Old Mar 28, 2012, 09:48 PM
CaptCB is offline
Find More Posts by CaptCB
CaptCB's Avatar
United States, CA, Orange County
Joined Aug 2011
My theory is, if it works well, don't mess with it, and as you can see, most of us have found the same answer. CaptCB
CaptCB is offline Find More Posts by CaptCB
Old Mar 28, 2012, 09:49 PM
Tim B. is offline
Find More Posts by Tim B.
Tim B.'s Avatar
United States, CA, Oakland
Joined Aug 2009
jjac was waiting for someone to ask !
Tim B. is offline Find More Posts by Tim B.
Old Mar 28, 2012, 10:01 PM
BOZINATOR is offline
Find More Posts by BOZINATOR
In The Sorrano Triangle
BOZINATOR's Avatar
El Dorado Hills, Calif
Joined Mar 2005
Now if I fail..it will be my own damn fault I didn't listen to the more experienced
Thanks for taking the time to set me straight on using sintra on my boats.
UH..one more thing..paint? primer or plastic paint or whatever?\
jim
BOZINATOR is offline Find More Posts by BOZINATOR
Old Mar 28, 2012, 10:06 PM
Tim B. is offline
Tim B.'s Avatar
Joined Aug 2009
Here we go again !
Old Mar 28, 2012, 11:23 PM
CaptDH is offline
Find More Posts by CaptDH
GET BACK IN THE SHOP!!!!!!
CaptDH's Avatar
United States, CA, Avalon
Joined Oct 2002
For this Sintra wheelhouse, I used thick CA and the Duplicolor high build primer followed by Duplicolor acrylic white. Both were from O'Reiley auto parts. It goes on much better than the new Krylon formula, has better tips and dries really fast..
Darrin
CaptDH is offline Find More Posts by CaptDH
Old Mar 29, 2012, 01:02 AM
CaptCB is offline
CaptCB's Avatar
Joined Aug 2011
Painting PVC foamboard
Just like CaptDH, I use Automotive touch up paint, and O'Reily's, again. I spray the paint directly on the pvc, NO primer. With today's paints, the thicker the paint, the more likely it is to chip. You can thank the EPA!! CaptCB
Old Mar 29, 2012, 01:32 AM
BOZINATOR's Avatar
Joined Mar 2005
Thanks guys...GREAT STUFF...
UH...I think I have one more question if I might be so bold
When you join the corners. do you miter cut or square cut before joining?
jim
sorry tim lol
Old Mar 29, 2012, 01:54 AM
CaptCB is offline
CaptCB's Avatar
Joined Aug 2011
Jim, I just square cut, that's also how the wheelhouse will fit together. I try to put the seams on the side walls, as they are easier to sand, and fill, if needed. Charlie
Old Mar 30, 2012, 09:17 PM
Kcal is offline
Find More Posts by Kcal
Joined Jul 2008
Ha now it’s my turn to stoke the fire, what do you use as a filler? Bondo is miserable on sintra.
Kcal is offline Find More Posts by Kcal
Old Mar 30, 2012, 09:25 PM
Tim B. is offline
Tim B.'s Avatar
Joined Aug 2009
Bondo is miserable on anything !
Old Mar 30, 2012, 10:21 PM
seaphoto is offline
Find More Posts by seaphoto
Kurt Greiner
seaphoto's Avatar
USA, CA, Grass Valley
Joined Sep 2005
I use Evercoat Catalyzed body putty on Sintra all the time - works just fine. Love the stuff. Edges hold up much better than lacquer based putties (which I also use to fill pin holes). Evercoat comes in different varieties, but I use the basic stuff in the dark blue can - it is like Bondo, but more finely milled.
seaphoto is offline Find More Posts by seaphoto
Old Mar 30, 2012, 10:55 PM
CaptCB is offline
CaptCB's Avatar
Joined Aug 2011
My favorite filler is Marine-Tex, a commercial, marine epoxy filler. I also use it to bed stuffing box's, etc. It was designed for bedding through hull fittings, on real boats. CaptCB
Old Apr 01, 2012, 08:01 AM
BOZINATOR's Avatar
Joined Mar 2005
Well I just found out using a water jet doesn't work (grape vine chit chat) I was thinking about making the boat houses using a cnc router. I understand that the cad drawings need to be converted to run the router...but to what format. Any one doing this for a living? I have a cad program (still messing with it..I am barely a newbe) I mostly stare at it and it stars back at me I though it would look better than if i chopped it out with a knife..my motor skill are not what they use to be...know what i mean?
Tuesday I get my Sintra so we will see.
jim
Old Nov 16, 2012, 01:46 PM
traviswparkervt is offline
Find More Posts by traviswparkervt
Joined Nov 2012
Best adhesive for Sintra (Expanded PVC)
Weld On 2007 is an excellent water thin adhesive for Sintra. Sorry for the bump.
traviswparkervt is offline Find More Posts by traviswparkervt
Discussion Dymond D47 servo, Which version do you have on hand, how can you tell??? TDboy Hand Launch 5 Apr 21, 2012 02:26 AM
Question Where do you get your trim designs and how do you test them? dedStik The Builders Workshop 16 Mar 15, 2012 03:32 PM
Discussion How do you set up DR/expo on realflight 6? Dr.JJ Simulators 7 Feb 23, 2012 05:20 AM
Discussion How do you use hot glue for long joints? chris1379 Foamies (Scratchbuilt) 30 Jan 10, 2012 04:07 PM
Discussion Gorilla glue white. what do you 'cut' it with? UlteriorModem The Builders Workshop 6 Oct 21, 2011 11:42 AM
