Old Mar 31, 2012, 04:49 AM
Sean Oelofse is offline
Find More Posts by Sean Oelofse
.....till the wind drops.
Sean Oelofse's Avatar
Port Elizabeth, South Africa
Joined Oct 2006
"Kevlar for durability and 2.4 friendly!"......but 35 megs does'nt have a problem with carbon! ;-)
Sean Oelofse is offline Find More Posts by Sean Oelofse
Old Mar 31, 2012, 04:56 AM
Fubar 123 is online now
Find More Posts by Fubar 123
Fubar 123's Avatar
Whitchurch,Shropshire. UK
Joined Jul 2008
Do you mind if I tag along for the ride ?
Fubar 123 is online now Find More Posts by Fubar 123
Old Mar 31, 2012, 05:00 AM
johannlochner is offline
Find More Posts by johannlochner
Stirring the pot
johannlochner's Avatar
Port Elizabeth South Africa
Joined Jun 2008
Hehehe
What took you so long Chris!!!
This is not a Genesis aka "Flying Fish" thread!
I do wonder....
Probably more my thing!
I really should stop going to the slope Cafe!
johannlochner is offline Find More Posts by johannlochner
Old Mar 31, 2012, 06:01 AM
Fubar 123's Avatar
Joined Jul 2008
Originally Posted by johannlochner View Post
Hehehe
I do wonder....
I have a confession .................
Old Mar 31, 2012, 06:45 AM
Stirring the pot
Joined Jun 2008
Here are a few more thoughts or rough sketches...
What are the other "team members" up too?
Sean, as the M-stab is your department,
Check out Paige's thread!
http://www.rcgroups.com/forums/showp...8&postcount=22
Bakkie,
Get out that hammer you bought the other day!
Old Mar 31, 2012, 09:13 AM
surfimp is offline
Find More Posts by surfimp
Piscine Promulgator
surfimp's Avatar
United States, CA, Santa Barbara
Joined Feb 2003
That fin is pretty close to being right on the CG.. might work more like a dive brake than anything
There are adherents to various varieties of the "nose rudder theory", but I am not one of them.
We already know that a suitably sized surface with sufficient travel located at the end of the tailboom will initiate an airframe flip... why should yaw work significantly differently than pitch?
Obviously there are issues around getting the wings to behave nice as they rotate in a way that they were never intended to, but the nose rudder theory doesn't help there, does it?
Steve
surfimp is offline Find More Posts by surfimp
Old Mar 31, 2012, 09:30 AM
JimZinVT is offline
Find More Posts by JimZinVT
let's FLY!
JimZinVT's Avatar
United States, VT, Castleton
Joined Dec 2007
I think Steve is assuming the "dorsal fin" is a functional control surface. I was seeing it as a fixed, but removable part of the fuselage, to get at the removable wing....just additional side surface area, the better to knife-edge with?
I don't really buy into the "nose rudder" idea either. If a flat 360 spin is the goal, it's going to spin around the CG. So the control input should be as far from the CG as possible....i.e. at the tail.
(just adding my 2 rand worth.....;-)
JimZinVT is offline Find More Posts by JimZinVT
Old Mar 31, 2012, 09:38 AM
surfimp is offline
Piscine Promulgator
surfimp's Avatar
Joined Feb 2003
The latest sketch shows what looks very much like a hinged surface... my comments pertained to that
Steve
Old Mar 31, 2012, 11:19 AM
Snewk is offline
Find More Posts by Snewk
Snewk's Avatar
United States, FL, Indialantic
Joined Dec 2011
Very good eye, there, Steve. I missed that detail but believe you're correct. Biggest issue I see with a truly flat pirouette type spin is the loss of lift from the wings as airspeed drops and reverses, especially across the wing that is pivoting backwards.
Here's a top view of a real flying fish.........possibilities???
http://animals.nationalgeographic.co...h/flying-fish/
And here's a nice side view drawing.
http://upload.wikimedia.org/wikipedi...flyingfish.jpg
These views got me thinking all kind of weird thoughts.....a probably low performance but visually cool "Fish" with a fairly standard build wing but all-moving tail surfaces built by using monofilament titanium wire for the leading edges and a straight film covering from wire to wire with no structural filler similar to a hang glider wing. They would be light and flexible, very forgiving on ground contact and although the flex factor would probably prevent tight precision flying it just might add a bit of oomph coming out of dives and turns.
(and I swear I haven't been smokin' nothin"!!)
Ken
Snewk is offline Find More Posts by Snewk
Old Mar 31, 2012, 11:28 AM
surfimp is offline
Piscine Promulgator
surfimp's Avatar
Joined Feb 2003
I don't know if think a true heli-style pirouette is very likely, but we know that conventional airframes can enter flat spins.
With appropriate flying technique, we should be able to unload Gs from the plane and kick it into a couple rotations at least before it drops into recovery.
Envision doing this with a glider, where the surfboard is the glider and the wave is the cliff face... very do-able, I think.
The Kaoli Kahokuloa 360 Spin (0 min 28 sec)
Steve
Old Mar 31, 2012, 11:33 AM
Bakkie is online now
Find More Posts by Bakkie
I think I'm Mode 2
Bakkie's Avatar
South Africa, Eastern Cape, Port Elizabeth
Joined Sep 2010
Bakkie,
We been out training Had a nice fly ay Maitlands
Bakkie is online now Find More Posts by Bakkie
Old Mar 31, 2012, 11:38 AM
I think I'm Mode 2
Bakkie's Avatar
Joined Sep 2010
"dorsal fin" is just the name for the "saddle" that's gonna keep the wing in place....
Old Mar 31, 2012, 11:50 AM
Stirring the pot
Joined Jun 2008
You guys are probably giving me credit for more lateral thought than I intend
The "Dorsal fin" was only a replacement for the lost vertical surface above the wing.
I would really like the wing to be a one piece removable item both for strength, weight and convenience.
It would also afford us the opportunity to test some different wing plan forms and sections.
I'll have to get to shaping the fuz to see what it looks like!
Old Mar 31, 2012, 12:32 PM
Fubar 123's Avatar
Joined Jul 2008
Hows about plug in wings for a change ?
Just a idea
Old Mar 31, 2012, 02:09 PM
Joined Oct 2006
Flat spin?
I've seen one of those Parkzone Strikers doing an inverted flat spin. It goes for as long as you like and does about 3 spins per second...(guess), like a "frisbee"
I beleive it prefers inverted to upright. OK!.......it has twin rudders and is a delta wing.
Just a question!
Do the wings need to generate lift in a spin?
How many spins is enough?
Discussion First Fun Fly of the year at Hartford Pa. 3/16, 3/17, 3/18. 2012 Curt S Electric Flight Events 0 Mar 14, 2012 11:08 AM
Contest 2012 New Years Day Postal Contest Mr B.... Sailplane Events 115 Jan 08, 2012 11:38 AM
Contest 2012 New Years Postal Contest Mr B.... Thermal 1 Dec 27, 2011 09:03 PM
Discussion 2012 the year of the Hypothecation event bubble bursting making sub prime look small treehog Life, The Universe, and Politics 0 Dec 17, 2011 06:59 PM
