Old Aug 16, 2012, 04:13 PM
flyhigh300 is offline
Find More Posts by flyhigh300
United States, TX, El Paso
Joined Nov 2010
Y4 setup.. ( feel so much more solid) on this little one..
Vtail4 - ( PID setting seem good I did not make any changes)
Y4 - Tail wag's back and forth..
I change P= 5.6 and I 0.010 ..
Real quick setup and look like I got the major wag out..
did a quick test outside.. and vs Vtail .. ( seem much more stable)
on V tail it can drop out if you are aggressive in the turns..
Frame is holding up good dropped it from.. 4.. 5.. 6.. 7 feet I'm sure.. and yet to break any props..
I have bent them.. but these are soft\hard plastic.. ( if you get me) not .. flexible .. springy..plastic..
So I just bent them back.. sure they cant take much of that..but hold up so far.
I think I will push the Y4 more and see how it does..
flyhigh300 is offline Find More Posts by flyhigh300
Old Aug 16, 2012, 07:12 PM
kad is offline
kad
Find More Posts by kad
kad
Quad Crasher
kad's Avatar
United States, NY, Poughkeepsie
Joined May 2012
Ok, with the prop adapters and the 3 bladed props finally in hand, I did some more testing this evening.
I installed the prop adapters with the 2 blade props, reset the FC to defaults, charged the battery and tried it out. She got into the air this time and was even able to hover for bit, but it took almost 100% throttle to get it to do so. Then, each attempt, after 30-60 seconds, she would settle to the ground, despite pushing the throttle to 100%. I then tried a few different pid settings (high & low, the defaults were mid), lowering the gyro_lpf to 20, etc. No change.
I then switched over to the 3 blade props. And she's back to the wet dog imitation, just shaking back and forth on the ground. (Yes, the props are on right, etc). A couple of different pid settings made no difference. Unless someone has a brilliant inspiration, I think the Naze32 has to officially be declared "Does not work with VTail frames."
-K
kad is offline Find More Posts by kad
Old Aug 16, 2012, 08:47 PM
jihlein is offline
Find More Posts by jihlein
Albuquerque, NM
Joined Aug 2002
I would like to see someone try the baseFlightPlus software on the v tail. It's got much improved sensor filtering that should, in theory, help. I've got a Naze mounted to my v tail frame, but I'm still waiting for other parts.
The code does not work with any configurator program, it's all set up via a command line interface.
I'm working on some updates to increase the flight control update rate from 100 to 200 Hz, and clean up the default PID values. The default rate PID P values of 200 need to be reduced to 150 or less before flight is attempted.
There's a lot of other improvements in this alternate code, but I won't detail that here.
PM me with any questions if you decide to try it.
jihlein is offline Find More Posts by jihlein
Old Aug 16, 2012, 08:56 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Feel free to talk about it here..!
Dialfonzo is offline Find More Posts by Dialfonzo
Old Aug 16, 2012, 09:12 PM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
is it possible to use 12" prop?
and i wonder if there is any upgrade kit going to be available to increase the height of the landing gears so larger prop can be used?
jy0933 is offline Find More Posts by jy0933
Old Aug 17, 2012, 05:30 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
I do that at home and in my basement..
Not my full time job.
If you need a taller landing just ask i can draw something for sure.
Working mostly on people request for upgrades like that.
I will look later (not on the right pc) if the 500 can accomodate 12" prop.
But il look big to me.
Which motor you want to use that run 12" prop ?
Old Aug 17, 2012, 09:30 AM
jy0933 is offline
James not bond
jy0933's Avatar
Joined May 2012
im going after rctimer 2830-14 (recycle from my other quad)
since the motor-motor is 500mm.. it can literally fit 17" prop.. but i wont do that
i guess 12" should work fine..
Old Aug 17, 2012, 09:33 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
No it can't fit 17" prop...!
This is a VTail not a Quad.
Prop that are on the back will hit the ground or each other
Old Aug 17, 2012, 09:38 AM
jy0933 is offline
James not bond
jy0933's Avatar
Joined May 2012
i was saying.. LITERALLY..
Old Aug 17, 2012, 09:44 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
I am looking at drawing and 12" will not fit.
The drawing show prop on the surface of motor mount, but if you extend them (normaly motor sit 1.5-2cm above that) you will hit the ground.
Old Aug 17, 2012, 10:57 AM
Joined Nov 2010
haha... since there is talk of some interest for larger V tail..
here is an idea I've been thinking about...
I call it.. Heli-Vtail
the construction would look similar.. to a Helicopter frame.
Note: Geometry is not Correct..
FB would sit further forward.. tail would be longer
CG would also not be in the center.
The frame is intended to fit a Heli Canopy Trex500,
The Ideas is that ti would give great visual reference.. for new flyers..
where the normal rotor shaft goes.. ( you have to booms)
where the tail rotor goes you have the V part.
Frame could be build in two options.. "Traditional Vtail"
with all motors fixed.
or the two front ones could Pivot Independently..for some crazy control
haha.. the mixing option could be endless..
Old Aug 17, 2012, 11:13 AM
jy0933 is offline
James not bond
jy0933's Avatar
Joined May 2012
is it possible to increase horizontal distance between the tail motors?
also.. i actually have thought about something else to implement larger front prop.. use higher Kv motor with fit-size prop.. since the front/rear motors are already not on the same throttle level most of time.. different pairs of motor should not make much trouble as long as they provide enough thrust.
Old Aug 17, 2012, 11:25 AM
Joined Nov 2010
I think it best to scale the entire frame..
there was a few people using .. High Power systems... that had problem with
tail flex and front boom flex.
is your goal to build ? .. a heavy lift Vtail ?
or just use the motors you have ?
Old Aug 17, 2012, 12:13 PM
jy0933 is offline
James not bond
jy0933's Avatar
Joined May 2012
i recycle them from my other quad.. since no one wants them.. i decide to reuse for some cool frames...
Old Aug 17, 2012, 12:15 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
It is possible.
Only the "V" shape part would need to be change.
But i do think it will put a lot of stress on the tail arm (Twist)
Doing both top and bottom tail arm in 2.3mm would help there
New Product Bledi-DiaLFonZo Copter VTail HUNTER 400 CANOPY + Addons Innerbreed Multirotor Talk 42 Sep 20, 2013 09:41 PM
