Old Oct 07, 2012, 01:25 PM
rycomm is offline
Find More Posts by rycomm
Flyin' Ryan
USA, MO, Lee's Summit
Joined Sep 2001
Looks good Bonnie, I haven't added anything to my fuselage yet. The stripes or someother way to make the wings stand out it a very worthwhile addition. I flew a few days ago in bright clear sky, and it really stood out. I also landed on some freshly mowed grass. My landings looked much better without a wingtip catching in the taller grass.
I don't know of the style of holographic tape on my plane. It was already there when I bought it. I understand many vinyl sign stores carry it. I've heard of "rain" and several others that seem to work fine.
Here is a sample of what a quick google search pulled up.
http://www.holographiceffects.com/reflective-vinyl.php
I've also used plain "chrome" vinyl. It doesn't work quite as well, but it was free.
Ryan
rycomm is offline Find More Posts by rycomm
Old Oct 07, 2012, 01:45 PM
bushpilotx1 is offline
Find More Posts by bushpilotx1
WITCH HUNTER EXTRAORDINAIRE
USA, FL, Boca Raton
Joined Feb 2001
I have used the silver and the black Holographic tapes on my leading edge , the advantage is that when you are flying far away from you you can always tell the way the plane is facing when you see the "sparkle of the tape" when the sun hits the tape. If the plane is flying away from you you can not see it. It has saved me several times I have bought them on ebay , here are some links to places that carry it , hopes this helps, geoff
http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
http://www.bing.com/shopping/search?...RM=HURE#x0y168
http://www.rcgroups.com/forums/showthread.php?t=899854
http://www.tapebrothers.com/Reflective-Tape-s/263.htm
http://mccormicksnet.com/products/gu...ape/decorative
bushpilotx1 is offline Find More Posts by bushpilotx1
Old Oct 07, 2012, 02:48 PM
USA, FL, Boca Raton
Joined Feb 2001
Bonnie nice repair!!, you may also want to try placing a carbon fiber keel along the bottom of the rear of the fuse... just like you did on the sides and top....
Old Oct 07, 2012, 09:44 PM
bonnie9496 is offline
Find More Posts by bonnie9496
Fighting Gravity
bonnie9496's Avatar
Australia, WA, Perth
Joined Jan 2011
Thanks for the tip.
I'm cautious about adding too much weight behind CG. I'll test with additions as is, then if OK add the carbon keel as suggested.
Have also added some glider skids to the wing wips to save wear and tear.
bonnie9496 is offline Find More Posts by bonnie9496
Old Oct 12, 2012, 10:15 AM
studioRS is offline
Find More Posts by studioRS
Klassische Bilder
studioRS's Avatar
Northern Vermont
Joined Jul 2010
There has been a few asking about how the 2 meter (78" span) ST Model ASW-28 glides. I have the 2m ST Model ASW-28 and present my video for compairison. On a couple of fly-by passes you can hear it whistle and then when just gliding how it flys into a 3-5 mph WNW wind. Anyway, thought you guys might want to see this.
Modified with the following specifications:
- Modified fuselage and winglets glassed with cloth, soaked with Zap medium CA, sanded and painted white and red. This solves the wobbly fuselage and T-Tail.
- Wing spar cut in half, aluminum shaft glued with 5~6 deg dihedral on wing spar.
- Modified motor: TowerPro 2409-12
- Propeller: Graupner 8x4,5
- Spinner: Art-Tech ASK-21
- ESC: HobbyKing 30A
- Battery: 3S Parkzone 1300mAh 15C
- Scale Pilot: Hans
- Graphics: kewlartdesigns.com
Note: the only other modification, I plan to add some carbon 3mm strips slit into the underside of the wings and gorilla glued for the entire length.
Video camera used for entire footage was a keychain 808 #11 with 4GB card.
Still photography, Olympus E-500 DSLR with 40-150mm lens.
NOTE: This video is NOT the FMS ASW-28
ST Models ASW 28 2,0 meter Segelfliegen (3 min 9 sec)
studioRS is offline Find More Posts by studioRS
Old Oct 12, 2012, 12:15 PM
kostuk is offline
Find More Posts by kostuk
Joined Nov 2003
Hi Thompson,
Nice ASW! I was wondering what the AUW was and how much the graphics cost?
Ray
kostuk is offline Find More Posts by kostuk
Old Oct 12, 2012, 02:18 PM
studioRS is offline
Klassische Bilder
studioRS's Avatar
Northern Vermont
Joined Jul 2010
Originally Posted by kostuk View Post
Hi Thompson,
Ray
AUW is right at 730 grams (25.74 oz), 1.6lbs with my modifications.
Graphics are available through kewlartdesigns.com as PDF $15, you print or $29.95 + shipping, printed on clear.
Old Oct 12, 2012, 03:19 PM
kostuk is offline
Joined Nov 2003
THanks!
Ray
Old Oct 12, 2012, 09:14 PM
StarHopper44 is offline
Find More Posts by StarHopper44
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
"...glassed with cloth, soaked with Zap medium CA, sanded and painted..."
I've been wondering about that process. It sure seems to produce a beautiful finish!
IIRC you used an unconventional cloth - sheets or pillowcase or something?
And sounds like it'd take load$ of CA. Any filler (ala the old talcum powder trick) used?
I'd really love to learn the detailed steps of what's involved.
StarHopper44 is offline Find More Posts by StarHopper44
Old Oct 12, 2012, 09:19 PM
skypan12 is offline
Find More Posts by skypan12
Northern IL
Joined Sep 2006
Brown truck dropped off the box today hope to get it going on it first of the week, wife has us busy for the weekend.
skypan12 is offline Find More Posts by skypan12
Old Oct 12, 2012, 09:46 PM
peterlngh is online now
Find More Posts by peterlngh
Joined Apr 2012
Hi, StarHopper.
I'm not entirely sure about Studio's process but I have been playing with smaller bits of "glass". I'm using Skloft and, despite it being a lot thinner than cotton fabric, getting smooth results. I'm also using HobbyKing CA which is a fraction of the cost, even including shipping, of any name brand CA. Of course, one must always test the glue on a particular airframe because there seem to be as many different foams as there are manufacturers.
I also did a small test area on foam that the HK CA will dissolve. I just coated the surface with epoxy thinned with rubbing alcohol. It would probably get too heavy for an entire airframe but would work well for reinforcing a smaller area. On the other hand; it only takes the barest coating of epoxy and one scrapes off almost all of it. Patience and a steady hand could get very good results.
This is the stuff I'm using. $5.28, including shipping, for 1.7oz. It does not melt the foam on my ST ASW 28 but can't tell you if it's safe for the FMS foam.
http://www.hobbyking.com/hobbyking/s...Medium_b_.html
I have also used this foam safe thin CA with good results. It's more expensive than the "plain brown wrapper" CA but has not melted any foam I've tried it on and seems to stick very well.
http://www.hobbyking.com/hobbyking/s...oam_Safe_.html
peterlngh is online now Find More Posts by peterlngh
Old Oct 13, 2012, 08:06 AM
studioRS is offline
Klassische Bilder
studioRS's Avatar
Northern Vermont
Joined Jul 2010
Full steps of covering are on my blog.
http://www.rcgroups.com/forums/showthread.php?t=1494472
Cheers, Thompson
Old Oct 13, 2012, 04:34 PM
sinowace is online now
Find More Posts by sinowace
Joined Feb 2007
I just tip stalled my Cularis. I want to get this plane but I need to know its stall characteristics before I buy. Also how reliable is Banana Hobbies?
sinowace is online now Find More Posts by sinowace
Old Oct 13, 2012, 05:12 PM
skypan12 is offline
Northern IL
Joined Sep 2006
mine arrived in good time and in good shape just now starting to work on it quality looks pretty good
Old Oct 13, 2012, 05:32 PM
Fighting Gravity
bonnie9496's Avatar
Joined Jan 2011
Cheers, Thompson
Excellent detailed steps and pics.
You are very skilled and must be very patient !
Build Log Asw 28-18 simonslim Scale Sailplanes 32 Aug 31, 2015 07:01 AM
For Sale NIB 5 meter ASW 28 Jim Frahm Aircraft - Sailplanes (FS/W) 6 Apr 04, 2012 12:27 AM
Discussion Asw 28 p51plane Sailplane Talk 1 Mar 06, 2012 04:58 PM
Discussion ASW 28 2m grofCRO Serbia 8 Mar 05, 2012 04:33 PM
