Old Aug 24, 2012, 03:50 PM
PDX Slope Pilot is offline
Find More Posts by PDX Slope Pilot
Eagle Butte User
PDX Slope Pilot's Avatar
Portland, Oregon
Joined May 2002
Good luck Ian!
PDX Slope Pilot is offline Find More Posts by PDX Slope Pilot
Old Aug 24, 2012, 09:39 PM
concreteman is offline
Find More Posts by concreteman
concreteman's Avatar
United States, CA, Torrance
Joined Aug 2004
Maiden for Ian happened. Maybe next time he will remember the ballast!.... He found a small rock landing, and put in a small scuff, I know he is quite peeved about it...
WD
concreteman is offline Find More Posts by concreteman
Old Aug 24, 2012, 09:45 PM
bluffman is online now
Find More Posts by bluffman
bluffman's Avatar
Joined Sep 2003
Well the maiden went pretty good, thanks to Warren helping me set up the plane, we did quite a few in flight adjustments, my landing was really good plane floated right in, but then skidded about 3' over a rock, I will get over it but man does that suck getting scuffs and a deep gouge first flight.
bluffman is online now Find More Posts by bluffman
Old Sep 25, 2012, 03:40 AM
F3B Fly Faster is offline
Find More Posts by F3B Fly Faster
Joined Jul 2008
Originally Posted by MKSservosUSA.com View Post
G'day all,
Last weekend I was able get out and maiden my Fosa Lift
I started with Jiri's settings that Bob had sent me,
CG - 105mm
Tow hook - 125mm from end of nose cone
Flaps, aileron and elevator in Launch - 15mm for flaps together with ailerons and around 1-2mm of down elevator
Flaps. aileron and elevator in distance - all zero
Flaps, aileron and elevator in duration - plus 3, plus 3, zero
Flaps, aileron and elevator in speed - 0 to minus 1, 0 to minus 1, zero
Any further twecks from these settings Thomas
F3B Fly Faster is offline Find More Posts by F3B Fly Faster
Old Sep 25, 2012, 05:26 PM
Joined Jul 2008
At long last its arrived.
Bad lighting, its red on the bottom.
Can anyone tell me what Rx batteries are being used.
Old Nov 04, 2012, 10:23 PM
Joined Jul 2008
I had a fly on the weekend.
Where did you guys get your set ups from. 15mm launch flap and ended up with about 4mm down elevator to get her to launch. I converted back to about 15% launch flap and ended up with about 5mm launch flap and zero elevator on launch setting 1 and she screamed up the line and pinged to the moon.
Next weekend I will play some more with CG - tow hook and launch setting 2.
Old Nov 05, 2012, 06:37 PM
MKSservosUSA.com is offline
Find More Posts by MKSservosUSA.com
MKSservosUSA.com's Avatar
Joined Feb 2011
Hey Fly Faster,
I have not had much time working on my settings.
Until last weekend I only had only a couple more flights since April/May
Last weekend I did get to fly her at the USA F3B Team Selections for three whole days of flying fun
I was using Jiri's settings but see some work is needed on my launch set up.
By the end of the contest she was launching better but still not where it should be.
The Fosa Lift has a lot of potential and hope that between now and Christmas will get some more time on her.
I loved the way she flew at the TS and after not flying F3B for 11 years, got a PB in distance (30 laps and the Grand) and a PB in Speed!
Thomas
MKSservosUSA.com is offline Find More Posts by MKSservosUSA.com
Site Sponsor
Old Nov 10, 2012, 07:46 PM
DrFragnasty is online now
Find More Posts by DrFragnasty
Thermal Wrangler
DrFragnasty's Avatar
Launceston Tasmania
Joined Mar 2004
Fosa Lift in Tas
Had the chance to check out Mick's Fosa Lift up close and it's solid, light and as strong as my Ceres.
Unfortunately we fly different modes so I didn't bother about asking for a go.
Mick's uses conventional flap horns (like Ceres; with clevis barely broaching the top skin) and RDS for ailerons. Wise move IMHO.
Custom colour scheme proved visible and distinctive.
DrFragnasty is online now Find More Posts by DrFragnasty
Old Nov 11, 2012, 03:38 AM
f3f-f3b is offline
Find More Posts by f3f-f3b
f3f-f3b's Avatar
Joined Dec 2009
Hi, Finally got to fly my FOSA LIFT for a Full day. Well what can say ,Launches hard,Speed Fast as, Thermals easy, distance Lots.
Lucky I brought Two of them
Will put setting up later
Cheers Eddy
f3f-f3b is offline Find More Posts by f3f-f3b
Old Nov 15, 2012, 02:00 AM
Joined Jul 2008
Can anyone tell me what the distance is on there Fosa lift from the nose cone lip to the front of the slot where the tow hook is.
I am wondering if my slot has been set to far back.
Old Nov 15, 2012, 06:08 AM
f3f-f3b is offline
f3f-f3b's Avatar
Joined Dec 2009
F3B Fly Faster,
Mine is 121mm From nose cone lip to front of slot
Whats your C/G. I'm at 105/6 from L/E
Hope that helps
Cheers Eddy
Old Nov 15, 2012, 04:56 PM
Joined Jul 2008
Thanks Eddy, your the 2nd one to confirm the 121mm
I still have a lot of setting up to do. CG is 102 as a starting point and the tow hook is forward in the slot. Conditions havn't been great for setting up launch. Hopefully I can sort it out this weekend.
Old Nov 15, 2012, 09:44 PM
f3f-f3b is offline
f3f-f3b's Avatar
Joined Dec 2009
F3B Fly Faster
Fosa Lift 2, 121mm
Eddy
Old May 10, 2013, 10:18 AM
lesterpk is offline
Find More Posts by lesterpk
lesterpk's Avatar
Australia, WA, Perth
Joined Oct 2003
Is the standard RDS setup for the flaps only good for around 45-50 degrees of movement? I seem to have a lot of up throw available and was wondering about popping the servo out and rotating the shaft one spline around for more throw, worth the effort or should I just adapt my landing style?
lesterpk is offline Find More Posts by lesterpk
Old May 10, 2013, 11:14 AM
tewatson is offline
Find More Posts by tewatson
Riddle me this...
tewatson's Avatar
United States, CA, Orange
Joined Oct 2006
I no longer have mine, but it was getting about 55 degrees of flap (slight additional bend added to the wipers). If it's servo travel you're out of, then definitely rotate one spline tooth.
Tom
tewatson is offline Find More Posts by tewatson
New Product Baudis Fosa F3B/F3F PDX Slope Pilot Multi Task F3X 483 Feb 05, 2014 03:10 PM
Discussion Fosa 2/Fosa Lift? Avaldes Multi Task F3X 7 Oct 02, 2011 10:56 PM
Sold ***New unbuilt "RED" FOSA B3B/F*** Just flyy Aircraft - Sailplanes (FS/W) 1 Jul 28, 2011 09:57 PM
New Product Fosa 1.86 KG Ballast Sets--Limited number available stevecondon Multi Task F3X 0 May 24, 2011 07:53 PM
For Sale Fosa 1.86 KG Ballas stevecondon Aircraft - Sailplanes (FS/W) 0 May 17, 2011 11:16 PM
