Old Mar 28, 2012, 05:29 AM
easystarfpv4 is offline
Find More Posts by easystarfpv4
Joined Mar 2012
Question
Does Easystar Elevator Section Need to be Glued on?
As I was putting my easystar together, I noticed that the Elevator section came with a ready to stick on surface, but after sticking it on the base of the fuselage, it just doesn't have a solid feeling of being stuck to the fuselage. Was wondering what others may have done when putting their kit together? Was thinking of putting some glue there to ensure that the part doesn't separate during flight. Any tips to what others may have done would be highly appreciated.
easystarfpv4 is offline Find More Posts by easystarfpv4
Reply With Quote  (Disabled)
Old Mar 28, 2012, 06:00 AM
Lancer31 is offline
Find More Posts by Lancer31
Joined Jun 2005
Check the instructions
Instruction 6, in my manual says to make sure everything is lined up straight & true, and then to glue it with Cyanoacrylate cement. They recommend using an accelerator with the cya. Good luck with your EZ*!
Lancer31 is offline Find More Posts by Lancer31
Old Mar 28, 2012, 10:13 AM
rcshirt is offline
Find More Posts by rcshirt
miniture aircraft pilot
rcshirt's Avatar
United States, FL, Tampa
Joined Oct 2007
if in doubt, i would glue it. even some planes that bolt on the tail that are arfs should be glued... thinking nexstars...
rcshirt is offline Find More Posts by rcshirt
Old Mar 28, 2012, 10:38 AM
Pete Miller is offline
Find More Posts by Pete Miller
Beaumont, TX
Joined Feb 2007
http://www.rcgroups.com/forums/showthread.php?t=1564626
Pete Miller is offline Find More Posts by Pete Miller
Discussion Need You Feedback: Sailplane Section on the Esprit Model Web Site Esprit Model Electric Sailplanes 2 Apr 23, 2012 08:05 PM
Discussion What should Initial elevator travel be on a Radian? Riodiler1 Thermal 1 Mar 20, 2012 04:25 AM
Help! Does Optic 6 Sport need to be updated jlremr Hitec/Multiplex USA 3 Jan 11, 2012 11:43 AM
