Old Nov 10, 2012, 06:25 PM
TomTerrific is online now
Find More Posts by TomTerrific
United States, CT, Waterford
Joined Jul 2012
@StudioRS: Thanks Thompson!
Next up-now to create some scale-ish landing gear doors to improve the looks of the front wheel...
@4all:
I flew my FMS ASW28 and ST DG-1000 today. I was wondering how similar or dis-similar you guys find these planes to fly???
(Assuming the ST ASW flies similar to the FMS model?)
My thoughts- While they both fly very nice, the ASW is faster and it seems I have to be carefull not to turn too fast or stall when turning as it will tipstall easily. Maybe i still have to get used to the ASW?
The ASW also has a faster & more powefull climb rate- almost to the point of looping backwards if not carefull. The spoilerons I added to both(55-65%flaps on a DX6i) are not dramatic and maybe helped reduce its loftyness(word?) upon landing.
Your Thoughts???
TomTerrific is online now Find More Posts by TomTerrific
Old Nov 10, 2012, 06:53 PM
peterlngh is offline
Find More Posts by peterlngh
Joined Apr 2012
Hmmm. I would think that the podded motor on the DG 1000 would help limit the pitch up compared to the ASW 28. It can be a problem with T-tails because the lift of the wings exceeds the stability of the tail at low speeds. With a botched launch one can even run into a "deep stall" where the T-tail is blanked by the wing. I've done it twice with my ST ASW 28 but suffered no damage aside from a bent prop shaft. The cure is to make sure that one launches level or even a bit nose down and keeps the nose low until one has sufficient airspeed. With a good launch it's no more difficult to control than any other motor glider.
The ST ASW 28 will tip stall easily but it's so light that it recovers by itself almost instantly. Adding dihedral helps one make smoother turns. I also added wooden ailerons and sanded a bit of washout into them but, mostly, I've just gotten more familiar with the plane. Any scale glider with a high aspect ratio will tip stall. It's just an inherent trait but the FMS ASW might be a bit more well behaved based on what I've read.
I have found that mine will land in a much smaller space by using spoilerons. It also allows one to slow down a bit more without dropping a wing since it essentially adds wash out. In fact, I can make "harrier landings" with a bit of a head wind.
It sounds like the FMS is a better plane out of the box while the ST needs some work. The stock aileron linkages are nearly worthless but, after adding the balsa ailerons and direct pushrods it flies beautifully and even performs nice rolls. The FMS has a bit higher wing loading but, since it's bigger, it doesn't sound like it suffers in soaring performance.
peterlngh is offline Find More Posts by peterlngh
Old Nov 10, 2012, 08:48 PM
Joined Jul 2012
Thanks Peter for your thoughts. Sounds like you've made allot of improvements to your plane. The FMS model has the dihedral built-in to the stock setup.
The DG has much more upturned wing ends than the ASW. Maybe that reduces its tipstall tendencies?
Wow- I like that "harrier" style landings achievable with your spoileron setup. Sounds powerfull. Maybe I'll keep increasing the movement and more experimenting...
Thanks Again!
Old Nov 11, 2012, 10:42 PM
kostuk is offline
Find More Posts by kostuk
Joined Nov 2003
ASW-28 pics
Hi,
I made some trim changes to my FMS ASW-28 to help with visibility. In addition to the red tips and tail I also painted the bottom of the wings and stab black. I really like the way it flies. I get 4 motor runs (20-30 sec) on a 1300 3s pack and usually have 3.9-3.96V after 15-20 minutes of flying. Moves quickly through the sky but indicates thermals well. I also added spoilerons for landing which slows it down and counters tip stalls. I'm using a Hitec Optic 6 Tx with an FrSky module and Rx.
Ray
kostuk is offline Find More Posts by kostuk
Old Nov 12, 2012, 09:03 AM
bushpilotx1 is offline
Find More Posts by bushpilotx1
WITCH HUNTER EXTRAORDINAIRE
USA, FL, Boca Raton
Joined Feb 2001
Looks nice kostuk...
bushpilotx1 is offline Find More Posts by bushpilotx1
Old Nov 12, 2012, 09:46 AM
Joined Jul 2012
Ray@Kostuk- Ditto... Looks great with the red trim. Nice!
I'm getting the same 4 lifts with my 1300ma batteries too.
The ASW-28 also makes a great whisssssshhhhhh sound when you make a fast flyby without the engine. Very neat.
Old Nov 12, 2012, 10:41 AM
StarHopper44 is offline
Find More Posts by StarHopper44
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
Like the wooosh, do ya? Check it out now:
The craziest glider low pass compilation, passages planeur : the best of -by CAF- (7 min 40 sec)
Thought I'd posted this in here before but re-checked & din't see it.
This's my all-time fave vidi on UToob....makes 'things' tingle on me!
StarHopper44 is offline Find More Posts by StarHopper44
Old Nov 12, 2012, 10:55 AM
Joined Jul 2012
WOW! Now that's some crazy great video.
I gotta wipe that smile & look off my face before I get thrown in the crazy bin
Old Nov 12, 2012, 11:22 AM
Earthbound Skyhound
Joined Jun 2011
Yassuh! I even like the lead-in implication of, "Crash & get eaten!"
Old Nov 12, 2012, 03:27 PM
stephen Damon is offline
Find More Posts by stephen Damon
USA, TX, Waco
Joined Nov 2010
asw28
Where is the best place and or places to buy one now? Thanks!!!
stephen Damon is offline Find More Posts by stephen Damon
Old Nov 12, 2012, 04:59 PM
Joined Apr 2012
Hi, Steve. As far as I know Banana Hobby is the only source for the FMS ASW 28 in the U.S.. Unfortunately it has been a big seller and they've jacked up the price. One could save a good bit on price with the smaller ones from ST Models or HobbyKing but they are of a lower overall quality and need some work to fly well. The ST soars very well because it's nice and light but the motor and aileron linkages just aren't very good and the control surfaces, at the very least, need to be stiffened up. Now that I have the ST ASW28 dialed in it suits my purposes but I'm going to glass and wood for my next scale sailplane.
Old Nov 12, 2012, 06:17 PM
Earthbound Skyhound
Joined Jun 2011
Originally Posted by peterlngh View Post
Hi, Steve. As far as I know Banana Hobby is the only source for the FMS ASW 28 in the U.S.. Unfortunately it has been a big seller and they've jacked up the price...
@Stephen:
Yeah, that. They were selling for $99.90 & suddenly took a quantum leap to $145.90.
BUT! There's a 'trick' you can pull to get back near the former CoA price. BH has a 'Free Shipping' on orders of $149+ deal going on right now. Just add some small $4 item you might or might not need but can use to your order. IE, just below the ad [http://www.bananahobby.com/asw28-rc-...366-prd1.html] they show 8 alkaline AAs for $4.90.
Shipping on mine to near-Atlantic coast was $35, so with the current "deal" you'll in effect pay only ~$14 more than the former price. But I'd jump now; BH has been especially notorious lately about ending promotions early. Plus anytime there's a deal going on, stock tends to disappear quickly. Your call.
AFA alternative domestic sources....since FMS dumped Nitro Planes/HobbyPartz, afraid BH is it!
http://fmsmodel-usa.com/t-about.aspx
Old Nov 12, 2012, 06:49 PM
Joined Jul 2012
Stephen- you've got some excellent advice here from Peter & Starhopper. If I could add 2 small ideas... Offers come and go and Bannana Hobbies may offer a better deal in the future(shipping may be less for you in Texas) if you can wait. Also - the online seller of the ST version - Tower Hobbies has a free shipping and $ off promo thru this Thursday. Peter & Thomson@StudioRS have provided excellent commentary & pictures on how to enhance the ST version here and on a separate thread here.
Good Luck!
Old Nov 12, 2012, 09:04 PM
Joined Apr 2012
Here's the link to my post about the ST ASW 28 after modification. I still think the FMS version is of better overall quality but I don't know if it actually soars any better. If I were to start over from scratch I would just avoid bending the prop shaft and stick with the original motor with a better ESC. Feel free to ask any questions on the ST thread if I have left anything out.
http://www.rcgroups.com/forums/showthread.php?t=1725885
Old Nov 16, 2012, 09:15 AM
instmusic is offline
Find More Posts by instmusic
United States, CA, Ventura
Joined Nov 2012
I have an FMS-ASW28 as well. I had a tip stall due to a bad launch and broke my propeller shaft. Did you replace the motor? How did you extract the original? The back of the firewall have the screw side of 4 wood screws. Thanks for the help.
I'm just getting started.
instmusic is offline Find More Posts by instmusic
Build Log Asw 28-18 simonslim Scale Sailplanes 32 Aug 31, 2015 07:01 AM
For Sale NIB 5 meter ASW 28 Jim Frahm Aircraft - Sailplanes (FS/W) 6 Apr 04, 2012 12:27 AM
Discussion Asw 28 p51plane Sailplane Talk 1 Mar 06, 2012 04:58 PM
Discussion ASW 28 2m grofCRO Serbia 8 Mar 05, 2012 04:33 PM
