Old Aug 07, 2012, 05:49 PM
kad is offline
kad
Find More Posts by kad
kad
Quad Crasher
kad's Avatar
United States, NY, Poughkeepsie
Joined May 2012
Originally Posted by Dialfonzo View Post
Yes you should try the filter.
Also try to balance your prop and eleminate as much as you can..!
Balanced the props (they didn't need much, I like that about Gemfans) and activated the gyro smoothing. Results were NOT good. Got a little more altitude (a few feet) but it developed a horrible... wobble isn't a strong enough word... It looked like a dog shaking water off itself. I tried a couple of levels of smoothing, to no avail. I'm really not sure what's going on. Going to try and reset the Naze to defaults and start configuring from scratch.
-K
kad is offline Find More Posts by kad
Old Aug 07, 2012, 06:41 PM
kad is offline
kad
kad
Quad Crasher
kad's Avatar
Joined May 2012
Reset didn't help much. I made a short video to see if anyone recognizes this behavior and it's cause.
-K
MVI 0477 (0 min 51 sec)
Old Aug 07, 2012, 07:13 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
-K
http://youtu.be/_KZS00TTi-k
Look like a mix of PID and Vibration.
I will email Bledi if he have any info for you..!
Dialfonzo is offline Find More Posts by Dialfonzo
Old Aug 07, 2012, 09:12 PM
Rifraf is offline
Find More Posts by Rifraf
United States, CO, Golden
Joined Aug 2011
That's how my first test went with the Naze on the 500. Looking forward to what you find out.
Rifraf is offline Find More Posts by Rifraf
Old Aug 08, 2012, 03:53 AM
Bledi is offline
Find More Posts by Bledi
Bledi's Avatar
Joined Jul 2011
It's look like a problem o yaw direction.
Arm, put small power, put yaw stick on left if the copter turn right inverte rear motors or pur in config.h yaw direction to -1
If it's not that Decrease your pid
Bledi is offline Find More Posts by Bledi
Old Aug 08, 2012, 09:55 AM
kad is offline
kad
kad
Quad Crasher
kad's Avatar
Joined May 2012
The Yaw direction seems OK. Left stick turns the nose left, right stick turns it right. I had had the Yaw pid set at 4 originally, I believe the video was with it back at the default of 8.5. Can you suggest a value to try? Right now everything is at default (pic below). This is one of Timecop's Naze32 boards, not a standard multiwii, but as far as I know, the pid system is the same.
-K
Old Aug 08, 2012, 11:07 AM
Bledi is offline
Bledi's Avatar
Joined Jul 2011
On mini you need to Decrease all pid.
I havé no mini but try 3 on P
Old Aug 08, 2012, 11:25 AM
Eddfoo is offline
Find More Posts by Eddfoo
Malaysia, Penang, George Town
Joined Jan 2012
-K
Same thing happens to me too, but I've mine hovering quite stable now. I'm using KK 5.5e with mems upgrade and Mike Barton 16j Vtail FW. I've learned the followings:
1. For small multimotor where the motors are closer together, the gyro gain have to reduced relative to the bigger multirotor.
2. On the Vtail, the inherent flex on the tail will translate to a wobble on the roll axis.
3. Really have to balance the motors and props, especially on the tail motors.
4. Retighten the cw props after every flight. ( often overlooked). They tend to work itself loose.
On my 500 vtail, I'm using almost half of my gyro gain setting for a 800mm Tri.
I would suggest setting the I to zero and reduced the P gain and try to hover.
Adjust the P until it flly the way you like it than adjust your I. That's what I did.
Eddie
Eddfoo is offline Find More Posts by Eddfoo
Old Aug 08, 2012, 10:28 PM
kad is offline
kad
kad
Quad Crasher
kad's Avatar
Joined May 2012
I tried a P of 3 with an I of 0 (as suggested by Edd) and that was completely uncontrollable. It took off forward & up and I barely managed to stop it before it crashed into a fence. I took a trip out to a semi-local hobby shop this evening that specializes in hellis and multirotors and tested it again with a P of 3 and an I of 20. It was marginally more controllable, but still isn't getting off the ground until 70% throttle or so and it's still shaking around from about 50% until takeoff. The owner (a MUCH more experienced pilot than I) also tried it and declared it incredibly twitchy. We also tried it with the accelerometer on and there was no difference. At this point I'm considering three possible issues, in descending order of probability:
  • The Naze simply doesn't handle VTails correctly or at least not ones this small.
  • My Naze board is defective (I bought it used and had not flown it before this)
  • There's something wrong with the Throttle on my radio.
I've got three things I'm planning on trying:
  1. Y4 mode
  2. 3 Blade props (on order from GotHeliRC, hopefully they arrive by the weekend)
  3. A CopterControl board the above LHS owner loaned me, assuming I can figure out V-Tail mixing for it.
Further misadventures as they occur....
-K
Old Aug 08, 2012, 11:04 PM
flyhigh300 is offline
Find More Posts by flyhigh300
United States, TX, El Paso
Joined Nov 2010
Anyone using Wii ? I've had good luck with that stock.. PID
with Y4 and V tail setup..
maybe if I ever get some time.. I will try the other mixing option with props reversed from the first .. post..
Few pages back there was lots of work done buy Blendi and few others..
even DJI worked ..
1260kv , 8inch prop, 3S 10 and 12 amp esc's..
flyhigh300 is offline Find More Posts by flyhigh300
Old Aug 10, 2012, 11:05 AM
Joined Nov 2010
Guys.. a few people asked me what electrics to use on the Mini,
The link below is what I have used on the MiniQuad..
RED props I have not tested..
http://www.hobbyking.com/hobbyking/s...ontroller.html
http://www.hobbyking.com/hobbyking/s...idProduct=5358
http://www.hobbyking.com/hobbyking/s...s_per_bag.html
http://www.hobbyking.com/hobbyking/s...dProduct=11328
Old Aug 10, 2012, 11:25 AM
DoctorAudio is online now
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
I want one of these too.
How do you like those motors?
DoctorAudio is online now Find More Posts by DoctorAudio
Old Aug 10, 2012, 11:38 AM
tech69x is offline
Find More Posts by tech69x
Custom quad builder
tech69x's Avatar
United States, CO, Boulder
Joined Apr 2012
Thank you
tech69x is offline Find More Posts by tech69x
Old Aug 10, 2012, 12:07 PM
cmeisteriii is offline
Find More Posts by cmeisteriii
cmeisteriii's Avatar
United States, NV, Carson City
Joined Jun 2012
Very helpfull Thanks Luis
cmeisteriii is offline Find More Posts by cmeisteriii
kad is offline
kad
kad
Quad Crasher
kad's Avatar
Joined May 2012
Just a note, I'm using iPower 2000kv, 10 gram motors (seem to be the same as the turnigy or HK ones, but rated for 3s) and Gemfan 5030 x 2 blade props and I can't even get it off the ground, despite iCalc's predictions of hover at 53% throttle. I still don't know if it's a FC issue (using a Naze32 that doesn't seem to like vtails), but just something to keep in mind. I've got 5030 x 3 blade props on the way at the suggestion of my LHS owner and a loaned CC board to try yet, but it's pouring rain here and I have no safe indoor testing area so I'm on hold until tomorrow.
-K
New Product Bledi-DiaLFonZo Copter VTail HUNTER 400 CANOPY + Addons Innerbreed Multirotor Talk 42 Sep 20, 2013 09:41 PM
