This thread is privately moderated by noppita, who may elect to delete unwanted replies.
Old Mar 29, 2012, 12:45 AM
noppita is offline
Find More Posts by noppita
noppita's Avatar
Joined Jul 2009
My new Quad frame "Noppita-W4"
I want to design and build a small and less weight quad for my system. The total frame weight is 220 grams. The aluminum arm is 29 cm long. Both top and bottom center plate is cut from 2 mm epoxy sheet. The battery will be installed on the top and you can attach Gopro directly to the small bottom plate. I am using motor 2212 850 KV motor from rctimer.com and hobbyking 20 amp + simon firmware and TC i2c converter.
Description:
Description:
Description:
Description:
noppita is offline Find More Posts by noppita
Old Mar 29, 2012, 12:52 AM
noppita is offline
noppita's Avatar
Joined Jul 2009
Assembly instruction by photo
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Old Apr 22, 2012, 11:05 AM
noppita is offline
noppita's Avatar
Joined Jul 2009
upgraded my Noppita-W4 with damper system for smoother vdo result.
Build Log My new butterfly Quad - Tri frame caotri Multirotor Talk 9 Nov 30, 2011 04:47 AM
Discussion My New "Iconic-X" aluminum Quad frame designs Quad_Addict Multirotor Talk 72 Oct 18, 2011 10:48 PM
Discussion my new quad frame joey1117 Multirotor Talk 1 Sep 10, 2011 04:26 PM
