle range and also about half of the number of steps. Using the 140% endpoint though, step 511 is about 70.003% which is even closer to half of the set range. So more resolution in terms of what % of the range a certain step represents.
But even with the transmitter using more and more % points, if the ESC was calibrated properly it will interpret 140% throttle as 100% if that's what you told the ESC was the "highest point of the throttle range". It will likely interpret 70% (midstick) as 50%, 20% as 14%, etc.
It doesn't seem very useful for values over 100% but can definitely be used to limit throttle to less than 100%. Say for people just starting out who ignore the left stick and fly WOT or no throttle at all.
