Old Mar 30, 2012, 04:36 AM
rosemark is offline
Find More Posts by rosemark
Catch me if you can!
rosemark's Avatar
Woodstock Ga.
Joined Jul 2006
Question
how to set up a system using two lipos in parallel and an on board flight battery?
Is there a thread for setting up a two lipo in parallel and an on board flight battery?
rosemark is offline Find More Posts by rosemark
Old Mar 30, 2012, 05:29 AM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
For paralleling two Lipos you need the two reds, +ive connected together, and then the two blacks, -ive connected together. Depending on what connectors you have used, it could mean a simple connector, (see my picture using 4mm connectors), or possibly a small harness with connectors on.
If using a separate battery for the Rx and servos, (nimh, or even a separate BEC), then the BEC on the ESC, (if it has one), should be disabled, (simply remove the red +ive center connector).
Warning: Whether doing parallel, or series, Lipos, take great care when connecting them up. Mark the connectors so that there is minimum risk of shorting out a Lipo.
eflightray is online now Find More Posts by eflightray
Old Mar 30, 2012, 08:24 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
If you have Deans on your packs: http://www.rcdude.com/servlet/the-74...Harness/Detail
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Mar 30, 2012, 08:29 AM
rosemark is offline
rosemark's Avatar
Woodstock Ga.
Joined Jul 2006
Thanks for the quick response. The info you both gave me was perfect.
Discussion How to set up and trim an EP glider JJ460 Electric Sailplanes 2 Mar 24, 2012 08:27 PM
Discussion How to set Idle up on my DX5e in Phoenix Armyguy8675309 Simulators 3 Mar 09, 2012 08:56 PM
Question Any videos on how to set up an EDF plane? AlvaSpeed Foamy EDFs 3 Feb 29, 2012 09:59 PM
Discussion Using lipo in parallel way question congcon97 Racing Boats - Electric 1 Feb 23, 2012 10:29 PM
Discussion Lipo alarm setting in-flight vs on ground ArltTech Hoverfly Technologies 21 Nov 03, 2011 11:08 PM
