Old Aug 20, 2012, 10:41 AM
cquian is offline
Find More Posts by cquian
USA, TX, The Colony
Joined Dec 2005
Originally Posted by kad View Post
Yup, it's consistent. Sometimes I can keep it in the air a little longer (a minute or so, as opposed to the 30 seconds in the video), but it always settles back down to the ground even on full power. And once it's down, it stays down because the rear props hit the grass and won't spin back up. I have to launch from a paving stone I sat in the grass and leveled.
-K
Is it possible your motors or esc's are over heating, thus loss of power. That could be an explanation of your repeatable observation. The fact that it hovers and looks to be fairly stable would indicate that the FC is setup correctly?
cquian is offline Find More Posts by cquian
Old Aug 20, 2012, 12:20 PM
flyhigh300 is offline
Find More Posts by flyhigh300
United States, TX, El Paso
Joined Nov 2010
I'm running.. 6amp esc..
he is running 10 amp..
I'm sure KAD is Frustrated to say the least.. I was really upset when the 2blade props did not work.. and had to dig around for the 3balde ..was one short.. finally found them..
flyhigh300 is offline Find More Posts by flyhigh300
Old Aug 20, 2012, 10:02 PM
kad is offline
kad
Find More Posts by kad
kad
Quad Crasher
kad's Avatar
United States, NY, Poughkeepsie
Joined May 2012
Half of me curses the pouring rain all evening (no mini testing today), the other half is grateful for the rain, we need it. <sigh>
-K
kad is offline Find More Posts by kad
Old Aug 22, 2012, 12:38 PM
jinsing is offline
Find More Posts by jinsing
jinsing's Avatar
United States, TX, Arlington
Joined Jun 2011
Description:
Slowly coming together
jinsing is offline Find More Posts by jinsing
Old Aug 23, 2012, 11:38 AM
Orphee is offline
Find More Posts by Orphee
Joined Jan 2011
The first flight of my VTail with the new Crius AIO Pro :
Hunter VTail 400mm & Crius AIO Pro 1.0 (0 min 57 sec)
Still need some tweaking, but it works great
Bye !
Orphee is offline Find More Posts by Orphee
Old Aug 23, 2012, 01:20 PM
kad is offline
kad
kad
Quad Crasher
kad's Avatar
Joined May 2012
Bye !
Nice! Is that a 400 or a 500?
Also, the bobbing up and down, is that something you expect to tune out? I ask because I consider it a major flaw in mine. It refuses to hold any altitude for more than a second or so. I'm (literally) constantly adjusting the throttle and if it can be tuned out, I'd like to find out how to do so!
-K
Old Aug 23, 2012, 02:20 PM
Orphee is offline
Joined Jan 2011
It is a 400, well i can't be sure about the up down, i was playing with sticks, i will try more Saturday...
Old Aug 23, 2012, 04:36 PM
kad is offline
kad
kad
Quad Crasher
kad's Avatar
Joined May 2012
First hard crash with the mini
Well, finally got in a quick flight to check on the power down issue. Freshly charged battery, it kept trying to go left again. I was able to hold it, kept it in the air for about 90 seconds with about 75% throttle, then it started slowly dropping down. I started increasing throttle to compensate and all of sudden it started oscillating left/right violently, then heeled over hard left and hit the ground from about 10 feet up. Damage (that I've found so far) one broken prop. Frame seems to have survived intact (Yay Eric & Luis!) The battery, when checked afterward was @ 12+ volts, just over 4v on each cell, so the settling to the ground wasn't the battery. I've got a different battery on the way (same weight) to eliminate the battery totally as an issue. Hopefully that will arrive on Saturday as the post office predicts.
-K
Old Aug 23, 2012, 07:23 PM
Orphee is offline
Joined Jan 2011
What is your setup? Motors,etc... ?
I have turnigy 2822 1450kv in front and 2822 1100kv on the tail.
Battery is 2200 3s. Gravity center most front possible, battery max at front, 8" flyduino propellers
Pid setup :
Roll : 5.0 0.030 23
Pitch : 5.0 0.045 23
Yaw : 3.8 0.045 0
Multiwii 2.1, i activated 42hz filter on the gyro in the sketch to eliminate vibrations
Old Aug 24, 2012, 01:37 AM
Joined Nov 2010
Hey man nice to know it did not come apart :-)
I did sell my little one.. :-(
just to many project..
this is the CC board ? this happen with ?
I tell you lets try .. Wii .. based
The mini gave me a challenge due to the props..but all other have work very well..
usually it come down to motor problems..
today I put back my 500 together.. and I flashed it with the ESC connected..
ESC = hobby king Mag8's . :-( they went crazy.. had to re-do all programing on ESC s.. then it was back to normal..
tested it with stock setting.. seem to do ok.. ( put Y4 on it) .. since I like it better on the Mini. :-)
-K
Old Aug 24, 2012, 03:52 AM
Orphee is offline
Joined Jan 2011
Pid setup :
Roll : 5.0 0.030 23
Yaw : 3.8 0.045 0
I forgot to say I configured it as a Y4. inverted D9 and D11 (D9 left, D11 right)
Old Aug 25, 2012, 10:28 AM
Orphee is offline
Joined Jan 2011
-K
Hi !
I had the time to tune it this morning, and as I thaught, no "bobbing up and down".
It was just your feeling on the video.
Here is a video of this morning :
Hunter VTail 400mm & Crius AIO Pro (3 min 48 sec)
Old Aug 25, 2012, 01:07 PM
cquian is offline
USA, TX, The Colony
Joined Dec 2005
Hi !
http://www.youtube.com/watch?v=fgUxN78dXIg
Very nice flight.
Old Aug 25, 2012, 04:31 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Kad
Maybe you have one motor that has an incorrect kv rating?
Dialfonzo is offline Find More Posts by Dialfonzo
Old Aug 25, 2012, 05:14 PM
tc3wins is offline
Find More Posts by tc3wins
Multirotor Builder!!!!!
South Carolina
Joined Mar 2009
Hey Dialfonzo , I sent you a pm a few days ago. need to know which way that mini board faces front, and is the y4 or vtail already loaded on the board?
tc3wins is offline Find More Posts by tc3wins
New Product Bledi-DiaLFonZo Copter VTail HUNTER 400 CANOPY + Addons Innerbreed Multirotor Talk 42 Sep 20, 2013 10:41 PM
