Old Jul 24, 2012, 01:48 AM
Drusky is offline
Find More Posts by Drusky
just a rumour
Drusky's Avatar
South Africa, EC, Port Elizabeth
Joined Jun 2006
What about bolting the mould to a frame afterwards? You would have to recess the bolt heads on side A. You could use angle iron. 50mmx50mmx4mm length = x. It could be bolted on so that it lies over the corner of the B sides.
Drusky is offline Find More Posts by Drusky
Old Jul 24, 2012, 04:24 AM
Sean Oelofse is offline
Find More Posts by Sean Oelofse
.....till the wind drops.
Sean Oelofse's Avatar
Port Elizabeth, South Africa
Joined Oct 2006
CHEESE Drusky!
We do want this thing to fly!! ;-)
Sean Oelofse is offline Find More Posts by Sean Oelofse
Old Jul 24, 2012, 04:36 AM
Drusky is offline
just a rumour
Drusky's Avatar
Joined Jun 2006
Sean you prrrawn! You would think I was considering using the angle for a wing spar :P
Old Jul 24, 2012, 04:44 AM
Bakkie is offline
Find More Posts by Bakkie
I think I'm Mode 2
Bakkie's Avatar
South Africa, Eastern Cape, Port Elizabeth
Joined Sep 2010
that's what I though too
Who know what to expect from you...... I saw your post of turning the Le Fish into a Titanic
Bakkie is offline Find More Posts by Bakkie
Old Jul 24, 2012, 01:07 PM
Drusky is offline
just a rumour
Drusky's Avatar
Joined Jun 2006
Le Nemere
Old Jul 28, 2012, 07:29 AM
johannlochner is offline
Find More Posts by johannlochner
Stirring the pot
johannlochner's Avatar
Port Elizabeth South Africa
Joined Jun 2008
It's raining again!
I've run out of resin, and can't get anything locally!
Rather than wait a week,
I split the mould halves!
I'll do the final squaring off later as I think it'll be fine....
It split easily enough, but I had some negative draught on the vertical tail seam line.
The plug is rigid with no flex which caused the split edge to crack off.
It can be fixed!
Otherwise.....
I'm happy!
johannlochner is offline Find More Posts by johannlochner
Old Jul 28, 2012, 12:03 PM
graham1234 is offline
Find More Posts by graham1234
Graham Kirkland
graham1234's Avatar
Port Alfred South Africa
Joined Jun 2009
Not surprised you ran out of resin. That is a BIG mould. Must weigh a ton.
We are going to have fun making sure that you don't get any surface bubbles. There are some pretty sharp curves in that tool. Ah, I forgot, you have been down that road before.
Impressive finish. But I am getting used to that in your work.
Graham
graham1234 is offline Find More Posts by graham1234
Old Jul 28, 2012, 02:31 PM
Drusky is offline
just a rumour
Drusky's Avatar
Joined Jun 2006
Why such a big mould? I was reading Samotage's Jart build again today and noticed that his mould was faaaar less chunky. Is the beef really necessary?
Old Jul 28, 2012, 02:36 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
Samotage wasn't pressurizing the inside of the mold with 50 pounds per square inch.
wyowindworks is offline Find More Posts by wyowindworks
Old Jul 28, 2012, 02:43 PM
Stirring the pot
Joined Jun 2008
Hi Andrew
Probably not....
The mould could have been thinned out width wise to follow the fuz shape, (especially the nose area) but making the "box" would prove a lot more work and accuracy.
Sam was also not using the inflation system where you need "thickness" to counter 60psi internal pressure and the necessary even clamping.
I simply come to terms with the quantity of resin!
But hey,
I'm learning too!
Old Jul 28, 2012, 02:51 PM
Stirring the pot
Joined Jun 2008
Oops...
Thanks Adam!
I've only used 45psi so far....
The mould Graham number's using for his DLG pod has worked great so far.
That learning curve is pretty steep in it's self as regards lay-up.
I'll get there soon....
Hopefully, I can learn from his experience!
Old Jul 29, 2012, 12:41 AM
Flying Beagle is online now
Find More Posts by Flying Beagle
...missing the PE Slope Rebels
Flying Beagle's Avatar
United States, MI, Manchester
Joined May 2004
wonder if anyone has tried to mix some "filler" to reduce the amount of resin reqd, like micro balloons, only bigger
Maybe dried wasabi green peas
Flying Beagle is online now Find More Posts by Flying Beagle
Old Jul 29, 2012, 01:32 AM
Zenmaniac is offline
Find More Posts by Zenmaniac
Building with TLAR precision
Zenmaniac's Avatar
near Madison, WI
Joined Jan 2009
That's why all the kids' sandboxes near Johann's house are empty!
If you used that much straight epoxy, it'd be smoking for a month!
-= Dave
Zenmaniac is offline Find More Posts by Zenmaniac
Old Jul 29, 2012, 03:03 AM
Stirring the pot
Joined Jun 2008
Hehehe
We have a huge sand box just down the road!
I have,
been down there in the middle of the night in pouring rain!
and...
cooked it up on the stove to dry it!
Strange but true!
If you mess around with epoxies,
and you not careful.....
You will be punished!
I mixed up 5g of gel coat to fix the minor chips and blemishes.
It's a 10: 1 ratio ie 0.5g hardner
and....
My very sensitive scale sd it up!
It's still all sticky!
Now to clean it up....
Last edited by johannlochner; Jul 29, 2012 at 03:05 AM. Reason: J with sticky fingers
Old Jul 29, 2012, 03:09 AM
Thepasty is offline
Find More Posts by Thepasty
Fly fast, Dont crash.
Thepasty's Avatar
Cornwall, UK
Joined Sep 2006
hey J
thats why I always mix more than I need when using such small amounts.
Not that I've done any glassing in the past year...
Thepasty is offline Find More Posts by Thepasty
Discussion First Fun Fly of the year at Hartford Pa. 3/16, 3/17, 3/18. 2012 Curt S Electric Flight Events 0 Mar 14, 2012 12:08 PM
Contest 2012 New Years Day Postal Contest Mr B.... Sailplane Events 115 Jan 08, 2012 12:38 PM
Contest 2012 New Years Postal Contest Mr B.... Thermal 1 Dec 27, 2011 10:03 PM
Discussion 2012 the year of the Hypothecation event bubble bursting making sub prime look small treehog Life, The Universe, and Politics 0 Dec 17, 2011 07:59 PM
