Old Aug 05, 2012, 01:01 AM
tc3wins is offline
Find More Posts by tc3wins
Multirotor Builder!!!!!
South Carolina
Joined Mar 2009
got confirmation that mine is on the way.
tc3wins is offline Find More Posts by tc3wins
Old Aug 06, 2012, 05:03 PM
cmeisteriii is offline
Find More Posts by cmeisteriii
cmeisteriii's Avatar
United States, NV, Carson City
Joined Jun 2012
Wow! I just got my Mini VTail today. Awesome!!
A Big Thanks to Luis for a job well done.
Carl
cmeisteriii is offline Find More Posts by cmeisteriii
Old Aug 06, 2012, 05:04 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
But who look to care about the one who actualy made it.. ?
Dialfonzo is offline Find More Posts by Dialfonzo
Old Aug 06, 2012, 06:37 PM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
Hahaha!
ROFLAMO!
:P
DoctorAudio is offline Find More Posts by DoctorAudio
Old Aug 06, 2012, 07:00 PM
kad is offline
kad
Find More Posts by kad
kad
Quad Crasher
kad's Avatar
United States, NY, Poughkeepsie
Joined May 2012
Maiden Flight of the Mini - NOT
Ok, just tried to fly the mini for the first time. Didn't even get it off the ground. It keeps wanting to flip tail over head. My wife is laughing at me.
Setup:
  • Mini V-Tail frame (Prototype version)
  • Naze32 FC w/ 7/26/2012 firmware
  • Turnigy Plush 10amp ESCs
  • IPower 2000kv motors
  • Gemfan 5x3 props
  • Hitec Minima 6T RX
  • Nano-Tech 3s 850mha Battery
Total flying weight - 308g
Pictures below.
This is the first time I've used the Naze FC. It is set for V-Tail and, as per a post earlier in this thread, I dropped the P on the Yaw down to 4.
Rotation is as per the diagram in the first post of the thread. Writing on the props is up.
The Naze manual does not have a motor number diagram for the V-Tail config. I used the Y4 diagram and tried the tail motors once each way (1,3 and 3,1)
Any ideas folks? I'm too new at this to have any beyond the rear motor # swap I already tried.
-K
kad is offline Find More Posts by kad
Old Aug 06, 2012, 07:29 PM
mamba max1 is offline
Find More Posts by mamba max1
mamba max1's Avatar
United States, NC, Durham
Joined Jun 2010
I think you need smaller props in the back.
mamba max1 is offline Find More Posts by mamba max1
Old Aug 06, 2012, 11:43 PM
flyhigh300 is offline
Find More Posts by flyhigh300
United States, TX, El Paso
Joined Nov 2010
we all love you Eric.. ! haha..
flyhigh300 is offline Find More Posts by flyhigh300
Old Aug 06, 2012, 11:45 PM
Joined Nov 2010
:-( I may be wrong..
but I don't think anyone has had look with Naze32.. I think only open person document there effort.. with that board.
Am i wrong guys ?
Setup:
  • Gemfan 5x3 props
Pictures below.
-K
Old Aug 06, 2012, 11:50 PM
Milwaukie , Oregon
Joined Feb 2003
Could be!
Old Aug 06, 2012, 11:54 PM
Rifraf is offline
Find More Posts by Rifraf
United States, CO, Golden
Joined Aug 2011
I am still hoping to get my 500 in the air with the Naze32. I first tried the Y4 setup and it wasn't working well. I intended to try the Vtail setup, but my 500 has been shelved a couple weeks while I try to get one of my planes finished up before the end of the summer...
Rifraf is offline Find More Posts by Rifraf
Old Aug 07, 2012, 11:26 AM
kad is offline
kad
kad
Quad Crasher
kad's Avatar
Joined May 2012
The tail over head issue has been solved. The wiring harness is tight enough that I have to flip it upside down to connect the battery. Doh! The gyros were calibrating that way! A recalibrate on the gyros from the TX once it's right side up solved the issue. I need to redesign the power harness anyway...
Now problem number 2. I can barely get her off the ground. According to eCalc, she should be hovering at just under 50% throttle and that's where she was starting to lift off yesterday. Today, 100% throttle and not more than a foot off the ground. Time to check the battery on the fancy charger I think.
Anyone else have any progress with the mini yet?
-K
Old Aug 07, 2012, 11:28 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
One thing i notice with mini and Multiwii is that vibration is a real killer.
My mini Quad was not even leaving the ground and after removing as much vibrations i can and also increassing the filter in Multiwii sketch ... it was over-powered..
Old Aug 07, 2012, 11:39 AM
kad is offline
kad
kad
Quad Crasher
kad's Avatar
Joined May 2012
Oh, and I believe I've figured out the motor numbers for the Naze32 V-Tail. They are basically the same as for a normal X quad.
4, 2 - Front
3, 1 - Rear
This may be obvious to some, but it wasn't to me.
-K
Old Aug 07, 2012, 11:50 AM
kad is offline
kad
kad
Quad Crasher
kad's Avatar
Joined May 2012
I've got the Naze mounted on 2 layers of HK sticky foam, no screws at all. I see that TC has added the MW gyro filtering to the latest Naze builds. I may have to try it.
-K
Old Aug 07, 2012, 11:51 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Yes you should try the filter.
Also try to balance your prop and eleminate as much as you can..!
New Product Bledi-DiaLFonZo Copter VTail HUNTER 400 CANOPY + Addons Innerbreed Multirotor Talk 42 Sep 20, 2013 09:41 PM
