Old Mar 29, 2012, 01:09 AM
Jcopter is offline
Find More Posts by Jcopter
Jcopter's Avatar
United States, CA, Downey
Joined Jun 2005
Gallery
Revel Gato
Just some photos of my not finished gato.
It is a work in progress
I know some of the photos are a little blury
I will re post some new later
Jcopter
Jcopter is offline Find More Posts by Jcopter
Old Mar 29, 2012, 01:12 AM
Jcopter is offline
Jcopter's Avatar
Joined Jun 2005
More photos
And a few more
Old Mar 29, 2012, 01:15 AM
Jcopter is offline
Jcopter's Avatar
Joined Jun 2005
Gato Pixs
Ok and the last few
Old Apr 01, 2012, 06:27 AM
HeliBeast is offline
Find More Posts by HeliBeast
Joined Feb 2012
Looking good. Do you trust the guns to hold up to the stress of water force when underway? Did you get the Caswell fitting kit? Are you going to weather the paint or does the Captain make his men upkeep the hull even when they are submerged? Those pics give me a lot of insight as to cutting my sub. Since the first cut is the deepest, I don't want to mess it up.
HeliBeast is offline Find More Posts by HeliBeast
Old Apr 01, 2012, 01:58 PM
Jcopter is offline
Jcopter's Avatar
Joined Jun 2005
I am not worried about the gun & fittings It will not be going fast enough to really be a problem
I did not get the caswell fitting kit, I make all my own parts except for the seals that I get from mikes subworks OH and the electronics. THe hull will weather itself over time and look natural, my 1/96 FFG looks great!!!! Don't forget to do the all the holes in the bottom
There are a lot of them Take you time.
Jcopter
Old Apr 01, 2012, 04:01 PM
Joined Feb 2012
It is good to here that about the weathering, I wasn't planning on doing it. The Captain is such a A-hole that he makes his men paint it underwater. I knew about the holes on the bottom and that is great, when I cut and installed the wood strips on my BlueFish it took all day, that was a great day. You have me rethinking the WTC, ass long as it can be removed from the top. Did you use the original diveplanes and rudder? I read that they need to be enlarged.
Old Apr 01, 2012, 06:14 PM
Jcopter is offline
Jcopter's Avatar
Joined Jun 2005
I used all the original parts but used brass rods or shims for the ruddar & diveplanes. Just the way dave merriman did his first one. If you do a search you will see his orig cobal reports. I just did not want to split mine down the center, as dave did his. I found that it was able to accept a 2 1/2" WTC just by cutting away some of the top.
Jcopter
Old Apr 01, 2012, 07:52 PM
crowman17 is offline
Find More Posts by crowman17
Western , Pennsylvania
Joined Feb 2009
Looks great!
Marc
crowman17 is offline Find More Posts by crowman17
Old Apr 01, 2012, 09:37 PM
Jcopter is offline
Jcopter's Avatar
Joined Jun 2005
Still A Work In Progress...
But I keep on pluggin along
Working on the WTC getting the servos installed and lining up the pushrods
Jcopter
Old Apr 06, 2012, 01:27 AM
Jcopter is offline
Jcopter's Avatar
Joined Jun 2005
Just an update on the WTC for the Gato, I have finally got the motor and the pushrod exits done to the endcap. It took a little while to engineer where all the parts where goung to go and line up. Had to be sure to get the holes in the rite places. But I now can continue and move on with all the other electronics that need to be installed in the WTC. I think it is looking good and I'm quite pleased with the progress so far. Now for the pump & Bladder section then the battery aft section.
Jcopter
Old Apr 08, 2012, 11:11 AM
OhioMike is offline
Find More Posts by OhioMike
OhioMike's Avatar
Grafton, Ohio
Joined Sep 2003
So JC, if im looking at this right, your showing an over/under motor/twin drive for the 2 screws and the 2 pushrods for the planes and rudder, correct? Are you going to put the rx., pump, esc, apc, and contactor/switch for the pump all ahead of the of the servos shown or seperated with some ahead of the wtc/ballest tank in a third wtc? Also, wheres the links and systems/servos going to go for the forward dive plans? Also, there is the option of wet storage for batts.
OhioMike is offline Find More Posts by OhioMike
Old Apr 08, 2012, 11:28 AM
Jcopter is offline
Jcopter's Avatar
Joined Jun 2005
Hey Omike
the wtc you see is just a test piece I have a 24" length of the tubing, I am just using this temporary. The 2 screws are Horizontal and the 2 rear Pushrods are in the vertical plane one for the ruddar and the other for the dive planes.
as to placement after what you see here, will go the reciever, sub safe, ESC, then the pump area with the valves ans switches, then the bladdar and finally the battery and the other servo for the forward planes as well as the on off switch
This was just the begining of a long process of enginerring the spaces and layout of all the parts it takes some time to figure the final spots for all.
Hope this helps some
Jcopter
Old Apr 27, 2012, 05:37 PM
pjdog is offline
Find More Posts by pjdog
Jack
pjdog's Avatar
United States, FL, Hudson
Joined Feb 2010
I have a Gato sub that's not finished yet. I've been having allot of trouble getting the bow drive planes to rotate. It's beebn on the shelf for a couple years. Been thing of doing another Gato. I have a second Sub Driver.
Keep up the good work. I'm going to check your progress and see what I can learn.
Jack
pjdog is offline Find More Posts by pjdog
Old May 03, 2012, 09:26 PM
laser110 is offline
Find More Posts by laser110
Just Limin'
laser110's Avatar
United States, NJ, East Brunswick
Joined Nov 2008
Nice looking build, looks like you went with the boxtop colors. I have a Gato I am hoping to start within the next few weeks.
Scott
laser110 is offline Find More Posts by laser110
Old May 03, 2012, 09:33 PM
Jcopter is offline
Jcopter's Avatar
Joined Jun 2005
Yes, Yes I did go with the stock Colors
Have fun with your build... I am still working on mine
but it looks gooooood
Jcopter
Discussion Revell Gato build questions laser110 Submarines 38 Feb 20, 2013 05:42 PM
Discussion Engel Akula and Revell Gato Rick227 Submarines 0 Jan 14, 2012 07:28 PM
Discussion Selling my Revell Gato project Steve2381 Submarines 0 Sep 22, 2011 05:50 PM
Sold Revel Gato + Merriman Sub Driver ir3 Boats (FS/W) 3 Sep 08, 2011 02:59 PM
Discussion is it wrong? revel gato motors my eyes hurt Submarines 1 Feb 10, 2010 05:45 PM
