Old Aug 10, 2012, 02:22 PM
flyhigh300 is offline
Find More Posts by flyhigh300
United States, TX, El Paso
Joined Nov 2010
I will try my best to build one this .. weekend..
Will be heavier.. as still waiting on .ups delivery for more 1mm..
Plus I want to try some color..
I've used.. this setup on a tri.. that is just as heavy.. with 2s..
If fire department leaves in the next.. few hours.. i should get my delivery..( inside joke)
Originally Posted by kad View Post
Just a note, I'm using iPower 2000kv, 10 gram motors (seem to be the same as the turnigy or HK ones, but rated for 3s) and Gemfan 5030 x 2 blade props and I can't even get it off the ground, despite iCalc's predictions of hover at 53% throttle. I still don't know if it's a FC issue (using a Naze32 that doesn't seem to like vtails), but just something to keep in mind. I've got 5030 x 3 blade props on the way at the suggestion of my LHS owner and a loaned CC board to try yet, but it's pouring rain here and I have no safe indoor testing area so I'm on hold until tomorrow.
-K
flyhigh300 is offline Find More Posts by flyhigh300
Old Aug 10, 2012, 02:35 PM
kad is offline
kad
Find More Posts by kad
kad
Quad Crasher
kad's Avatar
United States, NY, Poughkeepsie
Joined May 2012
Now, what have we told you about setting the house on fire?
-K
kad is offline Find More Posts by kad
Old Aug 10, 2012, 02:42 PM
Joined Nov 2010
It was not me... The lot next door house is being built.. and they broke a gas line..
Fire dep.. sad it would be a quick fix.. 2+ hours ago.. but from a distance I can see.. they even set up a tent now.. street is blocked off...
Old Aug 11, 2012, 06:31 PM
kad is offline
kad
kad
Quad Crasher
kad's Avatar
Joined May 2012
I've got three things I'm planning on trying:
  1. Y4 mode
  2. 3 Blade props (on order from GotHeliRC, hopefully they arrive by the weekend)
  3. A CopterControl board the above LHS owner loaned me, assuming I can figure out V-Tail mixing for it.
Tried the Y4 config today, other than a little bit of excitement when the yaw needed to be reversed to stop it spinning in circles, no difference, still won't get off the ground. New props didn't arrive yet, hopefully Monday.
-K
Old Aug 12, 2012, 08:05 PM
kad is offline
kad
kad
Quad Crasher
kad's Avatar
Joined May 2012
Tried a number of different PID settings today, both high and low. No change, still can't get the mini off the ground. I have found another possibility for a reason... I have read (in another thread here on rcg) that prop savers (as opposed to prop adapters) produce a lot of vibration. That's what I've got on this since they came with the motors and they seemed lighter than adapters would be. Any opinions on this? Should I try and find 2mm prop adapters?
-K
Old Aug 12, 2012, 08:44 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
If your prop adaptor have the right center to fit your prop and the oring is tight the vibration should be very minimal.
The prop saver can extend the lenght of shaft and add vibration.
Dialfonzo is offline Find More Posts by Dialfonzo
Old Aug 12, 2012, 08:45 PM
tc3wins is offline
Find More Posts by tc3wins
Multirotor Builder!!!!!
South Carolina
Joined Mar 2009
Dialfonzo- did you get my pm's from this morning?
tc3wins is offline Find More Posts by tc3wins
Old Aug 12, 2012, 08:54 PM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
Nope, you sent them to me.
LOL!
DoctorAudio is offline Find More Posts by DoctorAudio
Old Aug 12, 2012, 08:55 PM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
i cant remember if i have asked this before... but i would like to know about the max take off weight for the mini one.
and also would like to ask about the rec motor/prop/batt... im thinking about recycle my x250's to use on Vtail mini
my current electronics
suppo 1500-2200kv
5x3 prop @ 3s 2200mah
the total electronics/prop/motor weight is about 300g.... will these suit the mini vtail?
thx
jy0933 is offline Find More Posts by jy0933
Old Aug 12, 2012, 09:13 PM
tc3wins is offline
South Carolina
Joined Mar 2009
Doctor I sent you the PM's ?
Old Aug 12, 2012, 09:14 PM
Milwaukie , Oregon
Joined Feb 2003
Nope, just messing with you.
Old Aug 12, 2012, 10:00 PM
tc3wins is offline
South Carolina
Joined Mar 2009
All good. Lol
Rifraf is offline
Find More Posts by Rifraf
United States, CO, Golden
Joined Aug 2011
If they are the same motors an drops I am thinking of, can you just press fit the props onto the motor shafts? I did that on my last mini, worked great.
Rifraf is offline Find More Posts by Rifraf
Old Aug 12, 2012, 10:06 PM
tc3wins is offline
South Carolina
Joined Mar 2009
Alonzo your box is full.
Old Aug 12, 2012, 10:07 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
DiaLFonZo..!
Just clean a bit...
New Product Bledi-DiaLFonZo Copter VTail HUNTER 400 CANOPY + Addons Innerbreed Multirotor Talk 42 Sep 20, 2013 09:41 PM
