Old Mar 29, 2012, 02:44 PM
TheBlood+ is offline
Find More Posts by TheBlood+
Heavy thinker..I mean tinkerer
TheBlood+'s Avatar
Canada, ON, Aylmer
Joined Apr 2009
Prop Balancer for High Performance
Just curious as to what guys are using to balance small props for your high performance machines. I find that the typical ones you see at the hobby shop aren't up to the job of balancing 4" props because the spindles themselves come unbalanced from the factory on these balancers and that's no good as far as I'm concerned. If you check them without a prop on them...you'll see what i mean. I'm speaking of the magnetic one that I use, alright for larger props though.
So what are you guys doing?
TheBlood+ is offline Find More Posts by TheBlood+
Old Mar 29, 2012, 03:04 PM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
its tuff, if you have a few balancers that are good, you can compare them, and maybee get the same result, but in the end it all depends on how everything matches together anyway, the rotor/propp/nut/spinner/ and so on...
I have spend time balancing a 4.7x4.7 prop to perfection, but in the end the rotor in the motor was a bit off, which you cant do anything about, so wasted time..
My conslusion with these small props is, balance them as good as you get, and have at least 4-5 of them ready, then just try them and spin them up, if it vibrates, just turn them like 45 degrees angle till it gets better, or change prop and do the same again..
sebbe is offline Find More Posts by sebbe
Old Mar 29, 2012, 05:22 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Topflite powerpoint mag balancer, works shweet as. 4.1x4.1 at 50k smooth as silk.
jackosmeister is online now Find More Posts by jackosmeister
Old Mar 29, 2012, 06:16 PM
TheBlood+'s Avatar
Canada, ON, Aylmer
Joined Apr 2009
Thats the one I have, and I'm not impressed with the unbalanced spindle you get with it.
Old Mar 29, 2012, 06:18 PM
Auckland NZ
Joined Aug 2007
mines fine, maybe your ones bent?
Old Mar 29, 2012, 11:08 PM
RknRusty is offline
Find More Posts by RknRusty
RknRusty's Avatar
United States, SC, Columbia
Joined May 2010
That Top Flite rod is soft for better magnetic properties and very easy to bend. I bought one last week and tested the cones. They stay put where ever I place them. I tried to find a position they wouldn't stay in and couldn't. Unless I bend it trying to press it into a prop hub, I see no reason it should change. But it does come with a parts list. And the instructions said, for precision light props, to balance the cones and polish the rod tip and the magnets.
RknRusty is offline Find More Posts by RknRusty
Old Mar 30, 2012, 11:22 AM
TheBlood+'s Avatar
Canada, ON, Aylmer
Joined Apr 2009
Not bent, that's one of the first things one would tend to check I would think, so its got to be the plastic cones.
Old Mar 30, 2012, 01:12 PM
Flyextreme is offline
Find More Posts by Flyextreme
Sure it'll work
Flyextreme's Avatar
United States, CA, Redondo Beach
Joined Nov 2005
I spun just the shaft. It seemed to rock and stop in the same position. I marked it with a Sharpie on the top. Keeping the mark on top, I can get them (props) silky smooth. I think it's more where the point on the end is not 100% centered. You could attempt re shaping the tip.
The vender sent me a new shaft....same thing.
Flyextreme is offline Find More Posts by Flyextreme
Old Mar 30, 2012, 02:28 PM
Troy is offline
Find More Posts by Troy
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
I had issues with the OEM metal shaft and plastic cones so I modified mine to accept one of these hand balancers and drilled through-holes in one of the bases of the balancer stands to be able to slide the stands closer together (closing the gap). This has worked wonders on balancing small props and the hand balancer apparatus has super sharp, pointy ends and is balanced well.
Troy is offline Find More Posts by Troy
Old Mar 30, 2012, 02:40 PM
TheBlood+'s Avatar
Canada, ON, Aylmer
Joined Apr 2009
I have one of those hand spindles kickin around, that's a good idea to try it.
Thanks for the idea.
Old Mar 30, 2012, 02:52 PM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
remember, the lighter the balancer is, the better for smaller props, the ideal balancer would be a hard shaft like 1mm, short, with light cones from hard plastic..
Turning a greater mass is not a good idea for a slightly unbalanced small prop.
Even if the heavy balanced shaft/cones are perfect balanced, it is way better to have a lighter one with maybee 1/6th the mass of the heavy one, then its possible for the prop to turn it if its just slightly unbalanced..
try open o steeldoor compared to a light wood one..
takes much more momentum to make the steel one move..
Old Mar 30, 2012, 07:06 PM
TheBlood+'s Avatar
Canada, ON, Aylmer
Joined Apr 2009
Those are some very good points.
Old Mar 30, 2012, 09:01 PM
Troy is offline
Troy's Avatar
Joined Feb 1999
My hand balancer weighs 1.5g less than the stock shaft and plastic cones so fear not.
Old Mar 30, 2012, 11:49 PM
TES is offline
TES
Find More Posts by TES
TES
Tom Erik
TES's Avatar
Norway, Aust-Agder, Arendal
Joined Mar 2012
I suggest you try the same method we uses on tailrotors on helicopters. Use your Dubro-balancing kit, but let the balancing shaft rotate on two ice-cubes! This gives almost no friction:
TES is offline Find More Posts by TES
Old Mar 31, 2012, 03:08 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
TES, lookes interesting, not sure it would be ok for a small 4.1x4.1 prop..
I forgot to say, when balancing props, ALWAYS balance in both X and Y axis..
Yippee! NEW DRAGON LINK ADVANCED: Full Telemetry, Bluetooth, Droid Planner, Data Modem JettPilot FPV Equipment 51714 Today 05:34 AM
For Sale 4 "RC Lab" 1500mAh, 3s, 11.1V High Performance Lipo Batteries For Sale PianoMan5 Aircraft - Electric - Batteries & Chargers (FS/W) 2 Mar 28, 2012 01:40 PM
Discussion Build thread of cnc bearing servo tray for your high performance models kin Multi Task F3X 9 Oct 30, 2011 07:05 PM
Discussion Best 2.4G Radio for High performance Dan the man High Performance 15 Oct 27, 2011 03:17 PM
Help! Looking for high performance 68mm topforce Electric Ducted Fan Jet Talk 11 Sep 18, 2011 04:44 PM
