This thread is privately moderated by unclegeorge, who may elect to delete unwanted replies.
Old Mar 29, 2012, 12:30 PM
unclegeorge is online now
Find More Posts by unclegeorge
Trader Rating: 240
unclegeorge's Avatar
United States, FL, Sarasota
Joined Feb 2005
Trader Rating: 240
Sold
NEW ITEM-NIB-Gas engine the size of a .40 glow-Save money by not buying Glow Fuel!
Gas Engine the size of a .40 size engine! Cheaper fuel; same power! I have only 6 engines left out of the 10. I should have bought more!!!
Quit buying expense Glow Fuel, get the same size as a.40 Glow engine that burns Gas!
Here is your chance to get a small compact Gas engine the same size as an OS Max .46 Glow engine that burns Gasoline. The engine will pay for itself the first year!
Remember to burn gas WITHOUT ethanol or get a marine gas treatment that takes it out to save the O-Rings and Diaphragm pump in this engine.
Take a really close look at the pictures and the specs and you’ll get as excited as I did when I discovered it.
This is a new generation of small gas quality engine, it combines the advantages of both Nitro and gasoline engines, compact in size, light weight, fuel economy, reliable and powerful.
GT9 Engine Type: Gasoline Two-stroke, Air Cooled
Displacement (cc): 9.07cc
Bore x stroke (mm): 23.35 x 21.2
Carburetor: NGH made 60G needle with pump membrane
Max output: 0.8HP@15000RPM
RPM Range: 2600-15000RPM
Ignition: Auto advanced Rcexl DC-CDI with special spark plug cap
Spark plug type: 1/4 x 32 Rcexl
Ignition Power: 4.8V
Lubrication Oil: 2 cycle engine Oil API TC/JASO FD or better specs. (Mobil + M2T)
Break-in fuel oil ratio: 20:1 (5%)
General use fuel: 25:1 (4%) (Oil percentage can not less than 4%)
Recommended propellers: 10 x 6 to 12x6 (two blades)
Weight: 425g (without ignition)
545g complete
See this engine fly a PT-19
PT19 Ngh 9cc (5 min 58 sec)
1.Size: same as .52 glow engine size
2.Mount: beam-mount
3.Carb: special smaller carb with pump and regulator by NGH
4.Muffler: special smaller anodized Pitts-style muffler with Black
5.Plug: 1/4*32 NGK
6.Exploded: almost same as a .52 glow engine. just extra special carb, muffler, CDI and Plug, and special pump regulator (not shown in the picture)
7.Use Airplane: almost same use for .52 glow engine with 40 size airplane!
I will sell this engine NIB for $169 plus $12 shipping by priority mail inside the US with confirmation and tracking number.
Please give me your mailing address and please refer to the item you are buying in the “Subject line” along with your mailing address in your Pay Pal purchase. My account in Pay Pal is under uncgeorge@comcast.net
Uncle George
unclegeorge is online now Find More Posts by unclegeorge
Old Mar 30, 2012, 06:25 AM
viflyer is offline
Find More Posts by viflyer
Trader Rating: 95
St. Croix, US Virgin Islands
Joined Oct 2003
Trader Rating: 95
Have you tried running it without the pump when the tank is mounted close to the engine?
viflyer is offline Find More Posts by viflyer
Old Mar 30, 2012, 08:22 AM
Trader Rating: 240
Joined Feb 2005
Trader Rating: 240
It has to have a pump or it will not run. This is a gas engine not a glow engine.
Old Mar 30, 2012, 08:36 AM
viflyer is offline
Trader Rating: 95
Joined Oct 2003
Trader Rating: 95
Really, it's a gas engine??? Duh, I didn't know that thanks for the tip.
Old Mar 30, 2012, 09:03 AM
JRAllen is offline
Find More Posts by JRAllen
Trader Rating: 86
Fly it or get rid of it
JRAllen's Avatar
United States, NC, Hampstead
Joined Oct 2005
Trader Rating: 86
Paypal sent for the NGH GT 09 gas engine.
James
JRAllen is offline Find More Posts by JRAllen
Old Mar 30, 2012, 09:04 AM
rangamatchstic is offline
Find More Posts by rangamatchstic
Trader Rating: 0
Mt helena western australia
Joined May 2009
Trader Rating: 0
obvious troll is obvious
rangamatchstic is offline Find More Posts by rangamatchstic
Old Mar 30, 2012, 05:48 PM
viflyer is offline
Trader Rating: 95
Joined Oct 2003
Trader Rating: 95
That's funny considering I had a question about the engine. And what was YOUR question about??? Seems like YOU fit the Troll definition to a tee.
AND, I had a reason for asking the question. It is possible that the carb mounted on the engine is adequate and has it's own PUMP IF the tank is located near the motor but needs the aditional pump if mounted farther away.
The Saito 14 has it's own pump and they recommned the tank be mounted close to the motor LIKE A GLO ENGINE.
This motor appears to have a split Walbro type carb that needs the pump to work properly and allows for mounting the smaller half on a smaller motor.
I was hoping that that the motor might operate wi the mounted carb alone for a weight/space savings.
But HECK, I am just a troll right?
Old Mar 30, 2012, 06:00 PM
Trader Rating: 240
Joined Feb 2005
Trader Rating: 240
Remember there are alot of different arrangement by other manufacture and what works for one does not work for others. Saving 3 ounces of weight just doesn't seem worth the risk. You can go ahead and try it on a beach run but the venturi effect and fuel draw does not appear the be adequite when the engineer designed a pump to get the fuel to the carb under pressure. Relying on the fuel to be suck in with a pressurized tank is the down fall to most glow engine where the fuel tank placement is critical. The use of a pump elminates the need of the placement. The tank can be about or below the needle valve position that is why there is a pump. The Walbro system has worked on my gas engine for years. That is why I left glow in went to gas 20 years ago. Let me know if it works.
Uncle George
Old Mar 30, 2012, 08:46 PM
JRAllen is offline
Trader Rating: 86
JRAllen's Avatar
Joined Oct 2005
Trader Rating: 86
Did you receive payment for the engine?
James
Old Mar 30, 2012, 10:09 PM
Trader Rating: 240
Joined Feb 2005
Trader Rating: 240
Yes I did, thank you. I will ship as soon as Pay Pal hits my bank next week.
Uncle George
Old Mar 31, 2012, 11:00 AM
earlwb is offline
Find More Posts by earlwb
Trader Rating: 63
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Trader Rating: 63
viflyer, the NGH engine's carb is actually a floatless carb design. It has a diaphragm and valve in it to control the amount of fuel going into the carb. The external fuel pump is needed to provide some positive fuel pressure flow to the carb.
I was mightily tempted to pull the trigger on this myself, but I had just received one a week before George put his up for sale.
earlwb is offline Find More Posts by earlwb
Old Mar 31, 2012, 07:18 PM
JRAllen is offline
Trader Rating: 86
JRAllen's Avatar
Joined Oct 2005
Trader Rating: 86
Thanks, Can't wait to get it. Putting it on a Great Planes Pete N Poke. So cool to put gas on a plane like this........
Jamie
Old Apr 03, 2012, 12:18 PM
JRAllen is offline
Trader Rating: 86
JRAllen's Avatar
Joined Oct 2005
Trader Rating: 86
Has the engine shipped yet. I'm showing payment to be complete/
Jamie
Old Apr 03, 2012, 04:28 PM
Trader Rating: 240
Joined Feb 2005
Trader Rating: 240
Engines was shipped today with confirmation and a tracking #0311-0820-0001-8049-0935 by priority Mail from the Glenn Garry USPO a www.usps.com.
Uncle George
Discussion Just a thought on fuel savings... RCWorks Life, The Universe, and Politics 14 Mar 26, 2012 02:28 PM
For Sale Prop Chart and Thread finder for any Glow or Gas Engine unclegeorge Aircraft - General - Miscellaneous (FS/W) 0 Feb 24, 2012 03:06 PM
For Sale Rc os max 40 nitro engine master airscrew prop fuel tank & glow plug igniter t.korb Aircraft - Fuel - Engines and Accessories (FS/W) 2 Feb 22, 2012 12:46 PM
Question Which Gas Engin Equels Glow ispirit99@verizo Engines 16 Sep 20, 2009 12:05 AM
Discussion "Water4Gas" Save money on fuel in your car using hydrogen russainred95 Chit Chat 6 Jun 07, 2008 05:55 AM
