Old Mar 29, 2012, 05:32 PM
Highfly7 is offline
Find More Posts by Highfly7
Joined Mar 2012
Hobbyking buddy codes
Here are some Hobbyking buddy codes
BMS-966DMG Digital Metal Gear High Speed Servo 3.4kg / 0.06sec / 29g
Savings: 23.75 % / $4.96
Price after: $15.92
Weight: 87 g
Turnigy 9X LCD Backlight Kit - White (DIY)
Savings: 26.65 % / $1.33
Price after: $3.66
Weight: 24 g
Metal Finish cap for 3mm Screw for all 30-90 helis Red (10pcs)
Savings: 59.63 % / $1.95
Price after: $1.32
Weight: 15 g
Hobbyking ZYX 3-Axis Flybarless System USB Program Adapter
Savings: 40.62 % / $1.58
Price after: $2.31
Weight: 25 g
Heli Canopy Rubber Grommet Large (6pcs/bag)
Savings: 5.88 % / $0.02
Price after: $0.32
Weight: 10 g
TL-242 Thread Locker & Sealant Medium Strength
Savings: 17.17 % / $0.17
Price after: $0.82
Weight: 85 g
2 in 1 Magnetizer and Demagnetizer Tool
Savings: 40.4 % / $0.4
Price after: $0.59
Weight: 89 g
Turnigy Super Brain 80A Brushless ESC
Savings: 97.39 % / $68.16
Price after: $1.83
Weight: 69 g
Turnigy A-6-10 200W Balance charger & discharger
Savings: 10.3 % / $3.95
Price after: $34.40
Weight: 789 g
Receiver Wrap Yellow
Savings: 13.73 % / $0.21
Price after: $1.32
Weight: 33 g
Turnigy Ball End Driver for R/C Helicopters
Savings: 36.11 % / $0.52
Price after: $0.92
Weight: 39 g
HK-500GT Metal Electronic Parts Tray (Align part # H50021)
Savings: 39.8 % / $2.03
Price after: $3.07
Weight: 19 g
Turnigy Swashplate Tool (8mm)
Savings: 23.96 % / $0.92
Price after: $2.92
Weight: 26 g
Balance Plug Savers (JST-XH 6s) (5pc Per Bag)
Savings: 59.22 % / $1.06
Price after: $0.73
Weight: 25 g
Turnigy Typhoon 500H Heli Motor 1800kv (500 Class) (USA Warehouse)
Savings: 2.41 % / $0.76
Price after: $30.84
Weight: 201 g
Un-Cure CA Debonder 1. oz (USA Warehouse)
Savings: 23.98 % / $0.59
Price after: $1.87
Weight: 44 g
CA Applicator Reg (1pc) (USA Warehouse)
Savings: 46.94 % / $0.23
Price after: $0.26
Weight: 3 g
Hands free small item holder
Savings: 35.82 % / $0.96
Price after: $1.72
Weight: 369 g
Savings: 16.66 % / $8.83
Price after: $44.16
Weight: 159 g
HK-500GT Washers
Savings: 80.34 % / $1.43
Price after: $0.35
Weight: 9 g
HXT 4mm Gold Connector w/ Protector (10pcs/set)
Savings: 6.32 % / $0.23
Price after: $3.41
Weight: 57 g
JR Transmitter Neck Strap
Savings: 6.35 % / $0.19
Price after: $2.80
Weight: 60 g
Lithium Polymer Charge Pack 25x33cm JUMBO Sack
Savings: 6.23 % / $0.17
Price after: $2.56
Weight: 260 g
TL-262 Thread Locker & Sealant High Strength
Price after: $0.82
Weight: 85 g
EC5 5mm Connector (Pair)
Savings: 7.14 % / $0.08
Price after: $1.04
Weight: 23 g
Battery Strap (5pcs/bag)
Savings: 6.15 % / $0.12
Price after: $1.83
Weight: 29 g
Highfly7 is offline Find More Posts by Highfly7
Old Mar 29, 2012, 09:27 PM
WOS is offline
WOS
Find More Posts by WOS
WOS
United States, IN, Michigan City
Joined Nov 2003
and what is a buddy code?
WOS is offline Find More Posts by WOS
Old Mar 29, 2012, 10:16 PM
choppersrule is offline
Find More Posts by choppersrule
Got Helis
choppersrule's Avatar
United States, IN, Greenwood
Joined Mar 2010
Probably more than you want to read, but it's a discount program per say.
http://www.rcgroups.com/forums/showthread.php?t=1439534
choppersrule is offline Find More Posts by choppersrule
Old Mar 30, 2012, 07:33 AM
WOS is offline
WOS
WOS
Joined Nov 2003
I Read it thank you.
Old Mar 30, 2012, 07:08 PM
Got Helis
Joined Mar 2010
No problem
Old Apr 02, 2012, 12:02 AM
Warren is offline
Find More Posts by Warren
Thermal Junkie
Warren's Avatar
San Diego - California - USA
Joined Feb 2001
Turnigy 4s 3000 40C packs!
http://www.hobbyking.com/buddy.asp?c...F-E6322D4C8501
Warren is offline Find More Posts by Warren
Old Apr 04, 2012, 12:18 AM
dhonwyn is offline
Find More Posts by dhonwyn
Joined Nov 2011
http://www.hobbyking.com/buddy.asp?c...A-033EC8A6F554 - Carbon Fiber Tube (hollow) 5x750mm
http://www.hobbyking.com/buddy.asp?c...6-0804AE914973 - Carbon Fiber Tube (hollow) 8x750mm
http://www.hobbyking.com/buddy.asp?c...C-D0720CB37901 - Strong Rare-Earth Button Magnets (10pcs/set)
http://www.hobbyking.com/buddy.asp?c...-D7CA81F3FBA7v - -Turnigy 3mm Heat Shrink Tube - BLACK (1mtr)
http://www.hobbyking.com/buddy.asp?c...E-C9D92C313688 - Propeller Adapter (Colet Type) 3MM
dhonwyn is offline Find More Posts by dhonwyn
Old Apr 05, 2012, 08:54 PM
goodhumormarc is offline
Find More Posts by goodhumormarc
figuring it out...sort of!
goodhumormarc's Avatar
USA, OR, Happy Valley
Joined Jul 2010
HXT500 5g servos
http://www.hobbyking.com/buddy.asp?c...6-092F958D4DDD
Hextronix 5gram servos! In stock! USA WAREHOUSE!
goodhumormarc is offline Find More Posts by goodhumormarc
Old Apr 11, 2012, 08:36 AM
ovisopa is offline
Find More Posts by ovisopa
Romania, SB, Sibiu
Joined Jan 2012
Find my codes here: http://hk.rc-international.info/swarm/sibianul (valid until April 25, 2012)
ZIPPY Compact 3700mAh 3S 35C Lipo Pack Save US$: 26.57
Insta-Cure Super Thin CA 1. oz Save US$: 1.04
BMS-20315 Metal Gears for BMS-380MAX & BMS-385DMAX Save US$: 0.51
Carbon Fiber Tube (hollow) 12x750mm Save US$: 0.60
Turnigy 3A UBEC with Low Voltage Buzzer Save US$: 1.58
2.4Ghz 7DB Antenna for FrSky Modules (And compatible Radios/Modules) Save US$: 4.62
Un-Cure CA Debonder 1. oz Save US$: 0.59
Insta-Flex Flexible Thin CA 1. oz Save US$: 1.10
M3X10 Nylon Screws (10pcs/bag) Save US$: 0.19
M3x12mm Nylon Screws (10pcs/bag) Save US$: 0.23
M3 Nylon Nut (10pcs/bag) Save US$: 0.17
2mm Gold Connectors 10 pairs (20pc) Save US$: 0.66
Turnigy Pure-Silicone Wire 16AWG (1mtr) BLACK Save US$: 0.61
Turnigy Pure-Silicone Wire 16AWG (1mtr) Red Save US$: 0.61
Slow Fly Electric Prop 11x4.7SF RH Rotation (4 pc) Save US$: 0.53
Turnigy Heat Shrink Tube 25mm Transparent (1mtr) Save US$: 0.18
Simple Prop Balancer Save US$: 0.50
Turnigy Pure-Silicone Wire 18AWG (1mtr) Red Save US$: 0.79
Turnigy Pure-Silicone Wire 18AWG (1mtr) Black Save US$: 0.59
4mm Gold Connectors 10 pairs (20pc) Save US$: 0.51
Hard Steel Tweezer Set Save US$: 0.29
X-BLADE Spare SK-5 Steel blades (10pcs/set) Save US$: 0.63
Flat 26AWG servo wire 1mtr (R/B/W) Save US$: 0.15
Twisted 22AWG servo wire 1mtr (R/B/W) 22AWG Save US$: 0.67
FrSky TEMS-01 Telemetry Temperature Sensor Save US$: 0.94
Turnigy Battery Strap 330mm Save US$: 0.37
Battery Velcro Strap (2pcs/bag) Save US$: 1.30
Turnigy 4mm Heat Shrink Tube - BLACK (1mtr) Save US$: 0.31
Turnigy 4mm Heat Shrink Tube - Save US$: 0.31
Turnigy 6mm Heat Shrink Tube - BLACK (1mtr) Save US$: 0.28
Turnigy 6mm Heat Shrink Tube - Save US$: 0.22
5.6mm x 36mm M3 Nylon Threaded Spacer (10pc) Save US$: 0.87
5.6mm x 30mm M3 Nylon Tapped Spacer (10pc) Save US$: 0.88
Turnigy Heat Shrink Tube 50mm Blue (1mtr) Save US$: 0.50
ovisopa is offline Find More Posts by ovisopa
Old Apr 11, 2012, 11:25 PM
itsmillertime is offline
Find More Posts by itsmillertime
United States, TN, Memphis
Joined Dec 2011
Find my codes here: http://hk.rc-international.info/swarm/daniel (valid until March 29, 2012)
Carbon Fiber Tissue (Fine 10g/m2) 1mtr Save US$: 0.99
Turnigy 5mm Heat Shrink Tube - Save US$: 0.29
Turnigy 3mm Heat Shrink Tube - Save US$: 0.31
Turnigy 2mm Heat Shrink Tube - BLACK (1mtr) Save US$: 0.22
Turnigy 2mm Heat Shrink Tube - Save US$: 0.32
10X6 Propellers (5Pcs/Bag) Save US$: 1.02
9x5 Propellers (5Pcs/Bag) Save US$: 0.96
TP Slow Fly propeller 11x3.8 Save US$: 0.47
TP Slow Fly propeller 11x4.7 Save US$: 0.47
TP Slow Fly propeller 9x4.7 Save US$: 0.10
TGY Slow Fly Prop 9*6SF w/ shaft adapters Save US$: 0.59
TGY Slow Fly Prop 8*6SF w/ shaft adapters Save US$: 0.72
TGY Slow Fly Prop 8*3.8SF w/ shaft adapters Save US$: 0.47
APC style propeller 8x6-E Save US$: 0.39
APC style propeller 8x4-E Save US$: 0.39
APC style propeller 11x5.5-E Save US$: 0.71
APC style propeller 10x5-E Save US$: 0.13
SF E-Prop 9x3.8 / 229x96.5mm w/ Adapters Black (5pcs/bag) Save US$: 0.44
SF E-Prop 10x3.8 / 254x96.5mm w/ Adapters Black (5pcs/set) Save US$: 0.80
SF E-Prop 10x4.7 / 254x119.5mm w/ Adapters Black (5pcs/bag) Save US$: 0.43
Flat 26AWG servo wire 1mtr (R/B/Y) Save US$: 0.73
HK-282A Single-Screw, Ultra-Micro Servo 2g / 0.2kg / 0.08sec Save US$: 0.13
Turnigy Pure-Silicone Wire 14AWG (1mtr) RED Save US$: 0.54
itsmillertime is offline Find More Posts by itsmillertime
Old Apr 12, 2012, 05:01 AM
seraphSG is offline
Find More Posts by seraphSG
Joined Jan 2012
My buddycodes
XT-60 to HXT 4mm Battery Adapter Lead (2pc)
[S]$3.29[/S] $2.11* (discount 36%, -$1.18)
Clevis With Arms M3 M2xL24mm (5pcs/bag)
[S]$5.99[/S] $5.30* (discount 12%, -$0.69)
Knife Edge Reamer 0.5~18mm
[S]$6.15[/S] $5.77* (discount 6%, -$0.38)
TURNIGY 4pcs hex socket driver set
[S]$4.61[/S] $4.01* (discount 13%, -$0.6)
MPX Connector Male/Female (10pairs/set)
[S]$3.99[/S] $3.67* (discount 8%, -$0.32)
Turnigy Infrared Thermometer (-33 ~ 180Celsius)
[S]$9.99[/S] $9.39* (discount 6%, -$0.6)
HK-500GT Landing Skid (Align part # H50122)
[S]$2.20[/S] $0.98* (discount 55%, -$1.22)
[S]$2.24[/S] $1.95* (discount 13%, -$0.29)
[S]$0.34[/S] $0.25* (discount 26%, -$0.09)
Velocity Stack For 30cc-50cc Gas Engine (Red)
[S]$6.63[/S] $6.22* (discount 6%, -$0.41)
Carbon Fiber Tail wheel set 26cc~30cc Gas Plane
[S]$14.56[/S] $13.66* (discount 6%, -$0.9)
TURNIGY Voltage Protector
[S]$1.99[/S] $0.61* (discount 69%, -$1.38)
TurboThumbs Super Big JR Rocker (1pair) Red
[S]$4.95[/S] $4.67* (discount 6%, -$0.28)
Adjustable Control Horn 3x34mm (5sets)
[S]$2.08[/S] $1.58* (discount 24%, -$0.5)
All my buddy-codes here
seraphSG is offline Find More Posts by seraphSG
Old Apr 17, 2012, 06:35 AM
Zahid Rasheed is offline
Find More Posts by Zahid Rasheed
Let,s build it and fly ..
Zahid Rasheed's Avatar
Pakistan, Sindh, Karachi
Joined Dec 2010
Find my codes here: http://hk.rc-international.info/swarm/zr (valid until May 01, 2012)
Carbon Fiber Rod (solid) 1.8x750mm Save US$: 0.73
Transparent PET Film-3C 1 Metre Save US$: 1.17
Turnigy Glow Plug Lighter Tool Save US$: 0.36
Spare Rubber Ring for Prop Saver (10pcs) Save US$: 0.82
Zahid Rasheed is offline Find More Posts by Zahid Rasheed
Old Apr 17, 2012, 09:03 PM
key bored is offline
Find More Posts by key bored
key bored
key bored's Avatar
Joined Jan 2012
Here are my buddy codes for the USA Warehouse
HK-500 CMT- pay only $95.81
http://www.hobbyking.com/buddy.asp?c...4-17A921D50F63
Turnigy Typhoon 500H Heli Motor 1800kv- pay only $30.59
http://www.hobbyking.com/buddy.asp?c...C-C8CB91CC869A
Turnigy MG930 Digital Metal Gear Servo- pay only $13.55
http://www.hobbyking.com/buddy.asp?c...A-A28AEB85A39F
ZIPPY Flightmax 2200mAh 3S1P 30C- pay only $15.98
http://www.hobbyking.com/buddy.asp?c...2-B997A9062DFE
key bored is offline Find More Posts by key bored
Old Apr 18, 2012, 09:32 AM
Stufido is offline
Find More Posts by Stufido
Joined Apr 2012
Hi Guys, here are mine buddies for you (valid until May, 2nd, US Warehouse):
Turnigy 4000mAh Spektrum DX8 Intelligent Transmitter Pack (pay only $15)
http://www.hobbyking.com/buddy.asp?c...7-7E3F359FB5CB
Turnigy Receiver Controlled Switch (pay only $6.17)
http://www.hobbyking.com/buddy.asp?c...A-19E3AE86FCFD
OrangeRx R910 Spektrum DSM2 9Ch 2.4Ghz TwinPort Rx (pay only $21.18)
http://www.hobbyking.com/buddy.asp?c...B-8C9EE974FDE2
Stufido is offline Find More Posts by Stufido
Old Apr 18, 2012, 11:05 AM
elcid79 is offline
Find More Posts by elcid79
elcid79's Avatar
Joined Apr 2012
Valid until May 2.
TGS Sport 6x4E Precision propeller - Buddy code for .48 -
http://www.hobbyking.com/buddy.asp?c...2-A0A5ADF397F5
POM 20x27mm Control Horns - .90
http://www.hobbyking.com/buddy.asp?c...C-1A94BC3F9543
elcid79 is offline Find More Posts by elcid79
Discussion Hobbyking/RC Lander 68mm Buddy Code Southern335 Hot Online Deals 0 Feb 26, 2012 11:52 PM
Discussion Hobbyking Buddy Price code TheLeabres HobbyKing 11 Nov 10, 2011 11:21 PM
Alert Hobbyking Buddy Price Code -Nano-tech 300mah MCPx batteries - $3.05 mmalik4 Hot Online Deals 1 Sep 19, 2011 01:42 PM
Alert Hobbyking Buddy Code - Futaba Servo Arm Set - $1.69 mmalik4 Hot Online Deals 0 Sep 16, 2011 03:37 PM
Alert Hobbyking buddy code for sharing Fishermen21 Hot Online Deals 0 Sep 09, 2011 03:21 AM
