United States, FL, Daytona Beach
Joined Feb 2012
After the belt problem first occurred, I had to replace the main gear and checked/reset the belt routing at that time. The problem reoccurred as indicated in the post. Since then, the tail boom was damaged from a blade strike and I disassembled and straightened the boom. Since reinstalling the belt I have flown it once without the reversal problem occuring.
Art |
Pontiac/Auburn Hills, Michigan USA
Joined Dec 2008
Regards Max www.parkrcmodels.com |
Joined Feb 2012
[QUOTE=Parkflying;21241184]the problem might happen if the belt gets a "kink" in it or the belt has an inadvertent additional twist inside the tail boom or the tail boom has been bent causing the belt to be pinched or rubbing. QUOTE]
If that was the case, it happened at the factory since the problem started before any damage occurred. Then it continued after replacing the main gear (during which the belt routing was checked). Anyway, it has now stayed in place thru many flights since the last repairs, and I'm hoping to never observe this condition again. It may be that I have a little more tension on the belt than before. |
Joined Dec 2008
[QUOTE=Art_P;21249137]
| Thread Tools | |
| For Sale FS: Skyartec V4 Belt 250 size NEEDS REPAIR | andione1983 | Aircraft - Electric - Helis (FS/W) | 0 | Dec 28, 2011 07:20 PM |
| Discussion Skyartec Belt 250 V4, Upgrade Main frame and Gear issues | andione1983 | 3D Electric Heli Flying | 0 | Dec 06, 2011 04:22 PM |
| Discussion Wasp V4 Belt 250 | Mack531953 | Skyartec | 15 | Jun 08, 2010 12:28 AM |
| Question Will Wasp V4/Belt 250 parts fit on Wasp V3? | cfanto | Skyartec | 8 | Mar 24, 2010 04:02 PM |
| Discussion Skyartec Wasp V4 Belt 250 3D 6 channel RC helicopter | Beemer444 | Micro Helis | 9 | Dec 25, 2009 02:14 AM |
