FPVDM - FPV Dream Machine (Tricopter) by MyRcBuild
Yeah, yeah, yeah, I know. I am ridiculous... How my wife hasnt killed me by now I do not know.
I have been buying RC explorer type Tricopter Frames from Louis (flyhigh300) at Myrcbuild.com for some time now. I really like the quality of his g10 kits. A few months back he mentioned possibly building a Purpose built FPV tricopter and my eyes light up. After a little back and forth he cut me a kit to demo. Here are some things on this kit that I find very unique. 1. TONS OF ROOM FOR EVERYTHING!!!! A true FPV rig needs lots of room and this birds got it. 2. The bottom plate where the FC and Cam is mounted is soft mounted to the top frame using 4 pieces of soft foam. THIS IS JUST TO COOL!!!! I have a picture of it below, you can tighten it or loosen it, however you prefer. This should help tremendously with vibrations. 3. Built in cam mount / cage w/ full tilt ability. Also pictured below the cam cage is very nice. It fits my RMRC 540 cam with ease. The night lens was a little to big for the barrel but that's no big deal, I just took the barrel part off the cage. I am sure Louis will adjust this though so those of you with night lenses don't you fret 4. The arms are not connected to the top and body panels they are only connected to the top plate which should help protect the frame. This way the g10 wont crack from pressure, worst comes to worse you just loose an arm. 5. STRONG STRONG STRONG STRONG tail control assembly. I mean this thing is bulletproof. 6. The arms are swept further back making it more "T" shaped. I will be using: RMRC 540 cam w/ night lense RMRC 500mw VTX Hobby King easy OSD Inverted Vee Antenna Dragon Link OP Copter Control Motors: http://www.hobbyking.com/hobbyking/s...8622&aff=61689 Turnigy Plush 18a ESCs Dragon Link 2200-4000 3s lipo 9x5 props (currently I have 10x4.7 till they come in. Lost Model Alarm |
Maiden flight:
First FPV flight:
Very choppy lots of tuning to do. Second FPV flight:
Much better still have some tuning to do. Have to turn down the KP on my roll as it still twitches a little. I noticed while descending she wobbles around to so I probably have to lower my KI. |
Joined Nov 2010
Hey guy,
had not had time to look at the thread.. So some yes and no's here.. The top plate is 2.5mm thick .. I made a "fender washer" of G10 also 2.5mm thick.. thats on the bottom.. ( the part you cant quite see) So the washer puts pressure on the boom.. its about 1-1/8 wide.. The boom can be locked in with a screws or zip tie as there is a screw hole for that.. and slots for zip ties... zip tie slots are for those of us who plan to crash ... But even if you drill a second hole..it could be that.. you will weaken the boom and it will break in a crash much easier.. I've slam .. and I mean slammed .. a Tri on the ass-fault ..( copter with 1/2x1/2 Aluminum booms slotted) .. and G10 came way chipped but no breaking.. while the booms where all twisted.. In any case its strong.. The Ideas with the second plate is that its mounted on a vibration isolation pad, (soft mount) No metal or hard parts touch the top ..with the bottom plate. You have an option to mount the flight board on top or bottom.. So far one person bolted there Power Distribution board on top and bottom for FC.. GoPro version cumming soon also guys.. OK enough talk.. Well as they say.. "Video or it did not happen".. well its not a crash video.. :-( but here is the vid..
| Thread Tools | |
| For Sale Tricopter CNC Machined Chassis | noxnflame | Aircraft - Electric - Multirotor (FS/W) | 3 | Feb 25, 2012 12:32 PM |
| Discussion Dream machine - What would you build? | BenScoobert | Electric Heli Talk | 30 | Feb 05, 2012 01:49 PM |
| Sold CNC Machined Tricopter Center Chassis | noxnflame | Aircraft - Electric - Multirotor (FS/W) | 17 | Jan 30, 2012 02:40 AM |
| Discussion My Copter Control Tricopter... From Dream to Reality | tosjduenfs | Multirotor Talk | 5 | Nov 22, 2011 10:22 PM |
