Teflon Tape vs. Pipe Thread Compound... - Plumbing Forum Posted on the Posted by lazypup "Per ASTM (American Society of Testing & Materials) Standards we must use a thread sealant on all NPT (National Pipe Taper) Threads & fittings. The type of thread sealant is selected for compatibility with the material that the pipe will be conveying. In residential service the use of NPT joints is normally limited to water, natural gas, propane gas, #1 & #2 heating oils and occasionally low pressure steam, refrigerants or high-pressure air in a shop compressor system. TEFLON TAPE: WHITE-Single density- should only be used on NPT threads up to 3/8 inch. YELLOW- Double Density- yellow double density is often labeled as "Gas type" RED-Triple Density: (Note-the container is red but the tape itself appears as a pale pink color). Presently required on all joints ½" diameter or greater. GREEN- Oil Free PTFE tape- Required for use on all lines conveying oxygen (I.E. –medical oxygen or welding oxygen lines). COPPER COLOR- contains granules of copper and is to be used as a thread lubricant but is not approved as a thread sealant. (Generally it is used as a thread lubricant on bolts or pipe threads for mechanical applications where no physical seal is required.) PTFE tape is only approved as a thread seal when applied correctly. To apply you begin at the end of the pipe and wrap the tape under tension in the direction of the thread turns. Each successive layer should overlap the previous layer by ½ to 2/3 and continue wrapping until the entire threaded portion of the pipe is covered. (Minimum of 3 full turns). PIPE DOPE: When looking for pipe dope in the hardware or home supply store we commonly find two types, a tube of dark gray paste labeled "Pipe dope" and tubes or small bottles of white "Teflon Pipe Dope". When selecting the pipe dope check the fine print very carefully to insure the product is listed as approved for the application you intend to use it for as some of these products have a very limited range of applications. As a rule the Teflon pipe dope will have the broadest range of applications and will normally meet all requirements that would typically be found in a residential environment. Loctite 565 specs found here, http://www.henkelna.com/cps/rde/xchg...UID=000001FDTZ |
I have used this sealant on boiler fittings/pipe threads for over 30 years, with or without Teflon tape.
Works every time and foolproof with tape combination. http://toolmonger.com/wp-content/upl...ith-teflon.jpg Giovanni |
| Thread Tools | |
| Discussion HK450/HK500CMT - HK now using thread locker on components? | cswilsn | Electric Heli Talk | 3 | Dec 10, 2011 08:54 AM |
| Help! Removing thread-locker | 840193 | 3D Flying | 3 | Sep 05, 2007 09:47 PM |
| Loctite / Thread Locker | Red 61 | Beginner Training Area (Aircraft-Electric) | 5 | Oct 26, 2005 06:52 PM |
| Question Thread Locker | rowdyates | Micro Helis | 2 | Oct 14, 2004 01:34 AM |
