Old Mar 30, 2012, 08:15 AM
gryphon krinsky is offline
Find More Posts by gryphon krinsky
South Africa
Joined Feb 2012
Idea
large landing gear for small planes
i wanted to ask i have got a yak 54 from nine eagles and can not land it beacause the wheels are so small that they just get stuck on the grass and the plane pushes over forward is there any chance of making bigger wheels so that i can land.
gryphon krinsky is offline Find More Posts by gryphon krinsky
Old Mar 30, 2012, 08:33 AM
wellington53 is offline
Find More Posts by wellington53
Glenn
wellington53's Avatar
United States, WI, Oconto Falls
Joined Jan 2004
Sure,
http://www.hangar-9.com/Products/Def...?ProdID=HAN300
wellington53 is offline Find More Posts by wellington53
Old Mar 30, 2012, 08:38 AM
realtimerecon is offline
Find More Posts by realtimerecon
Real Time Recon
realtimerecon's Avatar
smith mt. lake VA.
Joined Jan 2007
A set of these will keep your prop out of the grass and muck.Total weight 1.3 ozs.And 4.5" in Dia.They are the ones that go w/the Multiplex Fun Cub.And can be bought separately from Multiplex.
realtimerecon is offline Find More Posts by realtimerecon
Old Mar 30, 2012, 08:43 AM
bjornkipper is offline
Find More Posts by bjornkipper
Little Norway
Joined Feb 2010
Well i only fly my P-47 (also nineeagles) on concrete floor/tarmac structures/asphalt. As we know, this is a 1C organism, so it doesn`t take to kindly to extra weight. I don`t know about you, but i never would have used this model on grass (unless some sort of artificial grass, worn down) I am very impressed with the NineEagles P-47, and i have heard that the Yak has a slightly more complex nature, but however this is to be my next NineEagles model for sure in the near future. They look the part to..although i see the ole spit isn`t pulling the scale representativeness meter to a new high :-(
bjornkipper is offline Find More Posts by bjornkipper
Old Mar 31, 2012, 03:40 AM
South Africa
Joined Feb 2012
so are you saying that my plane will probably crash if i ad on big wheels
Old Mar 31, 2012, 04:11 AM
-james- is offline
Find More Posts by -james-
-james-'s Avatar
UK
Joined Sep 2008
Not necessarily, with the larger wheels the centre of mass in the plane would be lowered so it would indeed change it's flight characteristics slightly. However the ones in the link only weigh 6 grams each, so as long as you don't have to drastically change the existing undercarriage structure to mount them on, and as long as the centre of gravity stays where it is relative to the front and back of the aircraft then you'll have no problem imo. Someone else who owns that aircraft may say otherwise though
James
-james- is offline Find More Posts by -james-
Old Mar 31, 2012, 04:14 AM
-james- is offline
-james-'s Avatar
UK
Joined Sep 2008
Actually, just seen how small that aircraft is, I agree that with a total flying weight of 35g then an extra 12g is quite substantial :/ Sorry, i'm not sure what alternative there are for you
James
Old Mar 31, 2012, 06:23 AM
javier668 is offline
Find More Posts by javier668
Chile, Araucanía, Angol
Joined Jan 2012
Big wheels add a lot of drag and your plane will fly like a Pig.
I tried this in my um j3 and sucks.
Regards!
javier668 is offline Find More Posts by javier668
Old Mar 31, 2012, 07:06 AM
20ECHO is offline
Find More Posts by 20ECHO
Joined Sep 2008
GWS SlowStick wheels are pretty ugly but pretty light.
20ECHO is offline Find More Posts by 20ECHO
Old Mar 31, 2012, 07:08 AM
Trisquire is online now
Find More Posts by Trisquire
Intermediate Multi
Trisquire's Avatar
Columbus, OH
Joined Mar 2005
GWS makes some large diameter wheels with very low frontal area for low drag. They're great for touch-n-goes off baseball diamonds.
Trisquire is online now Find More Posts by Trisquire
Old Apr 01, 2012, 02:41 AM
Jack the R is offline
Find More Posts by Jack the R
Jack the R's Avatar
Joined Aug 2009
No. Anything big enough to roll through grass will be too big for your plane. I think you would also have problems pushing through grass with such a light plane.
Your best bet is to take off the landing gear and belly land. You may want to protect the bottom of your plane and wing tips with clear packaging tape.
Jack the R is offline Find More Posts by Jack the R
Old Apr 01, 2012, 02:49 PM
Mazzepa1 is offline
Find More Posts by Mazzepa1
This is kid stuff.
Mazzepa1's Avatar
USA, AR, Harrison
Joined Aug 2010
+1
This is definitely what I would do.
Mazzepa1 is offline Find More Posts by Mazzepa1
Old Apr 02, 2012, 11:14 AM
South Africa
Joined Feb 2012
thanks for info I took of the wheels of my plane and it landed perfectly
Sold Couple sets of wheels and landing gear pieces for foam planes and whatever you need . MiG-3 Reno Rocket Aircraft - General - Miscellaneous (FS/W) 5 Mar 30, 2012 03:02 PM
Discussion A "no landing gear needed" recommendadtion, good for grass landing plane. Dr.JJ Electric Plane Talk 21 Mar 23, 2012 04:28 PM
For Sale NIP Great Planes .60 small Dural landing gear Viper82 Aircraft - General - Miscellaneous (FS/W) 0 Mar 03, 2012 08:31 PM
Sold Large Landing Gear Lot TGKconnectors Aircraft - General - Miscellaneous (FS/W) 0 Oct 18, 2011 12:05 PM
Sold Parkzone radios, Small Ni-Mh batteries, Landing gear. Lowered to $40.00 shipped! U.S. MiG-3 Reno Rocket Non R/C Items (FS/W) 3 Sep 26, 2011 09:56 AM
