Old Jun 24, 2012, 03:26 PM
johannlochner is offline
Find More Posts by johannlochner
Stirring the pot
johannlochner's Avatar
Port Elizabeth South Africa
Joined Jun 2008
Originally Posted by Fubar 123 View Post
...... only 3 weeks to the Lundy Trip
I would love to join you one day....
Not much work today as most of the time spent was waiting for epoxy to cure!
The split edges came out fine with one or two "hollows" to be filled.
They are very tight and should give a good result.
I'm 1-2mm out on the split line in places, but short of breaking every thing out, I don't know what to do!
Probably will be OK, but it's in the area of the nose where I have some concerns.
I'll fill the spots and worry about it tomorrow!
johannlochner is offline Find More Posts by johannlochner
Old Jul 11, 2012, 02:27 AM
Flying Beagle is offline
Find More Posts by Flying Beagle
...missing the PE Slope Rebels
Flying Beagle's Avatar
United States, MI, Manchester
Joined May 2004
............I'll fill the spots and worry about it tomorrow!
uh....hello ?
how long does it take for epoxy to dry ?
Flying Beagle is offline Find More Posts by Flying Beagle
Last edited by Flying Beagle; Jul 11, 2012 at 02:31 AM. Reason: one popcorn for each day since the last goldfish post
Old Jul 11, 2012, 03:13 AM
Sean Oelofse is offline
Find More Posts by Sean Oelofse
.....till the wind drops.
Sean Oelofse's Avatar
Port Elizabeth, South Africa
Joined Oct 2006
Hehehehehe!
You'll wait for ever for it to dry!....but 12 hours passed long ago for it to cure! ;-)
Sean Oelofse is offline Find More Posts by Sean Oelofse
Last edited by Sean Oelofse; Jul 11, 2012 at 03:14 AM. Reason: Welcome back to Africa FB!
Old Jul 11, 2012, 08:48 AM
Zenmaniac is online now
Find More Posts by Zenmaniac
Building with TLAR precision
Zenmaniac's Avatar
near Madison, WI
Joined Jan 2009
Originally Posted by Sean Oelofse View Post
Hehehehehe!
I don't trust anything a Coro builder says about epoxy!
-= Dave
Zenmaniac is online now Find More Posts by Zenmaniac
Old Jul 11, 2012, 12:51 PM
Stirring the pot
Joined Jun 2008
Originally Posted by Flying Beagle View Post
uh....hello ?
Welcome back FB!
Hope you survived the tornado's and heat waves back home.....
There is a bit of progress!
I have been sidelined by Graham's DLG pod mould the last two weeks.
I also need to order more resin, as I've used buckets of it lately!
Anyway,
The one half has been cast and I'll try for the other half over the weekend.
So far so good.
I just need to clean it up and fit the resin wells.
Old Jul 22, 2012, 01:52 PM
Stirring the pot
Joined Jun 2008
The build continues....
At a sedate African pace.
but hey, I've managed to get all the other "stuff" out the way!
The squaring and filling of the mould takes a huge amount of resin.
There is almost 10l in there!
I'm hoping to get the last sand resin mix in there soon and crack it open by next weekend!
Old Jul 22, 2012, 11:24 PM
Drusky is offline
Find More Posts by Drusky
just a rumour
Drusky's Avatar
South Africa, EC, Port Elizabeth
Joined Jun 2006
10L of epoxy resin? That's got to be pricey! Where do you source your sticky goo and super weave?
Drusky is offline Find More Posts by Drusky
Old Jul 23, 2012, 12:05 AM
Stirring the pot
Joined Jun 2008
You can try Specialist composites here in PE or order directly from AMT in JHB/CT or Durbs.
It's cheaper from AMT by a long shot, but delivery costs are high for small quantities. They also have a larger assortment of items we use in stock. Especially items such as light weight Carbon and Kevlar cloth.
Evan in JHB is also very much involved with the aircraft modelling scene and has a good understanding as regards our usage and requirements.
Old Jul 23, 2012, 01:41 AM
Drusky is offline
just a rumour
Drusky's Avatar
Joined Jun 2006
I get the little bits that I use from Specialist Composites.
Old Jul 23, 2012, 04:34 AM
DudleyLeRoux is offline
Find More Posts by DudleyLeRoux
scratch build everything
DudleyLeRoux's Avatar
South Africa, KwaZulu-Natal, Botha's Hill
Joined Aug 2009
Nice work as usual Johann.
I thought I used a lot of epoxy, geez, 10L is epic.
DudleyLeRoux is offline Find More Posts by DudleyLeRoux
Old Jul 23, 2012, 06:32 AM
Stirring the pot
Joined Jun 2008
Yeah, the volume is about 25 cubic litres
so, the rest has to be sand/glass and gel coat!
It is quite a lot...
I don't quite know how to get around the inflation/clamping without squaring it off.
Then there is the warping and twisting issues too...
Old Jul 23, 2012, 07:56 AM
Joined Aug 2009
In my rather lengthy discussions with Evan on the subject, specifically around wing moulds, Warp occurs if you are introducing different materials to the layup, like sand, metal bars etc... His recommendation to me was to use "returns" made of the same material as the mould layup. This gives the strength without the warp.
Of course this means nothing when you are building a mould for inflation bladder moulding, since you have to reinforce for internal pressure and hence external clamping force.
Good luck, I'm glad my fuse is long and skinny.
Old Jul 23, 2012, 02:06 PM
geoffers0_0 is offline
Find More Posts by geoffers0_0
I'd rather be.....
geoffers0_0's Avatar
Bristol, UK
Joined Jun 2008
Excuse my ignorance (following this thread with great interest)
Presumably, having completed the mould face
  • You're back-filling the "b-side" with sand/glass/resin for strength againt the bladder/clamping pressure?
  • Wouldn't it be possible to substitute a form of concrete - for instance glass-reinforced-concrete (GRC) as the backfill.
  • I appreciate that concrete itself would probably not have the required tensile strength without some kind of reinforcement, but GRC is widely used in the construction industry for lightweight cladding etc For example see ... http://www.grcuk.com/
geoffers0_0 is offline Find More Posts by geoffers0_0
Old Jul 23, 2012, 02:09 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
Originally Posted by geoffers0_0 View Post
  • Wouldn't it be possible to substitute a form of concrete - for instance glass-reinfoced-concrete (GRC) as the backfill.
I have tried this and had problems with the bond between the FRP face and the concrete.
wyowindworks is offline Find More Posts by wyowindworks
Old Jul 23, 2012, 02:32 PM
Stirring the pot
Joined Jun 2008
Hi geoffers0_0
Yeah, I'm currently "filling side B
Adam's right, it's all about the bond.
In composites, you can add the "fibres" as they do with the fibre cement boards using resin as the bonding material. The use of cotton flock tends to be very resin thirsty, but the bonding agent still has the same characteristics as the glass layup and therefore delivers good adhesion.
Sand in this case acts as the filler to give better bulking results per volume. Strength is not the main consideration.
But....
Warping and deflection of the mould part is a real problem.
Hehehe
On my 1st wing mould I stripped it after 24h and watched it curl and deflect with absolute horror!
Now, I've learnt at least one thing....
Let it cure, and perhaps consider some reinforcing bars!
Last edited by johannlochner; Jul 23, 2012 at 02:37 PM. Reason: Dam, I know I should have put some steel framing in!
Discussion First Fun Fly of the year at Hartford Pa. 3/16, 3/17, 3/18. 2012 Curt S Electric Flight Events 0 Mar 14, 2012 11:08 AM
Contest 2012 New Years Day Postal Contest Mr B.... Sailplane Events 115 Jan 08, 2012 11:38 AM
Contest 2012 New Years Postal Contest Mr B.... Thermal 1 Dec 27, 2011 09:03 PM
Discussion 2012 the year of the Hypothecation event bubble bursting making sub prime look small treehog Life, The Universe, and Politics 0 Dec 17, 2011 06:59 PM
