Old Mar 30, 2012, 03:45 AM
Goldentaco is offline
Find More Posts by Goldentaco
United States, CA, Hayward
Joined Jan 2012
Reusing glider wings to make flying wing
I have recently acquired a Soarcraft Centurion glider on the cheap. The fuse is in bad shape (one of the wing mounts is broken off). I am not sure what I want to do with it yet but I think I'd like to reuse the wing ( 8ft wide 2pc about 4deg dihedral) to make another glider. I recently got into flying wings and am wondering if it would be possible to use this in that manner.
While it won't be a true flying wing, it may have a small fuse big enough to mount a tail and electronics. Also probably adding elevons.
Does this sound doeable or would this wingset be a better fit for a more standard fuse with long tail? And if so should I just builg the fuse or can you get one already made?
I've never scratch built yet just ARF's and Kits so this is a tad over my head. But I want a challenge. If it doesn't work out I'm not out much anyway.
J
Goldentaco is offline Find More Posts by Goldentaco
Old Mar 30, 2012, 11:32 AM
prodjx is offline
Find More Posts by prodjx
prodjx's Avatar
Joined Jan 2007
Don't forget to reflex the elevon's, about 1/8" might do it. I have seen this done on a Cub trainer wing Which became a Backstrom Plank sorta scale and a Dynaflite Talon which flew rewall well.
prodjx is offline Find More Posts by prodjx
Old Mar 30, 2012, 03:22 PM
FWAL is offline
Find More Posts by FWAL
Flying without a licence
FWAL's Avatar
United Kingdom, Wales, The Mumbles
Joined Dec 2010
Go For IT
Last summer I bought an old, tired Chris Foss Phase 6. I refurbished it but decided only to use the semi symmetrical wings. I chose to make a 66" wing with the symmetrical Pro wing (OCD). As it was symetrical I found that no reflex was required!
Anyway, to cut a long story short I crashed it pretty bad and now what's left of the wings have bee used to build a 44" aerobatic soarer (Rebound)
There's a video of OCD's final flight on my RC Groups Blog
FWAL is offline Find More Posts by FWAL
Old Apr 02, 2012, 01:34 AM
Joined Jan 2012
Great it sounds like either way I go it may work.
The wings have polyhedral tips about a foot long like many gliders. I'm suspecting this may not work on the flying wing if I add any sweep to it. Would there be any need for sweep to make it sort of like a Nurfluegel?
If I go the flying wing route I may try for a design similar to this
I've recently discovered "socking" fuses so I may be able to make a traditional fuse with tail boom etc. I'm not sure which would be more hit or miss from a first time design standpoint.
J
Old Apr 02, 2012, 10:44 PM
lincoln is online now
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
Can you show us some photos? It's my guess that the easiest path is probably just to fix it back to the way it was. Second easiest might be to make a simple balsa fuselage the same length.
A flying wing will be pretty tricky. You can make them swept or not. The swept ones need more twist, the unswept probably need more reflex. In either case, I'd guess t he existing airfoil really isn't quite right for this.
lincoln is online now Find More Posts by lincoln
Build Log Epic Win - 2m flying wing electric glider slebetman Foamies (Scratchbuilt) 46 Oct 05, 2014 12:25 PM
Discussion What is your favorite flying wing glider? Ir-192 Thermal 26 Nov 01, 2011 10:16 PM
Question Best combat flying wing glider Ryan A Flying Wings 11 Oct 05, 2011 11:13 AM
Anyone ever make a Flying Eagle foam glider into an electric plane? Wingo 1 Foamies (Kits) 5 Oct 01, 2010 12:56 PM
