Old Mar 28, 2012, 07:50 PM
Time for me to Fly...
Mr. Wiz's Avatar
United States, MI, Fenton
Joined Jan 2000
What do you do when you're between props?
So here is my dilemma. I have a power system that isn't giving me the watts at the prop I want with an APC 14x7E. The 14x8E gives me the watts I want but the pitch speed is too high IMHO for a Telemaster. Nobody makes a 15x7. What do I do? APC makes a 15x6 glow prop. Should I try that?
Mr. Wiz is offline Find More Posts by Mr. Wiz
Old Mar 28, 2012, 11:02 PM
Alameda, CA
Joined Dec 2006
Sorry, but APC makes a 15x7E .
What C batteries are you using, and what is their condition?
Getting new batteries of a higher C might just do it.
Also, you might try cutting down a 15" prop. It gets a little tricky with bigger props, but it can be done.
Hope this helps.
Steve
sgomes is offline Find More Posts by sgomes
Old Mar 29, 2012, 12:32 AM
Don't worry be happy :)
Stark's Avatar
Sweden, Gävleborg County
Joined Sep 2001
Also try the XOAR wood props for electric. They have more "bite", better acceleration, in my experience.
Stark is offline Find More Posts by Stark
Old Mar 29, 2012, 02:41 AM
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
In my experience with trainer style models apparently excessive pitch speed doesn't seem to hurt, and in fact for a well overpowered model, seems to result in better part throttle, ie reduced rpm, performance. I'm talking 75-83 (12x10, 13x10) mph pitch speed for an LT-25 - seems nicer overall than the 50-60mph mark (12x6, 12x8). Even with the prop supposedly stalled for a while takeoff is never an issue - I only use 1/2 to 2/3 throttle anyway.
If it flies OK with the 14x8, ignore the pitch speed
scirocco is offline Find More Posts by scirocco
Old Mar 29, 2012, 03:13 AM
Staffs, UK
Joined Nov 2003
A 15x7 is probably not a practical option anyway. It will take quite a lot MORE power than a 14x8. 15x6 is roughly equivalent on power but then you'll have even less pitch speed.
It sounds like you're doing all this theoretically on the ground. I'd suggest flying the two props you have a few times and seeing if you really have a problem.
Steve
slipstick is offline Find More Posts by slipstick
Old Mar 29, 2012, 03:49 AM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Sorry Mr Wiz, but why are you measuring watts to determine how a plane will fly ?
"I have a power system that isn't giving me the watts at the prop I want..."
I always thought that was the wrong way to go. Having the right prop give the right sort of flight style for the model, I have always thought was the better way to go. The wattmeter is just a safety device to check you wont let any magic smoke esc.
eflightray is offline Find More Posts by eflightray
Old Mar 29, 2012, 06:29 AM
Mr. Wiz's Avatar
Joined Jan 2000
Hope this helps.
Steve
Ok I see it on the APC prop list but it seems nobody stocks it. I'll give APC a call.
Old Mar 29, 2012, 06:32 AM
Mr. Wiz's Avatar
Joined Jan 2000
You're right, Ray. I haven't flown it yet and I intend to fly them both to see which I like better. I may well have to live with one of those although I now see a 15x7 on the APC web site. We'll see
Old Mar 30, 2012, 12:09 AM
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
+ This
Lardog is offline Find More Posts by Lardog
Discussion What do you do when all your planes are broken? FeiJi Beginner Training Area (Aircraft-Electric) 29 May 21, 2012 03:14 PM
Question when do you choose a slow-fly prop over an electric prop? John M.. Power Systems 6 Feb 11, 2012 01:54 PM
Discussion Panasonic Lumix GH2 video settings, what do you use when flying? I need help. Mactadpole Multirotor Talk 3 Dec 21, 2011 09:40 PM
Discussion How DRUNK are you when you fly? (Or, what kind of Brew do you enjoy when flying?) dnasrep000 Life, The Universe, and Politics 161 May 16, 2006 02:19 PM
what do you do when you're done? micro_builder Indoor and Micro Models 21 Oct 29, 2005 12:28 AM
