Old Mar 29, 2012, 03:18 AM
jethack356 is offline
Find More Posts by jethack356
Guam
Joined Apr 2007
Question
How can I get more speed?
Hi guys. I have this Mugi(see attachment), which has a 48" span X 24" length and weighs approx 1.5 pds flying weight. I'm running a Electrafly Ammo 2845 2700KV
motor, 60amp esc, 3s 3000mah lipo and a 6 X 4 prop which I know is too much prop for that motor. The motor , however seems to be holding up nicely though.
I'm guessing I'm getting speeds in the 60-70 mph range with that setup. I'm not that
knowledgeable about motor setups, so here is the question. Can somebody recommend a setup that might give me some more speed? 100mph would be nice!
jethack356 is offline Find More Posts by jethack356
Old Mar 29, 2012, 03:41 AM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Speed usually comes from pitch and rpm, you could try some of the APC Thin props.
They do a handy range of 4.75" to 5" diameter. If you drop below that 6" prop and increase the pitch, you should hopefully get slightly more rpm, and a better pitch speed.
Cheaper than changing the motor or going up another cell to 4s.
But if you want a lot more speed, change the motor, change the prop, change the Lipo pack, and probably change the plane. High speed comes at a cost.
eflightray is online now Find More Posts by eflightray
Old Mar 29, 2012, 03:54 AM
billum is offline
Find More Posts by billum
Joined Oct 2007
A cheap experiment would be to cut out the piece of wing directly behind the prop which can't be doing any favours to the airflow from the prop. Will cut the noise too which must be wasted energy.
billum is offline Find More Posts by billum
Old Mar 29, 2012, 06:54 AM
flypaper 2 is online now
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
And wack about 6 in. off each wingtip.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Mar 29, 2012, 11:53 AM
buracho topspin is offline
Find More Posts by buracho topspin
Joined Feb 2012
In the words of Tim Taylor, "More Power".
Higher KV motor driving a larger, higher pitch prop. You don't necessarily need a larger battery but it will need to be able to deliver the required amount of power. That's about it except that you will reach a point of diminishing returns where excess weight will overcome the ability to actually fly the thing.
It will transform from flying wing to powered brick.
buracho topspin is offline Find More Posts by buracho topspin
Reply With Quote  (Disabled)
Old Mar 29, 2012, 01:44 PM
rcalldaylong is offline
Find More Posts by rcalldaylong
Dude, I do fly all day long!
rcalldaylong's Avatar
San Jose, California
Joined Dec 2007
I'd say if you have a nice flyer, keep it that way and build another one purely for speed. You see....that's why I now have 20+ planes...
when you get to 100+ mph, you'll need to beef up the airframe, beef up your elevons, beef up your servos (otherwise if not enough torque, you won't pull up in those 100+mph speed dives and yep it'll be a lawn dart...don't ask me how I know), and yea...beef up your motor/ESC/Lipo. With all that, you'll have a fast flying brick. So really...start with a new airframe...probably faster and easier.
rcalldaylong is offline Find More Posts by rcalldaylong
Old Mar 29, 2012, 03:54 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
You probably want something which can swing a 7x7 or similar prop to get you lots of thrust as well as speed... but you'll need 500W -600W to do it.
An ARC 28-47-1.5 can get you 119mph pitch speed with a Zagi Carbon 5.1x4.9 on 3s (39.70A/426W)... and that's 34.86oz thrust.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Mar 30, 2012, 09:33 AM
JimNM is offline
Find More Posts by JimNM
WAA-08 THANK FRANK!
JimNM's Avatar
Las Cruces, New Mexico, United States
Joined Jun 2002
My first step to a faster plane is to fly in a smaller area
JimNM is offline Find More Posts by JimNM
Old Apr 01, 2012, 03:53 AM
Guam
Joined Apr 2007
Thanks for the suggestions. I put a different prop on it and got some more speed. But I also started to get some elevon flutter. So, maybe I'll just leave it as is.
Discussion how to get more speed(cheaply)? monboy10 Electric Power Cars 14 Jul 31, 2010 02:09 PM
Discussion How to get more speed on scale aircraft Stingeragent Pusher Prop Jet Models 7 Jun 07, 2010 09:09 AM
Question How to get more forward speed MCX? bhoges17 Micro Helis 4 Feb 19, 2009 12:26 PM
Discussion somebody can tell me how to get more rpm of one Speed 400 6 V Please????? Belfenson Electric Motor Design and Construction 8 Nov 28, 2006 06:47 PM
MVVS 26, how can i get more performance??? E-Maxx2000 Engines 1 Oct 15, 2005 08:14 PM
