Old Mar 27, 2012, 09:54 PM
Joined Feb 2010
Like A Gyro To Keep Wings Level During Take-Off-From-Grass
I am looking for an electronic gadget to help keep my wings level while I take-off-from-grass, by level I mean perpendicular to gravity.
Currently I have a HobbyKing Bixler (3rd gen EasyStar clone) (mono-hull without landing gear) and landing on its monohull is easy, however take-off-from-grass is much more challenging, if a wingtip dips into the grass then the plane pivots and tries to take-off in a new random direction. The desired magic device would provide input to a mixer going to ailerons/flaperons to help keep the wings level and to help prevent/recover-from wingtip dipping into the grass. A Heading¬Hold Gyro tied to the rudder might be helpful but the wingtip dipping into the grass is still the root cause of this takeoff challenge.
I am sure that other applications can be found for this magic device.
Does such a device already exist?
If any vendors need a beta tester, then I would happily volunteer.
John
JD-Slow-Thumbs is offline Find More Posts by JD-Slow-Thumbs
Old Mar 29, 2012, 01:25 AM
Paul_BB's Avatar
France, IdF, Lagny-sur-Marne
Joined Feb 2007
Hi,
Maybe the Feytech FY 30-a Flight Stabilizer ? Or the EagleTree Guardian ?
http://www.wattflyer.com/forums/showthread.php?t=65527
-Paul
Paul_BB is offline Find More Posts by Paul_BB
Old Mar 29, 2012, 05:30 AM
United States, PA, Canonsburg
Joined Sep 2001
Have you tried hand-launching? I'd suggest adding landing gear before a gyro.
Skysailor is offline Find More Posts by Skysailor
Old Mar 29, 2012, 06:25 AM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
*this* is the link I was looking for last night. Long day...
www.servocity.com/html/how_do_servos_work_.html
..a
Old Mar 29, 2012, 02:14 PM
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
I bet it was
http://www.rcgroups.com/forums/showthread.php?t=1623087
I think that's the thread you were responding to with that info
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Mar 30, 2012, 01:47 AM
Thunder Team
scott page's Avatar
United States, WA, Richland
Joined May 2009
John
I've used aileron gyros for a Bixler taking off on grass. It was only marginally successful at best -- an only if the grass was very short. Gyros just can not counteract the force of anything with greater friction that air -- ie -- grass or water.
Hand launching is far more successful - and once you get the hang of it, not difficult at all. The key is don't THROW the bixler. If the prop is spinning the correct direction and facing the correct direction -- with a 3 cell battery it will fly right out of your hand with a moderate throwing motion. We have 5 of them in our family -- We fly the heck out of the Bixer.
scott page is offline Find More Posts by scott page
Old Mar 31, 2012, 12:22 AM
Joined Feb 2010
Thanks for the input
Paul_BB
Thanks for the pointer to the Feytech FY 30-a Flight Stabilizer and the EagleTree Guardian
SkySailor And Scott Page
Hand launching might still be the best answer,
I will have to give it another serious try,
(my first few attempts made for hard crashes).
Old Mar 31, 2012, 04:56 AM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Originally Posted by pilotpete2 View Post
I bet it was
Pete
Ah, crap. Thx!
..a
Old Mar 31, 2012, 11:19 PM
Thunder Team
scott page's Avatar
Joined May 2009
Paul_BB
When you crashed from hand launching -- was it due to not enough power or did you seriously botch the throw and torque it.
I ask because IF you have the prop set up right -- it will nearly fly right out of your hand. But -- you would not believe the number of people that install the prop backwards on the Bixler/Sky Surfer and think it's a gutless wonder -- because it will still fly -- just not very well.
So if the prop has the numbers facing the tail -- it's on backwards and you would have to really throw hard to get it to go -- but throwing hard causes problems with adding roll or yaw during the release.
When hand launching DON'T throw upward. Look at the horizon and throw at the horizon. #1 mistake hand launching is throwing up upwards causing a stall. #2 mistake is throwing too hard and inducing yaw or roll.
When hand launching you should have the transmitter on a lanyard or better yet, a transmitter tray. If using a lanyard a balance like this http://www.hobbyking.com/hobbyking/s...dProduct=12991 helps too.. and I throw with my right hand and have my left on the right stick.. just for a second. Not sure if putting the left fingers on the right stick is good advice, it's just what I do.
Help! Elevator Up or Level During Take Off? easystarfpv4 Electric Plane Talk 19 Mar 27, 2012 11:17 AM
Question foamy edf that can take off grass jgadzia Foamy EDFs 1 Mar 25, 2012 08:06 PM
Discussion Anyone know the best Warplane from Nitroplanes that takes off from grass thor4944 Electric Ducted Fan Jet Talk 1 Feb 11, 2012 02:39 PM
Help! TWO ESCs STOP DURING TAKE-OFF... vineet_p Multirotor Talk 30 Dec 17, 2011 05:18 AM
Discussion Electric Jets that take off from grass? thor4944 Electric Ducted Fan Jet Talk 30 Mar 04, 2008 05:43 PM
