Old Jun 30, 2012, 09:18 PM
Crash and crash!
realbob's Avatar
Canada, QC, Montreal
Joined Oct 2010
Find my codes here: http://hk.rc-international.info/swarm/realbob (valid until July 06, 2012)
Rubber Band Powered Freeflight Piper Super Cub 292mm Span Save US$: 0.49
Rubber Band Powered Freeflight Marchetti Model 310mm Span Save US$: 0.36
HXT 4MM to Banana Plug Charge Lead Adapter Save US$: 1.13
WireLabels - servo wire label heatshrink (14mm x 1m) Save US$: 0.61
XT-60 to JST Charging Adapter (2pc) Save US$: 0.62
Portable Mini Compressor with Air Hose Save US$: 1.89
realbob is offline Find More Posts by realbob
Old Jul 03, 2012, 06:01 AM
2 x Hex with HoverFly Pro
ross_badger's Avatar
Columbus, IN
Joined Jul 2009
Find my codes here: http://hk.rc-international.info/swarm/ross_badger (valid until July 13, 2012)
Strong Rare-Earth Button Magnets (10pcs/set) Save US$: 0.90
RG58 Patch Cable SMA Female to SMA Male (2 Meter) Save US$: 1.70
RG58 Patch Cable SMA Female to SMA Male (5 Meter) Save US$: 1.96
Hobbyking DUO5800v2 5.8GHz Diversity Receiver w/TrackerLink - Dual Output Save US$: 56.75
ross_badger is offline Find More Posts by ross_badger
Old Jul 03, 2012, 07:40 AM
The Netherlands, NB, Veghel
Joined Mar 2011
Find my codes here: http://hk.rc-international.info/swarm/mark2 (valid until July 17, 2012)
Turnigy 9X LCD Backlight Kit - White (DIY) Save US$: 1.36
Button spirit level. (2pc) Save US$: 0.65
MarkQ is offline Find More Posts by MarkQ
Old Jul 06, 2012, 08:04 AM
j0e
j0e's Avatar
Greece, Peloponnisos Dytiki Ellada ke Ionio, Patra
Joined Mar 2009
buddy codes
http://www.hobbyking.com/buddy.asp?c...7-994F9F999819
http://www.hobbyking.com/buddy.asp?c...C-A4F2161D57ED
http://www.hobbyking.com/buddy.asp?c...5-2844193E7E4A
j0e is offline Find More Posts by j0e
Old Jul 08, 2012, 10:59 PM
Joined Jul 2012
buddy codes
http://www.hobbyking.com/buddy.asp?c...5A-15970D2C6A6
Turnigy Accucel-6 50W 6A Balancer/Charger w/ accessories
http://www.hobbyking.com/buddy.asp?c...F-357F28C87133
On Board Lipoly Low Voltage Alarm (2s~4s)
http://www.hobbyking.com/buddy.asp?c...3-F759BF32B445
Turnigy 6mm Heat Shrink Tube - BLACK (1mtr)
davoo is offline Find More Posts by davoo
Old Jul 11, 2012, 07:21 PM
Beginner Flyer
Singapore, Singapore
Joined Jul 2012
HobbyKing Buddy Codes
TGS Sport 6x4E Precision propeller
http://www.hobbyking.com/buddy.asp?c...8-2BAD324C0DF1
Turnigy Servo Tester
http://www.hobbyking.com/buddy.asp?c...2-FEC6FB7FCC0F
X-BLADE Precision knife with replaceable SK-
http://www.hobbyking.com/buddy.asp?c...9-689B0B3C4EF4
hexTronik 24gram Brushless Outrunner 1300kv
http://www.hobbyking.com/buddy.asp?c...6-CF5BED0208F9
RayInFlight is offline Find More Posts by RayInFlight
Old Jul 12, 2012, 06:21 AM
Joined Jun 2012
Extra Codes, You can save 11.46% for all of this products with:http://rc-buddy.com/user/peepsdayz! Codes from RC-Buddy.com
3.17mm Prop Saver w/ Adapter & 3 bands
Savings: 71.14 % / $1.06
Price after: $0.43
Weight: 20 g
Fat Shark Dominator 3rd Generation modular FPV System
Savings: 9.3 % / $27.89
Price after: $272.06
Weight: 625 g
HobbyKing Red Brick 20A ESC
Savings: 9.74 % / $0.63
Price after: $5.84
Weight: 33 g
Slow Fly Electric Prop 8045R (4 pc - Green, RH Rotation)
Savings: 13.01 % / $0.32
Price after: $2.14
Weight: 35 g
Turnigy nano-tech 2200mah 3S 25~50C Lipo Pack
Savings: 42.91 % / $7.72
Price after: $10.27
Weight: 237 g
Extra Codes, You can save 22.2% for all of this products with:http://rc-buddy.com/user/peepsdayz! Codes from RC-Buddy.com
Slow Fly Electric Prop 8045SF (4 pc)
Price after: $2.14
Weight: 41 g
HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA)
Savings: 2.35 % / $0.47
Price after: $19.52
Weight: 99 g
Hobby King Quadcopter Power Distribution Board
Savings: 42.86 % / $1.71
Price after: $2.28
Weight: 38 g
5.6mm x 14mm M3 Nylon Threaded Spacer (10pc)
Savings: 36.02 % / $0.67
Price after: $1.19
Weight: 14 g
5.6mm x 21mm M3 Nylon Threaded Spacer (10pc)
Savings: 36.02 % / $0.76
Price after: $1.35
Weight: 15 g
20CM Male to Male Servo Lead (JR) 26AWG (10pcs/set)
Savings: 76.32 % / $4.35
Price after: $1.35
Weight: 39 g
PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC)
Savings: 5.66 % / $0.09
Price after: $1.50
Weight: 30 g
Extra Codes, You can save 42.28% for all of this products with:http://rc-buddy.com/user/peepsdayz! Codes from RC-Buddy.com
Turnigy 5mm Heat Shrink Tube - BLACK (1mtr)
Savings: 83.33 % / $0.3
Price after: $0.06
Weight: 19 g
Balance Plug Savers (JST-XH 3s) (5pc Per Bag)
Savings: 26.26 % / $0.26
Price after: $0.73
Weight: 20 g
HobbyKing Super Glue CA (50g / 1.7oz) <b>Super Thin</b>
Savings: 59.41 % / $1.42
Price after: $0.97
Weight: 89 g
TL-680 Thread Locker & Sealant Ultra High Strength
Savings: 2.02 % / $0.02
Price after: $0.97
Weight: 85 g
Peepsdayz is offline Find More Posts by Peepsdayz
Old Jul 12, 2012, 09:59 AM
Joined Jun 2012
Extra Codes, You can save 13.83% for all of this products with:http://rc-buddy.com/user/peepsdayz! Codes from RC-Buddy.com
Savings: 65.66 % / $0.65
Price after: $0.34
Weight: 15 g
Hobbyking 6CH RC Flight Simulator System (Mode 2)
Savings: 10.41 % / $1.56
Price after: $13.43
Weight: 770 g
Old Jul 12, 2012, 03:02 PM
Joined Mar 2011
Find my codes here: http://hk.rc-international.info/swarm/mh (valid until July 26, 2012)
JST-XH to JST LED Power Distribution Lead (6 JST) Save US$: 1.31
Peel-n-stick foam tape. 10x5inch 4mm thick Save US$: 1.25
Soft Ferrite Rings 16x7x10 (5pc) Save US$: 0.61
Antenna Pipe and Cap (1Pc/Bag) - A2016T Save US$: 0.18
Turnigy Battery Strap 330mm Save US$: 0.37
Old Jul 24, 2012, 06:39 PM
Joined Jul 2012
FrSky TAS-01 Telemetry Triaxial Acceleration Sensor
[S]$7.43[/S] $6.35* (buddy<br>price 15%, -$1.08)
Turnigy Pure-Silicone Wire 20AWG (1mtr) RED
[S]$0.79[/S] $0.48* (buddy<br>price 39%, -$0.31)
5.6mm x 30mm M3 Nylon Tapped Spacer (10pc)
[S]$2.45[/S] $1.57* (buddy<br>price 36%, -$0.88)
Turnigy Pure-Silicone Wire 20AWG (1mtr) Black
SF E-Prop 10x4.7 / 254x119.5mm w/ Adapters Black (5pcs/bag)
[S]$2.99[/S] $2.56* (buddy<br>price 14%, -$0.43)
Nylon Screws - Diam:4 x Length:34mm (10pcs)
[S]$0.99[/S] $0.54* (buddy<br>price 45%, -$0.45)
[S]$1.86[/S] $1.19* (buddy<br>price 36%, -$0.67)
All my buddy-codes here
faccan is offline Find More Posts by faccan
Old Jul 24, 2012, 10:27 PM
ChangeBegins AtTheDinnerTable
killowatt's Avatar
Raleigh , N.C.
Joined Jun 2006
Zippy Compact 3s 1500 25c U.S.A warehouse
Description:
http://www.hobbyking.com/buddy.asp?c...8-BA377A40C7BA
killowatt is offline Find More Posts by killowatt
Old Jul 31, 2012, 08:35 AM
flyboygaac's Avatar
Portugal, Lisbon, Sintra
Joined Jul 2011
Find my codes here: http://hk.rc-international.info/swarm/flyboy_____ (valid until August 12, 2012)
TGS Sport 12x8E Precision propeller Save US$: 1.98
APC style propeller 10x5-E Save US$: 0.13
flyboygaac is offline Find More Posts by flyboygaac
Discussion Hobbyking/RC Lander 68mm Buddy Code Southern335 Hot Online Deals 0 Feb 26, 2012 11:52 PM
Discussion Hobbyking Buddy Price code TheLeabres HobbyKing 11 Nov 10, 2011 11:21 PM
Alert Hobbyking Buddy Price Code -Nano-tech 300mah MCPx batteries - $3.05 mmalik4 Hot Online Deals 1 Sep 19, 2011 01:42 PM
Alert Hobbyking Buddy Code - Futaba Servo Arm Set - $1.69 mmalik4 Hot Online Deals 0 Sep 16, 2011 03:37 PM
Alert Hobbyking buddy code for sharing Fishermen21 Hot Online Deals 0 Sep 09, 2011 03:21 AM
